C-121uk 183 #1 Posted April 4, 2018 Hi all, we got a replacement clinton engine for my rj restoration and we have no idea how to wire a shut off switch to the engine. Any help will be gratefully appreciated Share this post Link to post Share on other sites
WHX?? 58,226 #2 Posted April 4, 2018 On the back side of the bearing plate there should be a small nylon block with a wire on it coming from the points under the flywheel. If you ground that wire out it will kill the engine. You can run that wire to a kill switch somewhere or as I did make a small piece of spring clip like thingy mounted on the nylon block to push to ground points much like a Kohler. Kinda hard to describe but don't have a pic but will get one. Not sure how the original kill button was. 1 Share this post Link to post Share on other sites
C-121uk 183 #3 Posted April 4, 2018 Thanks, we'll have a look, a picture would be good if you could get one Share this post Link to post Share on other sites
WHX?? 58,226 #4 Posted April 4, 2018 No problem ..will get one when I get home tonite..... that pic will speak a thousand words. 1 Share this post Link to post Share on other sites
WHX?? 58,226 #5 Posted April 5, 2018 Couple of pics here buddy on what I did for a kill switch. Switch thingy is just a piece of copper trimmed to form a spring. This is on a Clinton B1290 on a very eary 1960 Suburban .....May not be correct but worked. Hope this helps. Share this post Link to post Share on other sites
C-121uk 183 #6 Posted April 6, 2018 6 hours ago, WHX16 said: Couple of pics here buddy on what I did for a kill switch. Switch thingy is just a piece of copper trimmed to form a spring. This is on a Clinton B1290 on a very eary 1960 Suburban .....May not be correct but worked. Hope this helps. Thanks for that Jim, we'll have a look this weekend Share this post Link to post Share on other sites
wallfish 20,639 #7 Posted April 6, 2018 There's a hole in the hood below the throttle lever for a switch.(if the hood wasn't cut off) Run that wire from the coil to a switch which grounds the connection to the hood. They can be found on epay as chainsaw switch. 2 Share this post Link to post Share on other sites
WHX?? 58,226 #8 Posted April 6, 2018 54 minutes ago, wallfish said: found on epay as chainsaw switch. Thanks 'fish was looking for one of those.... would have never guessed for a saw. Share this post Link to post Share on other sites
