bmsgaffer 2,071 #1 Posted April 2, 2018 Hey everyone! Been just lurking for a few months as life got busy (and cold!). I am looking to make a "spring machine" out of one of my 854's. My yard (as most everyones) turns to a swamp this time of year, and I am looking to make a tractor that will just float on top. My 522xi, which has big tires, definately does NOT float coming in around 1100lbs without weights. I think the 854 is closer to 450lbs dry, and so if I can give it a super wide footprint it will do a lot less damage to the turf. I know i can throw some 23x10.5-12's on the back of it with the set of rims I have, but I am wondering about the fronts. Has anyone put larger tires on the front spindles? Probably looking like 16x7.5-8 or so (the standard ones for the bigger machines). Will I need bigger spindles? Is that too much tire for the steering components? I will be pulling a sweeper, roller, spreader, trailer, etc... Thanks for the help! Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #2 Posted April 2, 2018 I passed this machine onto another member here but here was my 854 with big tires out back. I loved the look! 6 1 Share this post Link to post Share on other sites
bmsgaffer 2,071 #3 Posted April 2, 2018 @stevebo I agree. I love the look! With tires that wide it will be softer than walkin on the grass. Now if I can just figure out the fronts! I can decide if I am going with Turfs or another set of my TerraTrac K502s that I am running on my 522xi. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #4 Posted April 2, 2018 Brandon- The rears are off a 520 with 10.50's. The fronts I love the look of the tri ribs. I have 4.80 and 3.50's on other machines. I like the look of the 3.50's 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #5 Posted April 2, 2018 You should be able to use any of the wider 8" wheels off of later models for the front end. They use the same 3/4" spindle and should just swap over. Randy 1 Share this post Link to post Share on other sites
bmsgaffer 2,071 #6 Posted April 2, 2018 Just now, RandyLittrell said: You should be able to use any of the wider 8" wheels off of later models for the front end. They use the same 3/4" spindle and should just swap over. Randy I had not yet measured, so I wasn't sure if the spindles were longer or not on the later models. That is helpful, thank you! Share this post Link to post Share on other sites
RandyLittrell 3,944 #7 Posted April 2, 2018 Here is a pic of my C-120 for example. 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #8 Posted April 2, 2018 4 minutes ago, bmsgaffer said: I had not yet measured, so I wasn't sure if the spindles were longer or not on the later models. That is helpful, thank you! I believe they may attach in a different manner, but the hub of the wheel itself, should be the same. The wheels from my cub cadet will even work. Randy Share this post Link to post Share on other sites
AMC RULES 37,256 #9 Posted April 2, 2018 Ever see this... start about the 9:50 mark here. 1 Share this post Link to post Share on other sites
bmsgaffer 2,071 #10 Posted April 2, 2018 37 minutes ago, AMC RULES said: Ever see this... start about the 9:50 mark here. I had not seen that before! (i usually avoid the mud mower videos as they are sometimes painful to watch!) For a mud mower, he did an alright job though.... Still hurts... Thanks! Share this post Link to post Share on other sites
slim67 2,825 #11 Posted April 3, 2018 15 hours ago, bmsgaffer said: Hey everyone! Been just lurking for a few months as life got busy (and cold!). I am looking to make a "spring machine" out of one of my 854's. My yard (as most everyones) turns to a swamp this time of year, and I am looking to make a tractor that will just float on top. My 522xi, which has big tires, definately does NOT float coming in around 1100lbs without weights. I think the 854 is closer to 450lbs dry, and so if I can give it a super wide footprint it will do a lot less damage to the turf. I know i can throw some 23x10.5-12's on the back of it with the set of rims I have, but I am wondering about the fronts. Has anyone put larger tires on the front spindles? Probably looking like 16x7.5-8 or so (the standard ones for the bigger machines). Will I need bigger spindles? Is that too much tire for the steering components? I will be pulling a sweeper, roller, spreader, trailer, etc... Thanks for the help! 18 x 8.50-8s are what your looking for. Thats the size golf carts run. The spindles should be fine. Share this post Link to post Share on other sites
Herder 2,355 #12 Posted April 6, 2018 On Monday, April 02, 2018 at 2:54 PM, stevebo said: I passed this machine onto another member here but here was my 854 with big tires out back. I loved the look! Looks awesome!!!!! Share this post Link to post Share on other sites
