WNYPCRepair 1,924 #2 Posted January 22, 2018 (edited) 3 Edited January 22, 2018 by WNYPCRepair 2 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #3 Posted January 22, 2018 4 but I don't have a brain 2 Share this post Link to post Share on other sites
Chris G 3,370 #4 Posted January 22, 2018 (edited) I'll say cup 7 Edited January 22, 2018 by Chris G 2 Share this post Link to post Share on other sites
Racinbob 12,817 #5 Posted January 22, 2018 Sneaky Ed....but I like it. Cup 3. 2 Share this post Link to post Share on other sites
953 nut 64,391 #6 Posted January 22, 2018 None of them! That one drop of water won't even cover the bottom of # 1. If it is a continuous flow then # 5 would fill first. 2 1 Share this post Link to post Share on other sites
wallfish 19,416 #7 Posted January 22, 2018 If "filled firstly" means filled to the top. it's 5. 2 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #8 Posted January 22, 2018 1 hour ago, Ed Kennell said: 4, 5, 6 and seven wont be filled because some blocked pipes and holes that means 2 cant fill up either because it drains into 7 1 only drains into 3 and 3 is the only one with pipes attached that cant drain into others so i say ITS 3 4 5 Share this post Link to post Share on other sites
953 nut 64,391 #9 Posted January 22, 2018 4 minutes ago, C-101plowerpower said: 5, wont be filled because some blocked pipes I missed that. Share this post Link to post Share on other sites
Jerry77 1,218 #10 Posted January 22, 2018 # 3 will fill first (ly) Share this post Link to post Share on other sites
Ed Kennell 45,090 #11 Posted January 22, 2018 OK , goodywoodshoes explained it perfectly. All you guys that picked 3, take a bow, or maybe you just got lucky. all for playing. 2 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #12 Posted January 22, 2018 3 is the ONLY cup that will fill and run over! 1 Share this post Link to post Share on other sites
ebinmaine 77,597 #13 Posted January 23, 2018 1 hour ago, Ed Kennell said: OK , goodywoodshoes explained it perfectly. All you guys that picked 3, take a bow, or maybe you just got lucky. all for playing. Just found this and checked the diagram profusely. It bugged me that the bottom read "99% will fail" so my honey and I started looking carefully... We ended up with 3 as well. Good one!! Thanks for posting. 1 Share this post Link to post Share on other sites
wallfish 19,416 #14 Posted January 23, 2018 (edited) 2 hours ago, 953 nut said: I missed that. me too. 3 will fill Edited January 23, 2018 by wallfish 1 Share this post Link to post Share on other sites
Racinbob 12,817 #15 Posted January 23, 2018 Unless the faucet dumps water in it faster than the connecting tubes can drain it #2 would never get a drop in it before #3 fills up. 1 Share this post Link to post Share on other sites
roadapples 6,987 #16 Posted January 23, 2018 (edited) I hate these things. I don't see how 3 can get more than 1/2 full until after 5 fills.. nevermind , just saw the pipe going into 5 isn't.... Edited January 23, 2018 by roadapples 2 Share this post Link to post Share on other sites
JPWH 6,544 #17 Posted January 23, 2018 3 has a blocked pipe feeding 5. 2 Share this post Link to post Share on other sites
ebinmaine 77,597 #18 Posted January 23, 2018 4 minutes ago, roadapples said: I hate these things. I don't see how 3 can get more than 1/2 full until after 5 fills.. Mr apples, scroll up 'n read goodywoodshoes explanation 3 Share this post Link to post Share on other sites
Big_Red_Fred 1,548 #19 Posted January 23, 2018 I have a Headache, ok who made me think 2 2 Share this post Link to post Share on other sites
ebinmaine 77,597 #20 Posted January 23, 2018 6 minutes ago, Big_Red_Fred said: I have a Headache, ok who made me think I'm blaming Mr Kennell for this excursion and foray into thinkmindedness 1 1 1 Share this post Link to post Share on other sites
WHX?? 55,360 #22 Posted January 23, 2018 i'm thinkin Ed dug this up from his damn turbine days and changed the laws of phyics again..... without my say so! 1 Share this post Link to post Share on other sites
Ed Kennell 45,090 #23 Posted January 23, 2018 5 minutes ago, WHX14 said: i'm thinkin Ed dug this up from his damn turbine days and changed the laws of phyics again..... without my say so! Close Jim. Actually I saw this on facebook. After doing an in depth study of the inlet and outlet elevations of each cup and calculating the differential head pressure across each cup, determining rates of flow, I confidently selected #4. Then Mrs K glanced at the picture a few seconds and informed me cups 4,5,and 6 would not see a drop of water due to the blocked pipes and 2 and 7 would not hold water due to the hole in botton of #7. That leaves #3 as the only one that can fill up. I'll still wear my favorite Tee Shirt though. 3 Share this post Link to post Share on other sites
WHX?? 55,360 #24 Posted January 23, 2018 Ok Ed now you asked for it ... How much water we talking here GPM .....whats the size of the pipes ...flow rates... cup volumes,... discharge rates? Lets crunch some numbers..... second thought lets notI do enough of that at work! Share this post Link to post Share on other sites
Ed Kennell 45,090 #25 Posted January 23, 2018 15 minutes ago, WHX14 said: ..... second thought lets not 1 Share this post Link to post Share on other sites
