65fstback 0 #1 Posted May 17, 2018 Need help on 212-5 mower. Does anyone know how to neutral safety switch engages,the micro switch is hanging down and I see no way for it to close when put in neutral is something missing. If anyone has pictures of switch and wiring under tank would help. Mower won't start without manually closing relay, blowing fuses and key will not shutoff mower. I checked all wiring for shorts. Fustrated!! Share this post Link to post Share on other sites
rjg854 13,083 #2 Posted May 17, 2018 Someone will be along shortly that should be able to help with the information that you need. And they may also be able to get this thread over to one of the forums more associated with the problems your having. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,276 #3 Posted May 17, 2018 Here are the North American models. B is Briggs and Stratton engine, O is Onan engine 32-12B501 (212-5) - Toro 212-5 Tractor (1989) 32-12O501 (212-5) - Toro 212-5 Tractor (1990) 32-1205A1 (212-5) - Toro 212-5 Tractor (SN: 1000001 - 1999999) (1991) This one has a typo 32-1205A1 should be 32-12O5A1 32-12B5A2 (212-5) - Toro 212-5 Tractor (SN: 1000001 - 1999999) (1991) 32-12B5A3 (212-5) - Toro 212-5 Tractor (SN: 1000001 - 1999999) (1991) 32-12O502 (212-5) - Toro 212-5 Tractor (SN: 1000001 - 1999999) (1991) 32-12O503 (212-5) - Toro 212-5 Tractor (SN: 2000001 - 2999999) (1992) When we know which one you have will look for the correct info. Each link is to the illustrated parts list. Garry Share this post Link to post Share on other sites
