Team70R
C120 belt and guard
Team70R
I've got a c120 8 speed that started it's life as a work horse 800. I'm having a hard time finding the correct belt and getting the belt guard  to fit. Did the real C120 have a different belt guard than the 800?
ebinmaine
I don't have the answer for you but maybe call A - Z  Tractor ?
ditchdigger25
If you go to partstree.com they have the parts break down for those tractors it looks like different parts numbers.
Ed Kennell
Does this picture of my C-120 help?
  • Like 4
wallfish
Pretty sure the Work Horse 800 is a small frame tractor and the C120 is definitely a long frame.
A work Horse 800 had a Tecumseh engine which makes the little tab on the 800 belt guard to hold it to the engine different than that of a Kohler powered tractor. Which belt guard are you using, 800 or 120?
Make a little flat brace with 2 holes to span the gap and hold the belt guard.
Use an old mower deck belt to wrap around the pulleys and idler to measure the belt length.
It seems like you're putting together a tractor from different parts so how about posting some pics so we can see what's going on.
  • Like 4
peter lena
belts are not a simple swap, I have found my local (  bearing distributor  ) to be the best help in belt info. bring in what you have and match it up, you can always bring it back  (  without usage  ) and get it spot on. another thing I have found is that with the w/h belts ,they  tend to be a little long, making the fit even at the end of adjustment , loose. by the way that will not allow the implement driven to get up to speed. inside and outside belt dimensions differ, I prefer the shorter belt , giving me more adjustment at the mule drive. I have also changed up to Kevlar belts, actually cheaper than o/e belts, internet. they have a much more solid drive function. pete
Team70R
It's the belt guard from the 800. I did some modifying of it last night but can't get it to release the belt all the way when I clutch it. I'll have to get some pics tonight
Ed Kennell
Please understand,  the lower flange on these belt guards acts as a necessary support for the belt when the clutch is disengaged.  If the belt is allowed to sag, it will contact the engine drive pulley and continue to move. and  turn the transmission drive pulley making it impossible to shift gears w/o grinding.
  • Like 5
953 nut
As Ed said, the lower portion is very important for stopping the belt when the clutch has been depressed. If you are unable to come up with a ready made belt guard that will meet your needs you could use an angle iron above and below the upper and lower portions of the belt attached to the engine and frame/transaxle securely. The opening could be closed with sheet metal which could be welded or riveted in place.
Team70R
Been fighting a cold and didn't get a chance to get any pics. I had it clutching okay until I lowered the belt guard a hair. I'll raise it back up and see if that fixes it.. I've been looking to build a belt guard for a different horse. That's a great idea on how to do it!!
Team70R
Weather has been super crappy all week and I haven't had much time to work on it unfortunately
  • Similar Content
    • Charles99
      By Charles99
      ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • Chuck14025
      By Chuck14025
      C120, 1974/75
      I added braces and shims to the rear end of the frame to beef up the cracked existing 'frame to transmission bracket'. Now, the parking brake does not engage.
      The shims are about 1/8" and have to stay on.
      Is there a way to adjust the parking brake?
    • seven
      By seven
      Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
