kbert1171 0 #1 Posted May 9, 2018 had to jump it the first time after getting it out after winter. started right away and ran fine while i mowed. tried again last week and nothing. battery has charge according to my multi meter. doesnt make a sound or even attempt to try and turn over. tried to jump the switch and nothing. any suggestions on where to go next. Share this post Link to post Share on other sites
rmaynard 14,932 #2 Posted May 9, 2018 What is the voltage reading across your battery? Did you remember to disengage the PTO, depress the clutch, sit on the seat (if it has a seat safety switch)? What is the model number so we can be a little more specific on possible causes? 1 Share this post Link to post Share on other sites
Tuneup 1,416 #4 Posted May 10, 2018 What model? You're hinting that the tractor has the old, rugged Ford solenoid jump the switch). So, you jumped from the (+) of the battery to the center terminal and, nothing? You should at least hear the solid click of the solenoid. If not, and the solenoid is well grounded, problem = solenoid. If it clicks and there is no starter and again all the grounds and connections are clean and cables good, dead starter. Does the voltage on the battery drop when attempting to start? If yes, no more than a couple of volts for a good battery. This is how I would approach it. Like many here, these machines need TLC on their wiring and grounds. Good luck! 1 Share this post Link to post Share on other sites
953 nut 51,954 #5 Posted May 10, 2018 The first thing you need to do is clean and tighten all electrical connections including grounds. You probably should have the battery load tested, any auto parts store will do it. Share this post Link to post Share on other sites
Retired Wrencher 4,895 #6 Posted May 10, 2018 kbert1171 As you can see you have some good help here all ready. Just follow all the above. 1 Share this post Link to post Share on other sites
bottjernat1 2,189 #7 Posted August 22, 2019 if you ever need anymore help i am a big wheelhorse nut and i live in avilla. just give me a holler! Share this post Link to post Share on other sites
kbert1171 0 #8 Posted August 27, 2019 Pretty sure the starter needs rebuilt. Where is the best place to have this done, in the Kendallville area? Share this post Link to post Share on other sites
pfrederi 17,170 #9 Posted August 27, 2019 For a regular bendix type starter on a Kohler replacement with an after market unit will probably be cheaper. MY starter generator guy doesn't work on the small engine units like these. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,332 #10 Posted August 27, 2019 to !!! Share this post Link to post Share on other sites
bottjernat1 2,189 #11 Posted August 27, 2019 49 minutes ago, kbert1171 said: Pretty sure the starter needs rebuilt. Where is the best place to have this done, in the Kendallville area? i will have to do some digging there is an amish guy north of us that does it. my late dad use to use busco auto electric in churubusco but the guy was pricey and rude. you might try county line engine just outside of rome city. also depending on the starter i may have a used one id sell you cheap. you can private message me on here or facebook. i can give you my number. hope this helps Share this post Link to post Share on other sites
bottjernat1 2,189 #12 Posted August 27, 2019 55 minutes ago, kbert1171 said: Pretty sure the starter needs rebuilt. Where is the best place to have this done, in the Kendallville area? i will have to do some digging there is an amish guy north of us that does it. my late dad use to use busco auto electric in churubusco but the guy was pricey and rude. you might try county line engine just outside of rome city. also depending on the starter i may have a used one id sell you cheap. you can private message me on here or facebook. i can give you my number. Here is a map where county line engine is. https://www.mapquest.com/us/indiana/county-line-engine-357948739 Share this post Link to post Share on other sites
