Countdown To Christmas!
Sarge
16 Auto/C-160 fuel cap w/gauge?
Sarge
Has anyone found a fuel gauge type cap to fit the 2-1/4" threaded neck on the plastic tanks in the C-series? My current cap leaks at much over 3/4 tank, would love to get a better-sealed unit with a gauge on it. I did find a Kelch to fit the D, it's a bit short but works great and doesn't leak, while still vented correctly.
Sarge
pfrederi
Toro part # is 106945 for the C series under seat tanks  Stens claims this one fits. I just order one will get it Wednesday will know for sure then.
roadapples
Keep us posted....thanks
Sarge
Uh - tank depth on the 16 Auto/C-160 (mine is model 1-0440) early models is only 5-3/4" compared to the under the seat tank location models...far as I know those are much deeper than the early C-series 6qt. capacity tanks.
Tank part # on mine is 103487 and cap is 102321 - through Jack's Small engines lookup, it seems the superseded part number for the cap (now showing w/gauge) is 108011....hhmmm. No other info on the superseded part other than "w/gauge". Direct search of that later part number comes back to fitting an LT-1637 Twin 5spd, odd. My original parts list does not show the section for the fuel tank cap, nor it's sizing specs. I did figure out by measuring it's using the standard 1-3/4" outside diameter threads, 5-3/4" deep to the top of the neck. This is the very rounded appearing plastic tank, not a metal one.
I did search through Kelch's offerings by size, but no luck there.
Sarge
Tankman
I tried several caps with gauges, gave up.
All eventually leaked, discolored, clear plastic cracked, forget it.
Use caps without gauges, remove the cap and take a peek-a-boo to confirm fuel level. :handgestures-thumbupright:
After taking the Horse out, fuel before the Horse rests in its stable. Always ready to ride 'em cowboy. :ROTF:
  • Excellent 3
Sarge
Yeah, it appears after a lot of searching there is no gauge available to fit the neck of this tank, it's sort of an odd size/depth. I hate trying to fill it with fuel as you can't see very well past the gas can spout. Due to the size of this property, I can mow the whole thing on one tank, sometimes - other times, not so much. It's hard to tell how much fuel it's really using since the K341 has so much torque, it's hard to hear when it's up against the governor on this engine.  I do need to find a new cap, this one leaks pretty good with anything over 3/4 of a tank.
Sarge
pfrederi
Got the cap. Fit the 418A, 310-8 and C141 perfectly.  Did not fit one of the C-175s wanted to cross thread.  (Have had a plain cap on here forever...may have imaged the threads on the tank???.)  I have to go up to the storage shed and try it on some other underseat tank horses.
Warning:Unsupervised
fwiw- I read this review below on Amazon for the Stens version 125-112 fuel cap Pfrediri posted that replaces WH/Toro 106945 cap. May be a member on here review below idk?
 Regardless I'm posting here as It may help some members out on these cap issues but I have not tried one at all myself yet to verify problems. My wife's health issues have priority over all things at the moment but' I will post an update when/if I do try one of these. I do need a cap on my 1988 414-8, not sure how it fits mine as some said it fit their 300/400 series perfectly others say it don't but posts I read don't mentioned the year of the tractor? So' I'm wondering if there may have been a subtle change in cap/tank designs over the yrs or its a factory screw up on some caps people received? After all its supposed to fit any tractor that uses 106945 cap but it dont seem to do that.  IDK why some caps fit a 300 series while others do not but this seems to be the case so maybe screw up? Tractor year just may be a factor too though, members with several tractors may solve this puzzle?
(Amazon Member Review --- Well, maybe it was my expectation level, but I assumed that Toro part # 106945 was compatible with Wheel horse part # 106945 since Toro owns Wheel horse, but not so. The threads on this one do not match the threads on the tank neck so as noted in another review, it goes on crooked and will not screw down all the way. Useless to me.
Update/PS:
  Kept messing with this thing and discovered that the problem is the cap has a raised center underneath that needs to go down inside the filler neck of the fuel tank, and it is too large to fit inside the neck of my Wheel horse C145. My tank is plastic so I used a file with a rounded side to enlarge the filler neck opening about 1/16" and then it worked perfectly. I had the tank removed so I did this with the tank upside down so the filings would'nt go into the tank. Someone measured wrong when they made these!--- end Review)
Link to cap above posted by Pfrediri located here (see 1 star rating for above post):
https://www.amazon.com/Stens-125-112-Replaces-Simplicity-1704366SM/dp/B001OK4HJ0/ref=cm_cr_arp_d_product_sims?ie=UTF8
Edited by 123GO
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
