johnnymag3 2,646 #1 Posted July 10, 2018 I believe my fuel pump on the 312 Hydro is shot. I cleaned all of the lines, and checked the float in the carb.....carb was spotless. New last year. I also changed the fuel filter which also was spotless. If I run the engine in part choke,it will run fine, but the filter is empty, If I pressurize the fuel tank and fill the Fuel filter, it will run fine until the filter empties..My guess is that under no load and low RPMs, the engine vacuum with partial choke is pulling enough fuel into the carb for the engine to run. any suggestions with regards, to the longevity of Aftermarket Pumps, vs. OEM pumps? thanks for any and all input from you guys John Share this post Link to post Share on other sites
953 nut 69,119 #2 Posted July 10, 2018 Have you taken a look at the screen filter in your gas tank to be sure it is clear? Fuel filters are seldom "full" but are passing a sufficient amount of gas to operate the engine. Have you replaced the rubber fuel lines, a slight pin hole would allow air to be sucked by the pump more easily than gas. Are you running ethanol free gas, ethanol will destroy your fuel system. https://www.pure-gas.org/ Share this post Link to post Share on other sites
JoeM 10,246 #3 Posted July 10, 2018 I've used both with no issues. The after market one is running 2 years now. I've also installed electric, but only the Mr. Gasket brand. works good too. Share this post Link to post Share on other sites
johnnymag3 2,646 #4 Posted July 10, 2018 I did blow small pressure from the fuel line to the tank.....BIG BUBBLES .!!!! and I use non ethanol now, but unsure of first owners........filter has no fuel in it when running, unless I blow into the tank Share this post Link to post Share on other sites
johnnymag3 2,646 #5 Posted July 10, 2018 should I pull pump and test it? Share this post Link to post Share on other sites
johnnymag3 2,646 #6 Posted July 10, 2018 Kohler Magnum 12 engine...common fuel pump Share this post Link to post Share on other sites
dells68 7,499 #7 Posted July 10, 2018 Go with the electric pump. I've got one on my 312 and she starts easily with a turn of a switch every time! 1 Share this post Link to post Share on other sites
johnnymag3 2,646 #8 Posted July 11, 2018 What type of electric pump? don't we need below 2 psi. for our seat to seal? and what about return lines after the bowl is full? Thanks, John Share this post Link to post Share on other sites
johnnymag3 2,646 #9 Posted July 11, 2018 Is there anyone here on this site that sells fuel pumps? Thank you, John Share this post Link to post Share on other sites
dells68 7,499 #10 Posted July 11, 2018 The pump I used is a low pressure pump. No need for a return line, as they will start almost instantly and I don't think the pump would push enough pressure to overpower the float valve. Share this post Link to post Share on other sites
Skipper 1,792 #11 Posted July 11, 2018 (edited) Yeah, I have installed quite a few low pressure pumps, and you just put them inline. No need to run returns etc. Just hook them up so they run when you have ignition on, and that's it. I have used the 10$ version several times too without any problems. Quite frankly, I do this conversion on all tractors i have come thru that has any kind if issue with the pump, and I also do it on every one of my own machines just as a preventative measure. Edited July 11, 2018 by Skipper 3 Share this post Link to post Share on other sites
953 nut 69,119 #12 Posted July 12, 2018 This one is $ 8.50 shipped to your house, found on Ebay. I am running a few of them and have had good results. HEP-02A New Gas Diesel fuel pump Inline Low Pressure electric fuel pump 12V Be sure to mount the pump lower than the tank, great pushers but lousy suckers! 1 Share this post Link to post Share on other sites
johnnymag3 2,646 #13 Posted July 17, 2018 ok, so the questions are still on the table......My tractor will run perfect until the fuel filter empties........Float is down in carb, and it still wont get fuel. Engine spits and sputters, pops and backfires....then I wait and start again in a minute or two, then it runs fine. If I leave the choke half open it runs fine forever at any speed. Do I have a blockage in the carb? I took off the fuel pump and manually tested it....it sucks and pumps as normal. The fuel in the tank is new, the lines are new, the screen is clean in the tank, the shutoff is open fully, I am at a loss for more things to look at? Thank You............... HELP John Share this post Link to post Share on other sites
johnnymag3 2,646 #14 Posted July 17, 2018 oh, I forgot to mention the needle and seat are fine also, Share this post Link to post Share on other sites
wildfire305 59 #15 Posted July 18, 2018 I had fuel issues after some water got in the tank. The cap was bad and it sat out in the rain for a day. The fuel pump died a few hours of use after I got all the water out of the system. Bought a new cap and also Bought new replacement pump - not impressed with the pump. Didn't run right at all. It turned out that the arm was 1/4" shorter and only engaged the diaphragm half way through the stroke. I got a refund for it and decided to use my noodle. I gutted the brand new pump of all the mechanisms, cut the metal disc out of the diaphragm, capped the outlet to the carb and basically created a Crankcase pulse adapter out of the pump. Then I installed a mikuni style plastic pump zip tied on the old one with the pulse port hooked up to my "adapter". The air cover hides all of it and it has been very reliable for 20 hours now. It also only cost me $10. I had previously replaced the fuel lines. Share this post Link to post Share on other sites
wildfire305 59 #16 Posted July 18, 2018 (edited) After doing all of this, I found out that Taryl Dactal has a YouTube video showing the same thing. Apparently, the replacement Kohler fuel pumps (even genuine) are not exactly reliable nowadays. The mikuni style is used on everything from quads, generators, dirt bikes, zero turns, etc. And doesn't require electricity. It also won't be dumping fuel if your engine dies and your not within arms reach to shut off the key. Edited July 19, 2018 by wildfire305 Spelling Share this post Link to post Share on other sites
