953 nut 59,705 #26 Posted March 20, 2018 9 minutes ago, JERSEYHAWG / Glenn said: Please Lord, lets just get through this storm. For the time being you will probably want to use the new "C" Clips, keep in mind that they are stamped steel and the rounded side should face toward the wheel so the sharp side can grip the groove on the spindle shaft. 5 2 Share this post Link to post Share on other sites
WHX?? 51,683 #27 Posted March 20, 2018 Or you could just clamp a vise grips on it to get you by this storm. What's with all these storms you easties are seeing .... if Ed @Ed Kennell took off his snow equipment like he was supposed it would be spring! 2 2 Share this post Link to post Share on other sites
roadapples 6,983 #28 Posted March 20, 2018 at least 1/8 maybe even 3/16" pin... 2 Share this post Link to post Share on other sites
ronhatch 406 #29 Posted March 20, 2018 (edited) 3/8" NF is OK too, just make sure you use the proper size drill bit. I'm thinking it's a numbered bit, but don't know it off the top of my older then dirt head. Just use plenty of cutting oil when taping the threads. IMHO; I'd go with a 5/32" cotter pin. Edited March 20, 2018 by ronhatch 3 Share this post Link to post Share on other sites
pfrederi 18,628 #30 Posted March 20, 2018 4 minutes ago, ronhatch said: 3/8" NF is OK too, just make sure you use the proper size drill bit. I'm thinking it's a numbered bit, but don't know it off the top of my older then dirt head. Just use plenty of cutting oil when taping the threads. 3/8 nc 5/16" driil 3/8 NF Q drill 3 1 Share this post Link to post Share on other sites
WHX?? 51,683 #31 Posted March 20, 2018 (edited) I think he is going the cotter pin route Ron. If you are Glenn you should be able to do it right on the tractor. Edited March 20, 2018 by WHX14 3 Share this post Link to post Share on other sites
Ed Kennell 41,762 #32 Posted March 20, 2018 1 hour ago, WHX14 said: What's with all these storms you easties are seeing .... if Ed @Ed Kennell took off his snow equipment like he was supposed it would be spring! Didn't have to Jim. Just the threat was enough to make it snow. And BTW, Spring has arrived. 4 Share this post Link to post Share on other sites
wallfish 18,033 #33 Posted March 20, 2018 (edited) 9 hours ago, Mike'sHorseBarn said: Personally, I don't have the equipment to drill and tap the end of the spindles nicely and I prefer the look of the bolt rather than cotter pin so I would find good used spindles from an earlier C series to swap with your tractor. Just my preference. Just a hand drill and you can use small adjustable wrench for the tap. You can buy a tap with the correct drill bit at HD , Lowes or any good hardware store or order online. This application doesn't need to be exact perfect and it's a fairly simple process. WAAAAAY cheaper and easier than finding and replacing spindles. You can even do it with the wheels on the spindles. https://www.amazon.com/Vermont-American-21669-16-inch-Drill/dp/B000BQW6F0/ref=sr_1_7?ie=UTF8&qid=1521583961&sr=8-7&keywords=5%2F16+drill+tap Edited March 20, 2018 by wallfish 5 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #34 Posted March 21, 2018 4 hours ago, WHX14 said: No Glenn they are not hardened at all and will drill like butter. Center punch & use a good sharp drill bit. Ok, thanks......good news. Glenn 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #35 Posted March 21, 2018 4 hours ago, WHX14 said: I think he is going the cotter pin route Ron. If you are Glenn you should be able to do it right on the tractor. Yep, the cotter pin route is it. Glenn 3 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #36 Posted March 21, 2018 1 hour ago, wallfish said: Just a hand drill and you can use small adjustable wrench for the tap. You can buy a tap with the correct drill bit at HD , Lowes or any good hardware store or order online. This application doesn't need to be exact perfect and it's a fairly simple process. WAAAAAY cheaper and easier than finding and replacing spindles. You can even do it with the wheels on the spindles. https://www.amazon.com/Vermont-American-21669-16-inch-Drill/dp/B000BQW6F0/ref=sr_1_7?ie=UTF8&qid=1521583961&sr=8-7&keywords=5%2F16+drill+tap This idea is worth re visiting though. I need to put some study on it. All the suggestions are much appreciated to. Tomorrow is shaping up to be a battle royal. Glenn 3 Share this post Link to post Share on other sites
ronhatch 406 #37 Posted March 22, 2018 " I prefer the look of the bolt rather than cotter pin." There should small caps that fit over the rim hub to hide and protect whatever method you choose to go with. There is a guy on this site that sells plastic caps for that purpose. I'm sure someone will chime in with his information. On my C101, I used $0.69, 1 1/4" (?) PVC water pipe caps from HD. They look great after I painted them red. They were a little loose, so I wrapped a couple of turns around the rim hub with good old duck tape to make up the small difference in diameter. That was 3 years ago. "Necessity is the mother of invention!" 2 Share this post Link to post Share on other sites
ebinmaine 72,316 #38 Posted March 22, 2018 11 minutes ago, ronhatch said: On my C101, I used $0.69, 1 1/4" (?) PVC water pipe caps from HD. Nice idea there... 1 1 Share this post Link to post Share on other sites
tarcoleo 119 #39 Posted March 22, 2018 I have two modified "C" chassis both equipped with 3/4" split shaft collars to secure wheels on front spindles. Work really well. Simple to do. 1 1 Share this post Link to post Share on other sites
diesel cowboy 263 #40 Posted March 22, 2018 On 3/20/2018 at 1:34 PM, pfrederi said: Guys I thought my mind was going so I just went out and looked at my old Dodge (its an M-37 but was made by Dodge) The Left Hand threaded lugs are on the driver side (left). Edit: Don't see much marked hardware anymore like on her. 2 of the initials are long gone now...sad First time I ran into the left hand thread wheel bolts was on one of the cars listed on that bolt head. Drove me nuts being all of 13 at the time and not knowing that was how they used to make them. IH used to mark all their bolts like that too. I agree with it being sad that 2 of the initials being gone now. They were both great cars. I have 3 of the DeSoto's 2 for parts and 1 almost complete that I've driven. Even at almost 70 years old its a smooth ride and that Fluid Drive shifts so you can barely feel it. 3 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #41 Posted March 22, 2018 1 hour ago, tarcoleo said: I have two modified "C" chassis both equipped with 3/4" split shaft collars to secure wheels on front spindles. Work really well. Simple to do. Could I see a picture of that please? When you can. No rush. Thanks, Glenn Share this post Link to post Share on other sites
tarcoleo 119 #42 Posted March 23, 2018 JERSEYHAWG/Glenn https://www.rollerchain4less.com/Double-Split-Set-Collar-34-Shaft-Collar_p_1415.html?gclid=EAIaIQobChMIw4-M__WC2gIVWFmGCh2fLgK6EAYYByABEgIDFPD_BwE 2 Share this post Link to post Share on other sites
Tankman 3,523 #43 Posted March 23, 2018 On 3/20/2018 at 3:43 PM, WHX14 said: No Glenn they are not hardened at all and will drill like butter. Center punch & use a good sharp drill bit. Easy enough but, drill, stop, drill, stop. Just a second or so on the drill bit. Keep clearing the chips out. Of course keep some thrust washers (http://qbcbearings.com/BuyRFQ/ThrustB_Washer_SL_SB_I.php) handy to minimize wheel lateral movement. 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #44 Posted March 24, 2018 3 hours ago, Tankman said: Easy enough but, drill, stop, drill, stop. Just a second or so on the drill bit. Keep clearing the chips out. Of course keep some thrust washers (http://qbcbearings.com/BuyRFQ/ThrustB_Washer_SL_SB_I.php) handy to minimize wheel lateral movement. Tank, what size would work? Good idea. I like the quality. Glenn Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #45 Posted March 24, 2018 6 hours ago, tarcoleo said: JERSEYHAWG/Glenn https://www.rollerchain4less.com/Double-Split-Set-Collar-34-Shaft-Collar_p_1415.html?gclid=EAIaIQobChMIw4-M__WC2gIVWFmGCh2fLgK6EAYYByABEgIDFPD_BwE Wow nelly, now that is some idea to put on that spindal. Did you ever try these? This is a handy idea. Thanks. I like the way they cinch uo to. Would the size you showed work on my spindal? Glenn Share this post Link to post Share on other sites
Tankman 3,523 #46 Posted March 24, 2018 (edited) 1 hour ago, JERSEYHAWG / Glenn said: Tank, what size would work? Good idea. I like the quality. Glenn The ID axle OD dimension. The OD (outside dimension) same as your rim's bearing housing (or close). Example shown. Thrust washer thickness depends on how much lateral movement you have; i.e.: 1/16" lateral movement? 1/16" thick thrust washer. I have installed numerous thrust washers on front axles but, without measuring, forget the sizes. QBC Bearings is quick delivery and reasonably priced. The '90 520-8 I restored needed thrust washers, works great when I installed thrust washers. Zero wheel play and keeps grease in, dirt out. I have 'em on both sides of the rims if needed. Edited March 24, 2018 by Tankman 1 1 Share this post Link to post Share on other sites
tarcoleo 119 #47 Posted March 24, 2018 The split shaft collar shown can be put one the spindle directly, with a washer. Yes, as I said, my WH's have been so equipped. And you might consider replacing the junk bearings with heavy duty roller bearings. More if interested. 1 Share this post Link to post Share on other sites
ronhatch 406 #48 Posted March 24, 2018 tarcoleo; Yes, interested! What kind and size of (tapered?) roller bearing will take the place of the 1 3/8" OD X 3/4" ID junk ball bearings? 1 Share this post Link to post Share on other sites
Tankman 3,523 #49 Posted March 25, 2018 (edited) 12 hours ago, ronhatch said: tarcoleo; Yes, interested! What kind and size of (tapered?) roller bearing will take the place of the 1 3/8" OD X 3/4" ID junk ball bearings? These bearings work fine if, greased and cleaned. Normal regular PM (preventative maintenance). http://www.partstree.com/parts/toro/parts/110513/ Edited March 25, 2018 by Tankman Share this post Link to post Share on other sites
wallfish 18,033 #50 Posted March 25, 2018 5 hours ago, ronhatch said: tarcoleo; Yes, interested! What kind and size of (tapered?) roller bearing will take the place of the 1 3/8" OD X 3/4" ID junk ball bearings? Believe he's referring to these type. They're not tapered but roller bearings for the 3/4 spindle straight shaft x 1 3/8 OD 1 1 Share this post Link to post Share on other sites
