mikeeyre74 289 #1 Posted April 16, 2018 I'm rewiring a tractor from scratch, as I'm putting the engine from a mid 70's C-120 into a '69 Charger. I've got it all mocked up now and everything tests OK, so I'm about to start running the new wiring and connecting things up.. but unfortunately, the two plugs I need were totally melted from something that happened before I got my hands on it. I'm referring to the 5 prong plug that goes on the back of the key switch (which I have located on Ebay) and the three prong "L" shaped configuration that goes on the old style voltage regulator rectifiers.. and that is the one I can't find. I know I can also do the one-at-a-time covered Spade connecter route, but I was hoping to do a nicer job and put on the proper connectors. Can anyone shed some light on what the second connector there is called, so I can look it up to buy one? Share this post Link to post Share on other sites
ebinmaine 71,258 #2 Posted April 16, 2018 Perhaps @953 nut could help. ....? Pretty sure he told me what/where that is at one point. 1 1 Share this post Link to post Share on other sites
ebinmaine 71,258 #3 Posted April 17, 2018 @953 nut, Dick I'm sure it was you who directed me to the 5 blade connector for the ignition switch. Do you know where to get the 3 blade connector for the 15 amp voltage regulator from the seventies Kohlers? Like on B, C series. .... Share this post Link to post Share on other sites
953 nut 58,564 #4 Posted April 17, 2018 Can't help with the three wire "L" shaped connector. The one I told you about was the 5 wire for the ignition switch I think. Share this post Link to post Share on other sites
ebinmaine 71,258 #5 Posted April 17, 2018 Just now, 953 nut said: Can't help with the three wire "L" shaped connector. The one I told you about was the 5 wire for the ignition switch I think. Yepp... it sure was. No worries! Share this post Link to post Share on other sites
cafoose 3,400 #6 Posted April 17, 2018 Check out this thread it may help: Share this post Link to post Share on other sites
mikeeyre74 289 #7 Posted April 17, 2018 Yep. That's where I got about half my Intel for this job... I'm looking for the same two connectors as that poster was! 😜 Share this post Link to post Share on other sites
ebinmaine 71,258 #8 Posted April 17, 2018 4 hours ago, mikeeyre74 said: Yep. That's where I got about half my Intel for this job... I'm looking for the same two connectors as that poster was! 😜 I couldn't find it online but my phone is a little limited. My thoughts would be to call @A-Z Tractor Lincoln. ... or give a call or email to isavetractors.com up here in Maine. Share this post Link to post Share on other sites
KC9KAS 4,744 #9 Posted April 17, 2018 @mikeeyre74 Try Del City electrical connections. They are called "Packard 56" series connectors. 1 1 Share this post Link to post Share on other sites
mikeeyre74 289 #10 Posted April 17, 2018 I checked Isavetractors and they have the Delphi 5 pin, but nothing else. The Delphi 3 pin is shaped like a pyramid, not like the L shape that the regulator requires. Share this post Link to post Share on other sites
doc724 925 #11 Posted April 17, 2018 Use the 4 position series 56 connector, just leave the unused position empty. That is what I used when I rewired my C125. Works perfectly 2 1 Share this post Link to post Share on other sites
