Lambeater 14 #1 Posted April 17, 2018 (edited) Good morning guys, just putting some new rubber on my grandsons 33R and looking for front tire advice. Got some Oregon lugs for the rear but now looking for front tires, gave up on ribs for front (seem to get to expensive for shipping to Canada). Narrowed it down to Carlisle saw tooth 4.10-4 or Carlisle turf saver. What do you think will work/ look best. thanks Lambeater Edited April 17, 2018 by Lambeater adjustment 1 Share this post Link to post Share on other sites
19richie66 17,858 #2 Posted April 17, 2018 I had turf masters or savers , can’t remember which. Good little tires. Share this post Link to post Share on other sites
Mike'sHorseBarn 3,475 #3 Posted April 17, 2018 I prefer the sawtooth tread over the turfsavers, but i think that "stubby" tires are the original tread pattern, but that is just my ocd coming out lol Share this post Link to post Share on other sites
Lambeater 14 #4 Posted April 17, 2018 3 minutes ago, Mike'sHorseBarn said: I prefer the sawtooth tread over the turfsavers, but i think that "stubby" tires are the original tread pattern, but that is just my ocd coming out lol I'm thinking that way as well seem to be a bit skinnier and more tractorish. thx Lambeater 1 Share this post Link to post Share on other sites
Lambeater 14 #5 Posted April 18, 2018 Well I got the rear tires mounted , cleaned and painted rims today. Sure was a big transformation, now just for the fronts. thx Lambeater 4 Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted April 18, 2018 He'd be very proud! Nice! Share this post Link to post Share on other sites
Lambeater 14 #7 Posted April 19, 2018 put the rears on today, great transformation. Also a set of foot rests sent to me by Joe. Hopefully the engine runs tomorrow (got a new carb, cleaned tank, new filters and glass fuel bowl separator). lol Lambeater 2 Share this post Link to post Share on other sites
Lambeater 14 #8 Posted April 20, 2018 Well replaced all the fuel system today, new bowl, filter, carb and spark plug. Had some weeping from tank gasket but seemed to stop. Tried to fire but no luck and all. will check out fuel and electrics tomorrow. Any ideas on why it wont run will be much appreciated. thx Lambeater Share this post Link to post Share on other sites
Mike'sHorseBarn 3,475 #9 Posted April 20, 2018 Spray some either or carb cleaner in the carb and then see if it will fire on that. If not, you don't have any spark and you need to look at points, condenser, coil, etc. Something else to think about is that sometimes the float on those new tecky carbs need adjusted or the bowl won't fill with gas. 1 Share this post Link to post Share on other sites
Lambeater 14 #10 Posted April 20, 2018 Thanks Mike I will check the carb first since its a chinese unit off amazon. Also will check electrics easy to find all replacement electrical from Oregon. Regards Darryn Share this post Link to post Share on other sites
pfrederi 20,243 #11 Posted April 20, 2018 28 minutes ago, Lambeater said: Thanks Mike I will check the carb first since its a chinese unit off amazon. Also will check electrics easy to find all replacement electrical from Oregon. Regards Darryn Check the float setting the last Chinese cheapy for my Techy the float was way, way out of adjustment Share this post Link to post Share on other sites
Lambeater 14 #12 Posted April 21, 2018 so updates, found fuel bowl on wrong way, turned around and now runs but rough. Can get it to run smoother at high revs but will not idle and also wants to surge. idle needle doesn't seem to do much. Is this possible point problem? thx Lambeater Share this post Link to post Share on other sites
