Joshn569 273 #1 Posted March 16, 2018 What should the piston to cyl clearance be for .20 oversized? Share this post Link to post Share on other sites
953 nut 63,922 #2 Posted March 16, 2018 This will give you all the specs. Kohler Single Cylinder Engine Specs _ Torque Values and Sequences for Fasteners _ Identification & Torque Settings of Most Commonly Used Grades of Bolts (1).html 1 1 Share this post Link to post Share on other sites
Joshn569 273 #3 Posted March 16, 2018 .007 - .010" Just seems like a lot, the service manual i downloaded says that also. Just wantes be sure. Thanks👍 @953 nut Share this post Link to post Share on other sites
Cvans 1,009 #4 Posted March 16, 2018 53 minutes ago, Joshn569 said: Just seems like a lot, the service manual i downloaded says that also. Just wantes be sure. The aluminum piston will expand a lot more than the cylinder when the engine gets to operating temperatures. When that happens your clearance will be a lot less. 3 Share this post Link to post Share on other sites
lynnmor 8,547 #5 Posted March 16, 2018 12 hours ago, Joshn569 said: .007 - .010" Just seems like a lot, the service manual i downloaded says that also. Just wanted be sure. Thanks👍 @953 nut Be sure you measure at the specified location. I too, think that it is a lot of clearance, but maybe measured at various locations you might find different readings. Share this post Link to post Share on other sites
redone 45 #6 Posted March 16, 2018 I am searching for one good exhaust valve for a k241 10 Thanks Bill Share this post Link to post Share on other sites
Fordiesel69 271 #7 Posted March 16, 2018 Do not use the book to bore, the pistons today are NOT in spec at all. Bore with about 0.0045 for the style D Mahle and about 5ish on the heavy side for the regular style A. Share this post Link to post Share on other sites
