dclarke 4,082 #51 Posted August 19, 2018 1 hour ago, 953 nut said: Unless you used hardener I would let it dry a week or longer. The decals can trap solvents under them and cause the paint to lift. Good advice, Richard and Randy. Thanks! Share this post Link to post Share on other sites
dclarke 4,082 #52 Posted August 20, 2018 Got the hood on and decided to put a longer nipple in the exhaust to move the stack a little farther away from the hood. I still need to paint the letters on the front of the hood and add the decals. 4 11 Share this post Link to post Share on other sites
Shynon 7,479 #53 Posted August 21, 2018 As always top notch, looks great Denny 1 Share this post Link to post Share on other sites
dclarke 4,082 #54 Posted August 24, 2018 After running it a while I've torqued the head bolts again, the decals are on and the letters on the front of the hood are painted. I wrapped the exhaust nipple in header wrap and made a heat shield for the stack. This project is done. 1 10 Share this post Link to post Share on other sites
ebinmaine 72,424 #55 Posted August 24, 2018 2 hours ago, dclarke said: made a heat shield I like that idea. Most of my tractors will have stacks. How did you do that? Share this post Link to post Share on other sites
dclarke 4,082 #56 Posted August 24, 2018 41 minutes ago, ebinmaine said: I like that idea. Most of my tractors will have stacks. How did you do that? My stack is 3” diameter, I used a piece of 16 ga. (I think) metal cut to about 5” x 12”. Heated it a little with a heat gun then formed it around a 3” plastic pipe coupling that measures 4” O. D. Once I had the shape I wanted I cut it to size and drilled a couple of 1/4” holes in it. I used a 1/4” coupling nut cut in half then shortened each half a little to get the spacing I wanted and welded the nuts to the stack. I did bolt the nuts to the shield and tack them to the stack while it was on the tractor then removed the stack and welded the nuts. 3 5 Share this post Link to post Share on other sites
953 nut 59,773 #57 Posted August 24, 2018 6 hours ago, dclarke said: This project is done. Not quite done! Don't see any Grand kids riding on it. 3 Share this post Link to post Share on other sites
dtallon 320 #58 Posted August 26, 2018 (edited) That tractor turned out fantastic. I can't wait to see the next one. You have inspired me to work some on my Ranger 8-speed project, and I am quickly gaining appreciation for the little modifications you did. What pulley did you use for the transmission input pulley? I did some measuring and the 2.5" engine / 4" trans pulley set on the Ranger is approximately the same ratio as the 4" engine / 6.5" trans that the 312-8 I got the transmission from had. Unfortunately I can't just swap over the trans pulley from the Ranger because it has a 3/4" input shaft and the 8-speed has a 5/8" shaft. Dave Edited August 26, 2018 by dtallon Share this post Link to post Share on other sites
dclarke 4,082 #59 Posted August 26, 2018 1 hour ago, dtallon said: What pulley did you use for the transmission input pulley? I did some measuring and the 2.5" engine / 4" trans pulley set on the Ranger is approximately the same ratio as the 4" engine / 6.5" trans that the 312-8 I got the transmission from had. Unfortunately I can't just swap over the trans pulley from the Ranger because it has a 3/4" input shaft and the 8-speed has a 5/8" shaft. Dave Dave, the input pulley on this one measures 4 or 4 1/4"" it's kinda hard to measure now and the engine pulley is 2 1/2". This tranny has 1" axles and the pulley came with the tranny, I think this input shaft is 5'8". In the past I have used the Maska 4" pulley pictured below on a 5/8" input shaft, I did have to modify it a little but it worked great. I ground the hub down to fit the length of the shaft and had to drill and tap new set screw holes, which I had to drill on a slight angle. I'll use this pulley on my next Ranger project if I can't find a pulley like the one I have on this Ranger. Share this post Link to post Share on other sites
Pullstart 66,623 #60 Posted August 27, 2018 Awesome job! 1 Share this post Link to post Share on other sites
dclarke 4,082 #61 Posted August 27, 2018 On 8/24/2018 at 3:54 PM, 953 nut said: Not quite done! Don't see any Grand kids riding on it. Here ya go Richard. He loves it! 2 7 Share this post Link to post Share on other sites
ebinmaine 72,424 #62 Posted August 27, 2018 Two clear-cut championship-winning calendar shots right there 3 Share this post Link to post Share on other sites
prondzy 3,889 #63 Posted September 8, 2018 Wow Denny that looks nice! I have been plugging away at the kids Lawn Ranger and now have a few ideas for the gas tank mount thanks to yours. Did you use the stock Throttle/Choke cables or did you buy longer ones and modify? Share this post Link to post Share on other sites
dclarke 4,082 #64 Posted September 8, 2018 50 minutes ago, prondzy said: Did you use the stock Throttle/Choke cables or did you buy longer ones and modify? Mike, I had to get longer cables, here’s how I ran the throttle cable. 2 Share this post Link to post Share on other sites
Shynon 7,479 #65 Posted September 9, 2018 On 8/27/2018 at 9:02 AM, dclarke said: Here ya go Richard. He loves it! Looks like one happy camper, Great Job Denny 1 Share this post Link to post Share on other sites
rmaynard 16,290 #66 Posted September 9, 2018 Great job Denny. I only wish I had half the fabricating skill that you have. 1 Share this post Link to post Share on other sites
prondzy 3,889 #67 Posted September 9, 2018 On 9/8/2018 at 10:04 AM, dclarke said: Mike, I had to get longer cables, here’s how I ran the throttle cable. Ok last question Denny, where did you find those throttle cable clamps.They look like nice ones and i havent found any good ones yet. Share this post Link to post Share on other sites
dclarke 4,082 #68 Posted September 9, 2018 3 hours ago, prondzy said: Ok last question Denny, where did you find those throttle cable clamps.They look like nice ones and i havent found any good ones yet. Mike, the cable clamp bolted to the engine I found in my Dad’s auto parts store back in the 70s. They sold and serviced push mowers back in the 50s and 60s and it was a leftover part from that. I had a few of them at one time but this is the last one I have. The clamp up by the governor was in my junk drawer too. Not sure where it came from. 1 Share this post Link to post Share on other sites
