Pullstart
Shop project...
Pullstart
The S10 got a new windshield today.  For $265, it’s well worth it!
Handy Don
No sensors or cameras needing special alignment or windshield wiper heating zones needing electrical connections. JYBW (just your basic windshield!)
  • Excellent 2
Pullstart
In other words, perfect!
953 nut
It has gotten to the point where a bachelor of windshieldology is needed on the newer vehicles.              :scared-eek:
  • Sad 1
Handy Don
I take your point, though I must add that I’m enamored of rain-sensing wipers, auto-dipping high beams, wiper de-icing, adaptive cruise control, and collision warnings all of which require certain windshield specs!
My wife’s windshield had a stone chip that was repaired in about 20 minutes and it’s all but undetectable
ebinmaine
NOT a fan of these in a Freightliner.
I strongly dislike the wipers being constantly on low or high speed with no intermittent or pause or driver control.
^^^^^  These are very good.
Also incredibly annoying and I honestly believe unsafe in a commercial vehicle because they aren't set up well yet.
EVERYTHING causes a loud buzzer and lights and even occasionally a sudden unplanned severe slowdown of the truck!!
Handy Don
I’ve have five cars with some sort of wiper sensor/intermittent. This car is the first one with sufficient control to actually wipe only when needed!
I’ve had the collision thing go a couple of times. Only once was I not already onto the brake myself--maybe it saved a collision or maybe not, but it was a fair assessment by the car!
The one for backing up is a mite sensitive, though. Backing into a steeply pitched driveway, or one with shrubbery hanging over, can set it off. That said, the beep is better than a “crunch” so I’ll not disable it.
lynnmor
I had the windshield replaced on my F250, what a fiasco!  Went to their shop and they ordered the glass saying they would be replacing it in my barn.  They did just that but when done I noticed it had the wrong windshield that didn't have the margins blacked and all the guts in the pillars were exposed to the public.  They ordered another and asked me to bring it to their shop and leave it.  They removed the dash cover so they had a clear shot at tossing their power tools on the dash.  I didn't go into all the gory details but I will never have a windshield replaced until it is so bad that it can't be driven.  If you ever watched the process it is worse than seeing sausage being made.
Pullstart
I really enjoyed the company of this service tech, and he took the time to explain things and show me tricks of the trade.  It was an enjoyable experience for me!
adsm08
Unless of course the inspection mechanic says it fails.
We have a mobile guy that comes around to the shop and he does them pretty slick and easy. Usually takes him about 20 minutes, and we never have any of those issues.
adsm08
I have yet to have someone explain to me, in a way that makes sense, how any of those things are preferable to just paying attention to driving while driving.
What I have seen in practice is that those systems enable the people who already don't want to pay attention to be even less attentive to the driving part of driving.
The only exception might be the wiper de-icing.
Edited by adsm08
adsm08
I think the worst one I've ever run across is the GM rear collision alert. They don't beep, or flash, the seat vibrates. The first time that happened to me was in the shop and I almost wrecked the vehicle because it startled me.
Handy Don
Generally, you are correct.
I often do the wipers myself--saves wear and tear on the blade, the motor, and the windshield! The best sensor use case is a drizzle where passing cars are throwing up spray that the Rain-X isn’t able to bead and clear--when the camera cannot focus through the windshield, it swipes the wiper. Over a multi-hour drive, manual gets tedious.
Auto high-beam dipping reacts faster than I can, usually, and if you are in a sparse, hilly suburban area as I am, with occasional streetlighting, I like having the highs as much as possible. Auto keeps me from manually switching every minute or two.
The possible collision I avoided was a lifted F150 with elaborate modified running lighting that came to a sudden stop to enter a parking lot in dim lighting and had no brake lights! (When I circled back the driver didn’t believe me until I insisted he see for himself--“Man, I wonder how that happened?!” but no apology or thanks)
8ntruck
We've got a '22 Pacifica van with all of the bells and whistles.  Bought it used.  I didn't know it had auto wipers until we had to replace the windshield this summer.  Finally found how to turn them on - about 3 layser deep in the vehicle settings menu.  I kind of like them - now that I've gotten them activated.
I get a chuckle out of the various collision and parking warnings when going through one of the local drive through tellers.  The clearances are close enough that they all seem to go off, seemingly screaming 'LOOK OUT, WE'RE ALL GOING TO DIE!'.
adsm08
I dunno. I work on these things for a living. The ADAS stuff is a giant pain in the butt, until you get way back into the early days of just audible park aides, and even sometimes those throw me. So many of the problems are software driven, and not an actual mechanical issues that I can actually fix, but every day I see more and more people just flat out not paying attention, expecting these systems to take up the slack, with no concept of the limits of the system (most adaptive cruise or collision avoidance systems will not actually bring the car to a full stop).
Meanwhile I'm over here still driving my 87 Ranger and 04/05 Explorers with none of those systems, and I've never been in an accident where one of those systems would have made a lick of difference. I have been "at fault" for four accidents in the last 25 years. One may have been prevented by a park aide or backup camera of some sort. I had a cap on the truck, all the windows on it were iced, and I backed into a white car in a snowy field.
One other I took off in a merge lane while watching the lane I was merging into. The car in front of me did more of a "staying still" type maneuver.
The other two involved sliding through sharp turns in low-traction events.
Every other accident I have ever been in the other car, or the deer, hit me, usually because they weren't paying attention.
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
