CountryRock 199 #1 Posted May 7, 2018 Has anybody ever put in an electric fan for engine cooling on their tractors? Been tossing the idea around a little. 1 Share this post Link to post Share on other sites
ebinmaine 81,049 #2 Posted May 7, 2018 Not something I've ever done and I can't really help with much info but I can see where it would make sense on hot summer days. What model and engine and such and such? Share this post Link to post Share on other sites
Jerry77 1,218 #3 Posted May 7, 2018 Not a bad idea at all....go for it..... Share this post Link to post Share on other sites
CountryRock 199 #4 Posted May 7, 2018 1 hour ago, ebinmaine said: Not something I've ever done and I can't really help with much info but I can see where it would make sense on hot summer days. What model and engine and such and such? 1992 246H with a 16hp Briggs twin. I thought about cutting a hole in the top or front of the hood and mounting a fan there. Direct wiring to battery with a switch on the dash. Share this post Link to post Share on other sites
ebinmaine 81,049 #5 Posted May 7, 2018 10 minutes ago, CountryRock said: cutting a hole I can definitely see the value in doing this, especially on a twin. Can it be done without tractor surgery? Share this post Link to post Share on other sites
CountryRock 199 #6 Posted May 7, 2018 5 minutes ago, ebinmaine said: I can definitely see the value in doing this, especially on a twin. Can it be done without tractor surgery? I'm hoping someone on this forum has done it and will share how. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #7 Posted May 8, 2018 @CountryRock Take a look at the pictures on @AMC RULES thread The Resurrection 2018. He has a fan mounted on top of his twin Kohler. 1 Share this post Link to post Share on other sites
moe1965 774 #8 Posted May 8, 2018 I added a extra cooling fan on a scag zero turn I had some time ago. I used a fan off a car one of those eletric ones that kick of as needed. I put a on off switch on it and ran it when ever I wanted. I could flip the wires and either make it push or draw more air. Share this post Link to post Share on other sites
WHX?? 58,328 #9 Posted May 8, 2018 Hate to be Debbie downer here Country but why? I have the same '92 vintage 246 and mow with it on the hottest days of summer and never have problem with overheating. I do keep the fins and fan clean tho. 2 Share this post Link to post Share on other sites
CountryRock 199 #10 Posted May 8, 2018 3 hours ago, WHX17 said: Hate to be Debbie downer here Country but why? I have the same '92 vintage 246 and mow with it on the hottest days of summer and never have problem with overheating. I do keep the fins and fan clean tho. Just something I was thinking about. Since I had to redo the heads due to exhaust valve guides walking out, I thought maybe some extra cooling on the heads would help prevent that from happening again. I also keep the fins clean. There was quite a rodent nest in there last year which I know contributed to the heads getting hotter than normal. I did get a little more debris out when I made the repairs too. 1 Share this post Link to post Share on other sites
953 nut 70,076 #11 Posted May 8, 2018 4 hours ago, CountryRock said: There was quite a rodent nest in there last year which I know contributed to the heads getting hotter than normal. I did get a little more debris out when I made the repairs too That seems to be the key. Your airflow bath needs to be open, adding another fan wouldn't do any good if the path isn't open. 3 Share this post Link to post Share on other sites
RandyLittrell 3,946 #12 Posted May 8, 2018 If you decide to add one, make sure the airflow is moving air the same direction as the flywheel or you could make it worse. Post up some pics if you do it. You could also pick up a temp gun and see if it really does make a difference. Randy 1 Share this post Link to post Share on other sites
wallfish 20,724 #13 Posted May 8, 2018 (edited) How about blowing a small fan onto a small oil cooler? Maybe make one out of a small heater core? Just a little radiator with a fan blowing air through it. not sure if natural convection is enough to force it to move the viscosity of oil or not but it does thin out quite a bit when hot and gets pretty hot, so it may. Is there oil plugs on both sides of the engine? Just Edited May 8, 2018 by wallfish 1 1 Share this post Link to post Share on other sites
953 nut 70,076 #14 Posted May 8, 2018 1 hour ago, wallfish said: small oil cooler? Maybe make one out of a small heater core? Lots of power steering units have small coolers, probably cheap at the scrap yards. 1 Share this post Link to post Share on other sites
WHX?? 58,328 #15 Posted May 9, 2018 Good thinkin outside the box ther 'Fish... would need an adapter to tap off the oil filter some how. This is an pressure fed oiler. Like most oil fed Briggs ther is just a 1/8 npt tap for a pressure switch or gauge. Share this post Link to post Share on other sites
wallfish 20,724 #16 Posted May 9, 2018 10 hours ago, WHX17 said: This is an pressure fed oiler Pressure lube is even better. They do sell remote oil filter kits which something could be adapted to for cooling but they're kind of expensive IMO. How about aluminum cooling fins that clamp right onto the filter? Couple of hose clamps, some thin aluminum angle pieces with little slots for the hose clamp bands. Backyard Hammer mechanic style oil cooler! 2 Share this post Link to post Share on other sites
bmsgaffer 2,071 #18 Posted May 9, 2018 Cooling the oil will be your best bet. No electric fan will even come close to matching the airflow of your flywheel blower, and if you found one that could, your electrical system wouldn't support it. I would scour ebay for a remote oil filter kit or at least a screw on adapter for an oil cooler. Then you can put a smaller fan on the cooler much more effectively than trying to over-blow the flywheel fan. My ECH730 has the pressure lubed system with an oil cooler mounted on a hole in the shroud, so it uses the flywheel blower (LOTS of air) to force air through a small oil cooler. The oil doesn't hardly get hot on the hottest days of summer after an hour of cutting grass. It wont solve your problem of blowing exhaust valve seats if you leave a nest in there though... On another thought, the 200 series is vertical shaft, right? Forget the electric blower and just run a duct from the flywheel intake to a large vent (or maybe duct it to two smaller ones on each side to prevent rain related issues). Your best bet will be to allow the already powerful fan pull in fresh cool air, not the preheated air in the engine compartment. Share this post Link to post Share on other sites
CountryRock 199 #19 Posted May 10, 2018 On 5/9/2018 at 8:38 AM, WHX17 said: Now that's kinda neat. I have the lower profile Briggs oil filter on there now, would have to get a little bit longer filter. Looking at the Frame XG3614, which I think is what I saw on yours in one of the pictures. Share this post Link to post Share on other sites
