Pullstart 71,561 #101 Posted March 10, 2021 1 hour ago, WHX24 said: In my quest for front end parts for a '61 or 62 looks like that tractor has got full length tie rods instead of only one Kev. That would mean it has the triangle plate welded to the lower shaft and no drag link. I woulda thought that it would have shared the same front end parts as a say a 702? Which is just a single short tie rod and drag link. Your steering gear looks '63 ish. I need to look at the IPL for a 502 I guess. My ‘62 tractor has a ‘64 frame, ‘78 trans and rear wheels, and an air compressor engine 1 Share this post Link to post Share on other sites
WHX?? 58,387 #102 Posted March 10, 2021 Might have figured a franken dinglenuts... I can't believe you actually had me in a furrow with that mutt! ... It's all good! 1 1 Share this post Link to post Share on other sites
Pullstart 71,561 #103 Posted March 10, 2021 9 hours ago, WHX24 said: Might have figured a franken dinglenuts... I can't believe you actually had me in a furrow with that mutt! ... It's all good! Arrrfff arrfff! Other than the little steering hiccup we talked about, he’s chompin’ at the bit to pull plow again! 2 Share this post Link to post Share on other sites
Pullstart 71,561 #104 Posted March 10, 2021 (edited) I noticed yesterday’s trail ride gave me about 1/4 turn of steering slop in the wheel under certain conditions of field operations. The roll pin in the fan gear was a bit shorter than it should be. Good to go now, ‘cept I’m sure Uncle Jim will flame me for using the WHRat’s hood for a work bench! Edited March 11, 2021 by pullstart 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #105 Posted March 11, 2021 The horror... You didn’t scratch the paint did you? 2 Share this post Link to post Share on other sites
Pullstart 71,561 #106 Posted March 11, 2021 52 minutes ago, SylvanLakeWH said: The horror... You didn’t scratch the paint did you? Not any more than I normally would 1 3 Share this post Link to post Share on other sites
Pullstart 71,561 #107 Posted July 29, 2021 On 3/16/2018 at 8:27 AM, pullstart said: I cut the hood repair panel out of a box store yard cart/trailer tailgate that was dropped off for my scrap pile, then trimmed it to fit between the frame rails and rest on the edges of the angle iron. in reference to the lack of pictures in 2018... here are some more front hood mounting tab details. 1 1 Share this post Link to post Share on other sites
Pullstart 71,561 #108 Posted September 28, 2022 It was great to hear Putt Putt fire up last night! He hasn’t run since 2020, when he abruptly shut off. After a points cleaning and re-gap, I figured that K-181 would pop right to life but still no go. I cleaned the spark plug but my spark was weak and intermittent. I swapped out the JC6 plug for an H10C (?) and it was off to the races! 1 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #109 Posted September 28, 2022 1 minute ago, Pullstart said: swapped out the **** plug I've had the exact same thing happen multiple times over the years. Most recently, we were running the Wallyho which is a Magnum 16 and it just quit. Dead. Nothing. It would turn over like it was meant to do so but not even a dream of fire in that engine. I dropped a new H10C in there and it roared right to life. 2 Share this post Link to post Share on other sites
WHX?? 58,387 #110 Posted September 28, 2022 Shouldn't it have a JC8 or equal in it Kev? Thought all small blocks did and bigs are H10? 1 Share this post Link to post Share on other sites
Pullstart 71,561 #111 Posted September 28, 2022 On 9/28/2022 at 8:01 AM, WHX?? said: Shouldn't it have a JC8 or equal in it Kev? Thought all small blocks did and bigs are H10? Couldn’t tell ya! It always ran great with the JC6… until it didn’t. I grabbed another plug out of another small block engine on the shelf and it fired right up. Share this post Link to post Share on other sites
WHX?? 58,387 #112 Posted September 28, 2022 Maybe someone else can verify this then. I think a 6 is real close in heat range to an 8 1 minute ago, Pullstart said: I grabbed another plug out of another’s all block engine on the shelf and it fired right up. Done that many times to keep from going bald. Share this post Link to post Share on other sites
Lane Ranger 12,167 #113 Posted September 28, 2022 38 minutes ago, Pullstart said: It was great to hear Putt Putt fire up last night! He hasn’t run since 2020, when he abruptly shut off. After a points cleaning and re-gap, I figured that K-181 would pop right to life but still no go. I cleaned the spark plug but my spark was weak and intermittent. I swapped out the JC6 plug for an H10C (?) and it was off to the races! yes I read last time I changed a plug in my B-80 With 8 hp Kohler K-181 that Kohler says ok for use in K-181. I always thought the HC-10 was only for ten hp and above. 1 Share this post Link to post Share on other sites
Achto 32,962 #114 Posted September 28, 2022 13 minutes ago, WHX?? said: Shouldn't it have a JC8 According to the manual J8C is the correct plug. 2 Share this post Link to post Share on other sites
WHX?? 58,387 #115 Posted September 28, 2022 (edited) Of course Dan the rack at FF was empty of J8C AND coils.. so the 701 161 had to get used crap.... for now. I did read through the coil we replaced on the C-121 Dan and the secondary was way low so it got round filed. Edited September 28, 2022 by WHX?? 2 Share this post Link to post Share on other sites
Achto 32,962 #116 Posted September 28, 2022 1 hour ago, WHX?? said: Of course Dan the rack at FF was empty of J8C An RJ19LM is also a suitable plug for a small block Kohler. This is what I run in most of mine. They resist fouling a little better. 1 Share this post Link to post Share on other sites
WHX?? 58,387 #117 Posted September 28, 2022 Agreed Dan ... I found those plugs in many of my small blocks. Share this post Link to post Share on other sites
ebinmaine 81,278 #118 Posted September 28, 2022 2 hours ago, Achto said: This is what I run in most of mine. They resist fouling a little better Could you elaborate on why that is please? 41 minutes ago, WHX?? said: Agreed Dan ... I found those plugs in many of my small blocks. Us too. Small and big blocks. Share this post Link to post Share on other sites
Achto 32,962 #119 Posted September 28, 2022 12 minutes ago, ebinmaine said: Could you elaborate on why that is please? Champion changed something in the RJ19LM that is supposed to make the plug more resistive to fouling out. Haven't had one foul yet so maybe what ever they did works. 2 Share this post Link to post Share on other sites
Pullstart 71,561 #120 Posted September 28, 2022 Crazy. I was telling Jada about getting Putt Putt running last night. I looked at the picture of @PeacemakerJack’s clan here and it was Sept. 28, 2020. I got Putt Putt going randomly on Sept. 27, 2022 at around midnight! Shoulda procrastinated another day! 1 1 Share this post Link to post Share on other sites
WHX?? 58,387 #121 Posted September 28, 2022 6 hours ago, ebinmaine said: Could you elaborate on why that is I thought maybe it just ran a little hotter 1 Share this post Link to post Share on other sites
Howie 900 #122 Posted September 29, 2022 I think they are a slightly hotter plug. 2 Share this post Link to post Share on other sites
Pullstart 71,561 #123 Posted September 29, 2022 We’re a little pigeon toed here! 1 Share this post Link to post Share on other sites
Pullstart 71,561 #124 Posted September 29, 2022 One of the last times running, I was a little over a mile away from home and the roll pin broke out and was nowhere to be found. I ended up driving the tractor in reverse, me standing in the front hanging weight and kicking the tires to steer it home. I stuck a 1/4” bolt through but knew it was temporary. 2 years and some change later, I decided to pull it apart, clean it up and weld it. 1 Share this post Link to post Share on other sites
Pullstart 71,561 #125 Posted September 29, 2022 Something we can all agree on without anyone getting shunned, fresh Regal Red sure is pretty! 1 Share this post Link to post Share on other sites
