SIUC3 9 #1 Posted May 30, 2018 Has anyone experienced the mower drive/pto belt (part number 1577 replaced by 7430) (1/2" x 28") start to slip and squeal with the spindle belts not too tight and cutting normal grass height? Has anyone bought a smaller drive/pto belt so it fits tighter? Or should I just buy a couple of these belts and just keep going through them. The one slipping now is only about 2 months old. Any suggestions are welcome! Share this post Link to post Share on other sites
stevasaurus 23,857 #2 Posted May 30, 2018 I have had that happen. Make sure the 3 pulleys are aligned and clean them with steel wool and wipe with mineral spirits. Also, make sure your spindles are well greased. I have had trouble finding the 28" belt. I have used a 29" and it did not slip when new, but it is starting to slip now. I found a 28" belt at O'Riley's the other day...that is the belt you really want to use. I would not go to a 27". I take the grease covers off once a year to make sure I get the grease gun on the zerk. also check out your blades to see if you picked up some plastic bag or fishing line...that can really bind on a spindle. 3 1 Share this post Link to post Share on other sites
SIUC3 9 #3 Posted May 30, 2018 Right On! Thanks for the tips! 1 Share this post Link to post Share on other sites
stevasaurus 23,857 #4 Posted May 30, 2018 Let us know what you find out. It is always nice to know if we actually did help. 1 Share this post Link to post Share on other sites
squonk 48,231 #5 Posted May 30, 2018 Napa 4L280W 28" kevlar belt. With the PTO belt off spin the blades by hand. Check for binding. Lots of bearings in these decks. A real common problem I have found with these is that the cross shaft bearing start to sieze in the aluminum housings. 2 Share this post Link to post Share on other sites
SIUC3 9 #6 Posted May 31, 2018 I will keep you all up to date. I am going to be trouble shooting it tomorrow, to see if I can find the problem / solution! 1 Share this post Link to post Share on other sites
lynnmor 9,051 #7 Posted May 31, 2018 If the PTO clutch slips, the belts can also begin to slip as the torque on the blades actually goes up with the lower RPM. 1 Share this post Link to post Share on other sites
stevasaurus 23,857 #8 Posted May 31, 2018 @lynnmor he does not have a PTO clutch...it is the tension pulley that works off the right pedal kind. You are correct about the clutch thingy though. Just did not want to put any confusion in here. 1 Share this post Link to post Share on other sites
lynnmor 9,051 #9 Posted May 31, 2018 2 hours ago, stevasaurus said: @lynnmor he does not have a PTO clutch...it is the tension pulley that works off the right pedal kind. You are correct about the clutch thingy though. Just did not want to put any confusion in here. Sorry about that, I just read pto and shot from the hip, should have read the title. 1 Share this post Link to post Share on other sites
SIUC3 9 #10 Posted June 13, 2018 Sorry for the delay guys, but I did end up with a good fix! Went to O'Reilly's and they had a slotted 7-5/8" belt and works great! I'm two cuts in and hasn't slipped once yet! Here's some pics.... 2 Share this post Link to post Share on other sites
