953 nut 70,076 #23751 Posted June 1, 2025 8 hours ago, ineedanother said: kinda like a bunch of conversations at the dinner table, or at the bar I didn't know people still had conversations at the dinner table, thought it was all texting. BUT, if there were conversations it would go like this; How was your date . . . She was boring . . . Yes, I had the cylinder bored 30 over . . . 30, he doesn't look a day over 12 . . No, it ain't noon yet, its only 11 7 Share this post Link to post Share on other sites
WHX?? 58,328 #23752 Posted June 1, 2025 @ineedanother Right!?!?! We were just discussing your bearing madness on a 1045 I have. Split the cases or shove the bearing in. Concerns about the axles being good on the bearing surface and the fact that the manufactures recommend the bearings be pressed in. I have pounded them in before I knew any better. 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #23753 Posted June 1, 2025 Strictly “preservation paint” … not a restoration whatsoever. 11 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #23754 Posted June 1, 2025 Although I did mask off the decals … 9 1 Share this post Link to post Share on other sites
HyperPete 943 #23755 Posted June 1, 2025 1 hour ago, Sparky said: Although I did mask off the decals … How do you mask them so neatly? I tried trimming the edges with an Exacto knife, but i could not really see the label through the painters tape, raised label to thin to help. Thanks! 2 Share this post Link to post Share on other sites
ineedanother 2,885 #23756 Posted June 1, 2025 3 hours ago, WHX?? said: @ineedanother Right!?!?! We were just discussing your bearing madness on a 1045 I have. Split the cases or shove the bearing in. Concerns about the axles being good on the bearing surface and the fact that the manufactures recommend the bearings be pressed in. I have pounded them in before I knew any better. I drove the old one in first rather than pushing it with the new one. I was able to get a good look a the condition of the axle which was fine. The wall thickness of the driver matched the bearing really closely and I made sure the end was flat and smooth. A bit of Lucas assembly grease and it tapped in with little resistance. I actually prefer it now over sliding the case on with the bearing pressed in. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #23757 Posted June 1, 2025 37 minutes ago, HyperPete said: How do you mask them so neatly? I tried trimming the edges with an Exacto knife, but i could not really see the label through the painters tape, raised label to thin to help. Thanks! I did what you just said. I laid the tape right on the top and bottom edge of the decal so I only had to trim 2 sides. It’s far from perfect, but good enough for me. 3 Share this post Link to post Share on other sites
ineedanother 2,885 #23758 Posted June 1, 2025 1 hour ago, ineedanother said: I drove the old one in first rather than pushing it with the new one. I was able to get a good look a the condition of the axle which was fine. The wall thickness of the driver matched the bearing really closely and I made sure the end was flat and smooth. A bit of Lucas assembly grease and it tapped in with little resistance. I actually prefer it now over sliding the case on with the bearing pressed in. @WHX?? Someone else had actually mentioned doing this before, maybe @kpinnc, I can't remember. When I looked at how much space is between the inner and outer bearings, it just makes sense if there's no other reason to split the case. 3 Share this post Link to post Share on other sites
ebinmaine 81,049 #23759 Posted June 1, 2025 4 minutes ago, ineedanother said: @WHX?? Someone else had actually mentioned doing this before, maybe @kpinnc, I can't remember. When I looked at how much space is between the inner and outer bearings, it just makes sense if there's no other reason to split the case. 1 hour ago, ineedanother said: I was able to get a good look a the condition of the axle which was fine ^^^^^ This is key. 1 Share this post Link to post Share on other sites
Damien Walker 297 #23760 Posted June 1, 2025 On 5/22/2025 at 1:24 PM, Pullstart said: Nice work! When I did mine, I turned that rod end on the smart steer 90 degrees, drilled a hole in the frame side and snugged it up. I used the convenient (but rather large) close by hole in the chassis which I filled with a large penny washer to centralise the new bolt. Smart Steer seems like a great idea but I think it needed a bit more development...it needs to be less effective. In electronic terms, it needs less 'gain'...in mechanical terms, it needs a shorter bell crank! I'm not sure how I'd do it but it's asking for an electronic solution....we could then have variable or adjustable Smart Steer (a bit like the probably over complex systems on my Range Rover!). If anything comes of my foray into fantasy land, I'll write it up here! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #23761 Posted June 1, 2025 Finally mowed with the 520-8 today. She did well! 11 3 Share this post Link to post Share on other sites
kpinnc 19,036 #23762 Posted June 1, 2025 (edited) 23 minutes ago, Sparky said: Finally mowed with the 520-8 today. She did well! That is one sharp machine Mike. I'm glad you were able to repurpose it! Now you need to have Terry make up some "510-8" stickers! Edited June 1, 2025 by kpinnc 1 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #23763 Posted June 1, 2025 3 minutes ago, kpinnc said: Now you need to have Terry make up some "510-8" stickers! Tempting …but I have a Mag 14 here that might move onto the 520 frame now that I have all the wiring and whatnot straight. 3 1 Share this post Link to post Share on other sites
Damien Walker 297 #23764 Posted June 1, 2025 On 5/30/2025 at 2:52 PM, Racinbob said: Another thing I'd like to replace is the 'fat' steering wheel. She said she likes the feel. I'm here typing this so obviously I refrained from comment. The 'fat' steering wheels have alloy bushes over here....I assume they are similar in the States. I have two 518Hs both with fat wheels and the bushes have distorted with use and the wheels become loose on t...he shaft. I cannot comment on how they got in that state as I bought them both as wrecks...'ghastly' would describe them though. I have rebuilt one of these tractors and fitted power steering so the 'fat' style wheel doesn't make sense as hydrostatic steering systems do not retain their centre. Consequently, I replaced my wheel with a C Series 3 spoke wheel....ok so it's 'thin', but it is otherwise a very nice wheel...and is bushed in steel. 3 Share this post Link to post Share on other sites
ebinmaine 81,049 #23765 Posted June 1, 2025 .... I started with coffee as any sane person should. Loaded the car for the transfer station. Moved a load of firewood from down back to up front. Went to the transfer station. Decided to chip some bark and sticks. PTO disc went bad. Fixed that with an NOS disc from stock. Did the chipping. Then resting. Then more chipping of branches. Now resting a bit. Then .....?? 5 4 Share this post Link to post Share on other sites
ML3 2,557 #23766 Posted June 1, 2025 (edited) Girlfriend & my mom spent most of day out shopping, flea markets, etc. So..... I had time to get the recoil fixed & hopefully the idle surging on the RJ. Also got yard mowed/trimmed. Made time to get the hit/miss engines started too. Plenty beers consumed as well! Edited June 1, 2025 by ML3 2 10 Share this post Link to post Share on other sites
squonk 48,288 #23767 Posted June 1, 2025 On 5/30/2025 at 9:52 AM, Racinbob said: Another thing I'd like to replace is the 'fat' steering wheel. She said she likes the feel. I'm here typing this so obviously I refrained from comment. I took this steering wheel of of my 76 C-160 and replaced it with a Fat Wheel because of the arthritis in my hands has lessened my squeezing power. It could use a good home. 2 1 Share this post Link to post Share on other sites
ebinmaine 81,049 #23768 Posted June 1, 2025 1 minute ago, squonk said: Fat Wheel What'd ya use? Share this post Link to post Share on other sites
squonk 48,288 #23769 Posted June 1, 2025 28 minutes ago, ebinmaine said: What'd ya use? Same as your Cinnamon Horse 1 Share this post Link to post Share on other sites
Ed Kennell 47,754 #23770 Posted June 1, 2025 56 minutes ago, squonk said: a Fat Wheel because of the arthritis in my hand All my steering wheels are fat. These old paws won't close far enough to grip a skinny wheel. 5 Share this post Link to post Share on other sites
DevonianHorse 313 #23771 Posted June 1, 2025 Hauled a load of firewood for my Dad today, and then gave the Horse a oil rub down- Devon (England) is super humid, so it keeps the rust at bay! 2 11 Share this post Link to post Share on other sites
Racinbob 13,250 #23772 Posted June 1, 2025 1 hour ago, squonk said: I took this steering wheel of of my 76 C-160 and replaced it with a Fat Wheel because of the arthritis in my hands has lessened my squeezing power. It could use a good home. 50 minutes ago, Ed Kennell said: All my steering wheels are fat. These old paws won't close far enough to grip a skinny wheel. Kinda inbetwixed guys. One like the original on my 76. Called 'soft-touch' back then. 13". Or like the one I put on the 05. Also 13" I just don't care for the bulky 15" guy on the 96. Of course it won't get changed if the main pilot prefers the fat one. Time will tell. She hasn't tried the tractor since I modified the hydro control but she did say the original was awkward. 2 1 Share this post Link to post Share on other sites
squonk 48,288 #23773 Posted June 1, 2025 14 minutes ago, Racinbob said: Kinda inbetwixed guys. One like the original on my 76. Called 'soft-touch' back then. 13". I just don't care for the bulky 15" guy on the 96. I wonder if the "Soft Touch was an option. The wheel I have was original to my 76 C 160. And yes that wheel on that 96 would be yanked off in a second it it was mine. 1 Share this post Link to post Share on other sites
Damien Walker 297 #23774 Posted June 1, 2025 1 hour ago, DevonianHorse said: Hauled a load of firewood for my Dad today, and then gave the Horse a oil rub down- Devon (England) is super humid, so it keeps the rust at bay! Very nice too! 1 1 Share this post Link to post Share on other sites
Racinbob 13,250 #23775 Posted June 1, 2025 38 minutes ago, squonk said: I wonder if the "Soft Touch was an option. The wheel I have was original to my 76 C 160. And yes that wheel on that 96 would be yanked off in a second it it was mine. Besides not liking the feel it certainly is ugly too. I don't think the 76 wheel was an option. I would guess that they had some 75 wheels left over and you know how they were. Share this post Link to post Share on other sites
