Butch 194 #1 Posted June 5, 2018 Now that tractor supply no longer carries their Valspar Implement paint what spray cans are people using on their wheels? Thanks! Butch S. Jersey Share this post Link to post Share on other sites
Achto 32,541 #2 Posted June 5, 2018 Many members have used Rusoleum spray paint on their tractors. Share this post Link to post Share on other sites
KC9KAS 4,746 #3 Posted June 5, 2018 Depending on the tractor, but I use RUSTOLIUM ALMOND. 2 1 Share this post Link to post Share on other sites
Retired Wrencher 6,959 #4 Posted June 5, 2018 1 hour ago, KC9KAS said: Depending on the tractor, but I use RUSTOLIUM ALMOND. What KC9KAS said. Used it many times in the past comes out nice. But I brush it with a lazy suzan. 1 Share this post Link to post Share on other sites
oliver2-44 11,717 #5 Posted June 5, 2018 For rims I use Rustoleum Appliance Epoxy in the Linen color Share this post Link to post Share on other sites
Butch 194 #6 Posted June 5, 2018 Thanks guys! Rustoleum it is!! 1 Share this post Link to post Share on other sites
giddyap 1,574 #7 Posted June 9, 2018 For what it's worth. This new nozzle shoots a straight line spray like a professional sprayer. BIG IMPROVEMENT Share this post Link to post Share on other sites
"D"- Man 827 #8 Posted June 9, 2018 Can this be removed and press fit on to a Rust-Oleum spray can? Share this post Link to post Share on other sites
giddyap 1,574 #9 Posted June 9, 2018 Rust-Oleum can on the left is different. I'm not ready to experiment, with my luck something will break and I'll lose a can of paint. But I did discover the nozzle rotates for up/ down pattern or side/side pattern. Share this post Link to post Share on other sites
c-series don 12,384 #10 Posted June 9, 2018 I don't think that they are interchangeable. Rustoleum needs to come up with a better nozzle! Share this post Link to post Share on other sites
giddyap 1,574 #11 Posted June 9, 2018 (edited) 2 hours ago, giddyap said: For what it's worth. This new nozzle shoots a straight line spray like a professional sprayer. BIG IMPROVEMENT I did use Krylon "Banner Red" from Walmart. It has the same can as Rust-oleum. While shopping at ACE I discovered they had my color. That's how I discovered Ace's superior nozzle. So the question is, whose paint is Ace using? Whatever brand name and color you are now using, You just might find the same color in the Ace can with their superior nozzle. Edited June 9, 2018 by giddyap Share this post Link to post Share on other sites
MAH 50 #12 Posted June 11, 2018 (edited) http://www.agspecialty.com/indstrial.htm This is what I use. Works good, lays nice. I haven't sprayed any body panels but the wheels came out good from a rattle can. The chassis stuff I've uses both rattle cans and sprayed with a top feed. All my colors are spot on even with different cans. One of my local mom and pop shops in the area carry it. Edited June 11, 2018 by MAH Share this post Link to post Share on other sites
