Countdown To Christmas!
69-Raider-10
HELP!! Bronco 14 not starting and its snowing heavy!
eddiebunyan
I had the same problem with my Bronco years ago.If I hadn't started it for a while(say a week or so) she would just crank and crank.I found that if I took the plug out,put some gas in the cylinder and reinstalled the plug it would fire and run then die! Put gas in the plug hole a second time and it would fire and run fine.Somehow my fuel pump was drainig back to the filter(had to be losing the vacume in the line somewhere) causing fuel starvation.If I started it often I had no problem,just long periods between stars.Always worked for me and most times only took filling spark plug hole once!Just relating my experiance.
