wallfish 20,700 #1 Posted February 15, 2018 Posted this a while back over on My Old Machine and thought others here would also be interested. Wish I could find one to go in my chainsaw tool and attachment collection. Bet it needs a REAL good air filter. 11 Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted February 15, 2018 I really don't believe that I would have the nerve to use that.....whooa... 2 2 Share this post Link to post Share on other sites
jajiu 55 #3 Posted February 15, 2018 He must not have a shovel, or a back hoe. 1 Share this post Link to post Share on other sites
shallowwatersailor 3,222 #4 Posted February 15, 2018 Here is a Purpose-built trencher using a saw. The trouble is it is only for low-voltage wiring. Line voltage, according to the NEC, needs to be direct buried 24" deep, 18" in a conduit, or 12" with a layer of concrete. 4 Share this post Link to post Share on other sites
ztnoo 2,302 #5 Posted February 15, 2018 I didn't get a real good look at the cutters, but it almost looked like a hand held trencher, with fairly narrow width teeth. That could be real handy in burying wires and cables in tight spaces and where short runs are needed, where a regular trencher either couldn't get into the site or space, or was way more machine than needed for the job. As long as you could be reasonably assured there wasn't solid rubble or any live electric service buried in the path, doesn't seem like that big a deal to me to use. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #6 Posted February 16, 2018 I am not sure I would want to use that. Looks like a easy way to loose a leg. Wonder what happens when you hit a big old rock or block of concrete ? 2 Share this post Link to post Share on other sites
roadapples 6,987 #7 Posted February 16, 2018 52 minutes ago, elcamino/wheelhorse said: Wonder what happens when you hit a big old rock or block of concrete ? Wouldn't use that at my place, way too Rocky... 1 Share this post Link to post Share on other sites
Daddy Don 912 #8 Posted February 16, 2018 Easy way to make a flower garden Share this post Link to post Share on other sites
Sarge 3,473 #9 Posted February 16, 2018 I ran Ditch Witch and Vermeer vibratory plows for a lot of years as well as the trenchers - no way I'd try that with a handheld machine of any sort unless it has some sort of limiting clutch, without one that could hurt a lot. We found old car bumpers ('53 Buick) and various other things with those plow blades over the years and now and then some vintage glass would appear coming out at the top in one piece, oddly. The vibratory units were great, just a quick knife cut and the cable runs through a slot in the blade with a removable shoe - I could crab steer the plow back over the raised 1' portion on either side of the cut on the return pass and you couldn't hardly find the mark when we were done. We put in miles of CATV, electrical lines, conduit runs and phone on different contracts and traveled quite a lot across several states - finally got sick of being away and living in motels most of the time so I was out, had a wife and baby at home to look after. Those old Ditch Witches could be ran on their side as long as the blade stayed in the ground but it barrel roll one down an embankment when I hit a sand pocket - I got lucky by bailing and let the machine go early enough to get only some scratches - we had one guy killed in northern Iowa the last year I worked. Nothing fun about hitting rocks with any type of soil cutting teeth - it can cause a 12,000lb machine to take off skyward and walk itself on the trencher bar if you didn't jump on the clutch fast enough. I would think those hand held units have to have some sort of safety clutch - maybe not... Sarge 1 Share this post Link to post Share on other sites
Jerry77 1,218 #10 Posted February 16, 2018 18 hours ago, ztnoo said: doesn't seem like that big a deal to me to use. Ok....you can take my turn.... 1 Share this post Link to post Share on other sites
wallfish 20,700 #11 Posted February 16, 2018 4 hours ago, Sarge said: barrel roll one down an embankment I rolled a couple down some hills. We used to travel around building underground CATV plants. They were always rentals with insurance. Always hated doing trench work but running the pneumatic mole was kind of fun. Sometimes you never know where that thing could accidentally pop up. 1 Share this post Link to post Share on other sites
953 nut 69,914 #12 Posted February 16, 2018 Looking at that thing makes me think of the Charles Darwin Award. So how are the Darwin Awards actually determined? Nominees significantly improve the gene pool by eliminating themselves from the human race in an obviously stupid way. They are self-selected examples of the dangers inherent in a lack of common sense, and all human races, cultures, and socioeconomic groups are eligible to compete. Share this post Link to post Share on other sites
Pullstart 71,441 #13 Posted February 20, 2018 Look'it all that PPE! 1 Share this post Link to post Share on other sites
