ebinmaine 74,412 #1 Posted June 2, 2018 My muffler on my Patriot horse is about an 1- 1/8" away from the hood. Is that enough? @Vinylguy..... But also everyone else. 1 Share this post Link to post Share on other sites
AMC RULES 37,226 #2 Posted June 2, 2018 When they're burnt... that's too close. 5 Share this post Link to post Share on other sites
ebinmaine 74,412 #3 Posted June 2, 2018 HAHAHAHAHHAHAHAHA!!!!! Okay. So. Yes Craig. That's probably true. Maybe. Possibly. I might want to avoid burning the decal? I don't know. Just a thought. But thanks though! I do appreciate the information. 1 Share this post Link to post Share on other sites
AMC RULES 37,226 #4 Posted June 2, 2018 I'm quite sure... Terry will make you more. 1 Share this post Link to post Share on other sites
953 nut 62,041 #5 Posted June 2, 2018 I know that a heat gun is one method of removing a decal and it isn't as hot as your exhaust. Too much heat will also discolor the paint. 2 Share this post Link to post Share on other sites
JPWH 6,541 #6 Posted June 2, 2018 I like to have about 2". So far I have not had any issues. Jay 2 Share this post Link to post Share on other sites
pacer 3,177 #7 Posted June 3, 2018 This one has been on now for a good while and I use it a good bit - its my yard trailer puller - and havent noticed any hint of discoloring. 6 Share this post Link to post Share on other sites
Chris G 3,363 #8 Posted June 3, 2018 Both stacks I have on mine are a inch away and I have had no issues so far. 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #9 Posted June 3, 2018 3 hours ago, pacer said: This one has been on now for a good while and I use it a good bit - its my yard trailer puller - and havent noticed any hint of discoloring. Beautifull looking machine. Glenn 1 Share this post Link to post Share on other sites
mrc 991 #10 Posted June 3, 2018 great looking D series!!! love those front tires. what brand and size are those? thank you mike Share this post Link to post Share on other sites
JoeM 8,832 #11 Posted June 3, 2018 maybe a guard or reflector between the muffler and hood would help? Share this post Link to post Share on other sites
SylvanLakeWH 29,265 #12 Posted June 3, 2018 You could cover up the decals with that heat muffler tape to protect them... Share this post Link to post Share on other sites
ronhatch 407 #13 Posted June 3, 2018 (edited) I have my IH Cub stacks above the hood and far enough away so it clears the hood in the open position. That gives me about 2" between the 1" pipe leading to the muffler and the hood. See picture to left. So far, so good! Edited June 3, 2018 by ronhatch Share this post Link to post Share on other sites
pacer 3,177 #14 Posted June 3, 2018 Going off topic here, but a brief explanation of the tires on my D-160 --- That is a "home made" set up, I wanted a 10" tire to possibly raise the tractor since I only use it for towing. That is a 'cart' 10" tire on a Kubota rim using a shop made spindle to take the 5 lug rim. Wasnt exactly what I was after but at least appearance wise it turned out nicely - I DO like the looks of it! 5 Share this post Link to post Share on other sites
