Handy Don 17,103 #25726 Posted April 16 Just now, squonk said: All you need is the Handy Don's secret weapon! You are so right! Problem was that I’d brought only fixed-size wrenches out to the garage thinking “this’ll be a short job” so I needed an extra hike back down to the basement shop to get “the weapon.” Lesson learned. 1 5 Share this post Link to post Share on other sites
ebinmaine 79,950 #25727 Posted April 16 56 minutes ago, squonk said: All you need is the Handy Don's secret weapon! Are these reversible or do you really need to stick with properly labeled orientation? 1 2 Share this post Link to post Share on other sites
squonk 47,580 #25728 Posted April 16 23 minutes ago, ebinmaine said: Are these reversible or do you really need to stick with properly labeled orientation? If you flip it over it's left handed! 2 2 6 Share this post Link to post Share on other sites
adsm08 4,866 #25729 Posted April 16 I found a 7/8 ball that fits the hitch on the Commando. Now I just need to fix the carb and I can use the tractor to move stuff. 5 Share this post Link to post Share on other sites
sqrlgtr 3,535 #25730 Posted April 16 2 hours ago, squonk said: If you flip it over it's left handed! unless you are already using it in your left hand of course, then its bass ackwards. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,950 #25731 Posted April 16 2 hours ago, squonk said: If you flip it over it's left handed! Ohh... I struggle with that kinda coordination.... 1 1 Share this post Link to post Share on other sites
ML3 2,442 #25732 Posted April 18 Worked the 654 hard today. We've had tons of rain so far this spring. Have an 81yr old neighbor lady. Her landscape guy hasn't shown up to cut her lawn. I told her I'd mow before the city cites her. We had rain this morning so it was very wet & muddy. Her grass was at least 6-8" tall. 6 7 3 Share this post Link to post Share on other sites
Goldnboy 1,139 #25733 Posted April 18 I sanded this head for a K321 I am Rebuilding..not sure why so many people posts metioned glass and water.. I used a 12x12 new steel plate I had. 2 Share this post Link to post Share on other sites
wallfish 20,347 #25734 Posted April 18 10 minutes ago, Goldnboy said: not sure why so many people posts metioned glass and water I'm going to guess more people would have glass or easy access to it vs a 12x12 piece of thick steel plate. Wet sanding clears the dust out of fine grit paper to prevent clogging 6 Share this post Link to post Share on other sites
pfrederi 20,964 #25735 Posted April 18 (edited) Got the 48 all hooked up had to buy a new belt. 42 takes 102" 48 takes 103" Hard to believe it makes a difference...it does. To wet to start mowing the paths. I like the front mount as it knocks some of the Tics down before they hit my leg Already had one.. Going to need lots of DEET this year. Did a short test may have to get a bigger horse the 48 put a load on the 14hp. Edited April 18 by pfrederi 8 6 Share this post Link to post Share on other sites
sqrlgtr 3,535 #25736 Posted April 18 Put steering wheel center cap on 520H thanks ti AtoZ tractor, also added cubic inches decals to air cleaner lid on same tractor. 6 3 2 Share this post Link to post Share on other sites
Thor27 892 #25737 Posted April 18 1 hour ago, pfrederi said: Got the 48 all hooked up had to buy a new belt. 42 takes 102" 48 takes 103" Hard to believe it makes a difference...it does. To wet to start mowing the paths. I like the front mount as it knocks some of the Tics down before they hit my leg Already had one.. Going to need lots of DEET this year. Did a short test may have to get a bigger horse the 48 put a load on the 14hp. Nice set up. Can you please show a pic of the other side? Like to see belt routing. Thank you. 2 Share this post Link to post Share on other sites
Chris689 308 #25738 Posted April 18 Rather productive day today. Broke the axle shaft free of the hub with my 12 ton hobo freight press. Pulled the trans out of the 10-8, new axle shaft came in today for the 10-8 trans now just need to get the time to split it and repair it. Had my new tri-rib tires mounted yesterday and today threw them on the C120 for now to see how I like them since they’re for the 10-8. Then plowed out my new garden bed with the C120. All in all it was a good day. 4 8 Share this post Link to post Share on other sites
pfrederi 20,964 #25739 Posted April 18 1 hour ago, Thor27 said: Nice set up. Can you please show a pic of the other side? Like to see belt routing. Thank you. You have to dissemble the PTO... the back side belt goes outside the hoop. Will take some tomorrow 3 1 Share this post Link to post Share on other sites
kpinnc 18,811 #25740 Posted April 19 My favorite Frankentractor started acting up this week. Slow to crank sometimes, and shut off unexpectedly every 15-20 mins. Crank right back up and die 5 mins later. Swapped both magnetos, since both originals "tested" within specs. Best I can tell one of them flaked out when hot. Once again purrs like a kitten (a dang big one ) now. I really love this machine. It was my first Wheel Horse and it has been awesome for 30 years! 10 6 Share this post Link to post Share on other sites
ebinmaine 79,950 #25741 Posted April 19 8 hours ago, kpinnc said: one of them flaked out when hot Understandable. I do the same thing. 1 Share this post Link to post Share on other sites
cleat 9,086 #25742 Posted April 19 (edited) 59 minutes ago, ebinmaine said: Understandable. I do the same thing. I know what you mean, it got up to 74 degrees F. yesterday and I felt like I was in an oven. Still used to winter temps I guess. Well, I should have kept my mouth shut. It's snowing heavily right now. Summer and winter all in one weekend. Edited April 19 by cleat 3 1 Share this post Link to post Share on other sites
ebinmaine 79,950 #25743 Posted April 19 23 minutes ago, cleat said: I know what you mean, it got up to 74 degrees F. yesterday and I felt like I was in an oven. Still used to winter temps I guess. Well, I should have kept my mouth shut. It's snowing heavily right now. Summer and winter all in one weekend. Yep. We saw 74⁰ a couple days ago. We're not forecast to go above the upper 50s for the next 11 days! 1 Share this post Link to post Share on other sites
JCM 11,332 #25744 Posted April 19 On 4/15/2026 at 5:52 PM, kpinnc said: Actually a commonly used style seat nowadays. I have two myself. And they hold up very well those seats. Have several after the OEM 's vanished. Source ? KP 1 Share this post Link to post Share on other sites
Ed Kennell 46,763 #25745 Posted April 19 45 minutes ago, cleat said: Summer and winter all in one weekend. 87* here last week and frost warnings tomorrow night. There go my pear and plum blossoms. 2 Share this post Link to post Share on other sites
adsm08 4,866 #25746 Posted April 19 3 minutes ago, Ed Kennell said: 87* here last week and frost warnings tomorrow night. There go my pear and plum blossoms. Tell me about it. I was dripping running the saw yesterday, now I'm annoyed that I left my work coat hanging at work when I left Friday. 1 Share this post Link to post Share on other sites
peter lena 9,988 #25747 Posted April 19 @Chris689 make a regular habit of penetrating oil spray down , of any , dry / faded / neglected paint ? soak it down and forget it , let the penetrants do their thing , usually a darker shade developes , showing you what's there , then what i do is to use a mineral oil clean cloth rub down , no rough action , just a total , refresh of darkened paint , if the paint does not easily , break thru with a color change , fine , leave it in the vintage stage , seams like everyone wants to instantly recover a show queen , everything I have is , recovered / maintained , original paint , looks the way it should be for the years of service . very east to experiment with this idea , thats how I started , stay oily , pete 1 Share this post Link to post Share on other sites
Chris689 308 #25748 Posted April 19 (edited) @peter lena it’s funny you mention this. I’ve been having this internal conflict the last couple weeks on whether or not to do a quick scuff and shoot of the 10-8 but I’ve come to realize I really like how the paint has faded on it and all the original stickers are still on it except for one. It has aged very nicely in my opinion. The C120 on the other hand I haven’t decided on yet. It got hammered with road salt this winter because hauling it on an open trailer to help family out for the first half of winter, then I got an enclosed trailer. So I’m on the fence doing a scuff and shoot on this one. I think the 10-8 will be a good candidate for keeping oiled. If I made either of them into show pieces I’d never use them. Edited April 19 by Chris689 1 Share this post Link to post Share on other sites
peter lena 9,988 #25749 Posted April 19 @Chris689 paint on my units , this is all lubrication , recovered , maintained , only thing I regularly wipe them down with , is a clean light aerosol oil . once a 6" electric hand buffer , cleaner wax , cleans off all the oiled work , its there . I am always experimenting , with something , thank you for the response , pete Share this post Link to post Share on other sites
kpinnc 18,811 #25750 Posted April 19 6 hours ago, JCM said: Source ? KP Oh boy it's been too long. Probably 15 years ago. I remember I bought both together but I can't recall the place. 1 Share this post Link to post Share on other sites
