lynnmor 9,037 #25376 Posted February 5 22 minutes ago, Ed Kennell said: s I was looking at Jims washers Lynn. Sorry about that, it is hard to identify the players without a program. 1 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,299 #25377 Posted February 5 4 hours ago, WHX?? said: All depends on the hardware store to find them. I lucked out and found one that had them in all lengths but yes not full threads past 1 1/2. What's your theory with the star washers? I used thick flat washers to get them to seat flush. I like those spacers Mike ... source? Needed 2” full thread, not available at stores but McMaster Carr had em and shipped me 10. Star washers?? Not sure the were needed but I installed em anyway. They were cheap, unlike the bolts. And the spacers, they were sitting on a guys table for sale at a tractor show and my son grabbed em. No brand name on them that I could find. 4 1 Share this post Link to post Share on other sites
Blue Chips 854 #25378 Posted February 5 (edited) 7 hours ago, Racinbob said: I'm thinking the lock washers are more for getting around that little taper on the bolt. I've countersank them in the past. Agreed. For a threaded-hole situation like that, I would usually (as you mentioned) countersink the hole a bit to provide clearance for the little radius (fillet) between the underside of the bolt head and the bolt shank. Of course a washer would also do the trick. Edited February 5 by Blue Chips 3 Share this post Link to post Share on other sites
8ntruck 9,278 #25379 Posted February 6 I wrassaled the 48" deck i picked up last weekend out of my truck, strapped on the 2 wheel hand cart and wheeled it through the trails that I cut in the snow with the tiny Toro two stroke snow blower to the tractor shed. That will let Morgan, the 14-8; and Clyde, the C-195 make friends with it while it is waiting for a refresh sometime this spring. 3 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,299 #25380 Posted February 6 Mounted up these cast weights I bought last year. Seemed heavier than all my usual 50 pounders, turns out they’re 70 pounds apiece! Came with hardware that’ll need an inch or so cut off. 13 1 Share this post Link to post Share on other sites
CD Long Jr 203 #25381 Posted February 6 39 minutes ago, Sparky said: Mounted up these cast weights I bought last year. Seemed heavier than all my usual 50 pounders, turns out they’re 70 pounds apiece! Came with hardware that’ll need an inch or so cut off. 8 inch carriage bolts were perfect for my 55 lb Sears weights. Now to find round Wheel Horse decals. 5 1 Share this post Link to post Share on other sites
lynnmor 9,037 #25382 Posted February 6 9 minutes ago, CD Long Jr said: 8 inch carriage bolts were perfect for my 55 lb Sears weights. Now to find round Wheel Horse decals. Here ya go. 3 1 Share this post Link to post Share on other sites
Blue Chips 854 #25383 Posted February 7 (edited) Oops. Ran into a bit of a glitch in painting my 522xi fender. It looked reasonably good until I noticed some areas where the paint wrinkled and/or orange-peeled a bit. I had allowed extra drying/curing time for the primer to make up for the relatively low temperatures in the shop, but I guess it wasn't quite enough time. I'll be more patient this time and wait at least a week before I wet sand the rough spots, plus at least an additional week before applying a second application. I'll set the shop temperature a few degrees warmer as well. On the plus side, the next coat(s) should be even smoother, and there's no big rush, since there are several other parts of the tractor that I can work on in the meantime. If it had been a bigger paint job, I might have used 2K primer and paint. Maybe some other time. Edited February 7 by Blue Chips 4 1 Share this post Link to post Share on other sites
JoeM 10,246 #25384 Posted February 7 1 hour ago, Blue Chips said: I might have used 2K primer and paint. Maybe some other time I like the 2k primer that gassing problem goes away. my bad and this one I don't know if you ever tried this on single stage paint, I like putting two coats of clear enamel on as two final coat of color. Apply 10 minutes or so after the last color coat. It can be buffed and adds UV protection too. Only available in spray cans tho. 5 3 Share this post Link to post Share on other sites
ebinmaine 80,600 #25385 Posted February 7 On 2/2/2026 at 11:11 PM, oliver2-44 said: Spoken like a true Southerner. And a guy from Maine too!! 1 Share this post Link to post Share on other sites
ebinmaine 80,600 #25386 Posted February 7 On 2/5/2026 at 10:27 AM, WHX?? said: The thick flats can be hard to find too. Really no need for locks other than a spacer. Once the nut is on they ain't going nowhere. If one can find the thicks in 3/8 they work great for head bolts. Bolt Depot in Hingham MA has em. Order online. Those thick washers and the studs and nuts for wheels are part of our constant stock in the Parts department here. Share this post Link to post Share on other sites
ebinmaine 80,600 #25387 Posted February 7 19 hours ago, Sparky said: cast weights I bought last year. Seemed heavier than all my usual 50 pounders, turns out they’re 70 pounds apiece! Got a set o' those here too. They were in the pile when we picked up the Workhorse GT1800 we built for our friends. They now set on The Ugly Bruce tractor. Excellent traction aids. 2 1 Share this post Link to post Share on other sites
Ed Kennell 47,254 #25388 Posted February 7 21 hours ago, Sparky said: turns out they’re 70 pounds apiece! I have these plastic coated 70 pounders on the 520H. 6 1 Share this post Link to post Share on other sites
Blue Chips 854 #25389 Posted February 7 (edited) 10 hours ago, JoeM said: I don't know if you ever tried this on single stage paint, I like putting two coats of clear enamel on as two final coat of color. Apply 10 minutes or so after the last color coat. It can be buffed and adds UV protection too. Only available in spray cans tho. I've used various types of clear coat, both single-stage and catalyzed, for a variety of projects, mostly automotive. It is a good way to add some smoothness, gloss, and depth to the finish, as well as some extra UV resistance, as you mentioned. 2K primer is nice, since its rapid cure avoids off-gassing or softening the topcoat, which can happen with single-stage primers that are not completely dry/cured. I didn't see any bubbles in the red paint, so I don't think there was any off-gassing from the primer, but rather just enough residual solvent in the primer to soften the red paint and cause it to wrinkle and warp a bit in places. In this case, I was in too big of a hurry to apply the red paint over the single-stage primer before the primer was hard and dry enough. I used two different primers on this fender, since I ran out of one type, and the second primer that I used in a few places was a slower drying type. I should have tested all of the spots where I used that primer for hardness before painting. As mentioned, I just needed to be more patient. It shouldn't take much to sand those spots, since they affect only a small portion of the area of the fender, but it's a delay that could have been avoided. It recalls the old saying, "The hurrier I go, the behinder I get." Edited February 7 by Blue Chips 4 Share this post Link to post Share on other sites
ML3 2,504 #25390 Posted February 7 Didn't get much snow overnight but had some wind so driveway was drifted in a bit. Used the 702 to clean up & now its thawing in garage. 6° outside but its 68° in garage 7 5 Share this post Link to post Share on other sites
rjg854 13,341 #25391 Posted February 7 We're all the way up to 3 degrees with 25mph winds, got 2-3" of snow but drifting way more than that. This has been like an old fashion winter. Haven't had one like this in many many years. I love it. 5 Share this post Link to post Share on other sites
Ed Kennell 47,254 #25392 Posted February 7 1 hour ago, rjg854 said: Haven't had one like this in many many years. I love it. You're welcome Randy. No problem, all I had to do was sell the Ber Vac and here we are. 7 Share this post Link to post Share on other sites
ML3 2,504 #25393 Posted February 7 1 hour ago, Ed Kennell said: You're welcome Randy. No problem, all I had to do was sell the Ber Vac and here we are. Sorry Ed.......... The Ber Vac does look good sitting in my garage doing nothing 🙄 1 Share this post Link to post Share on other sites
JoeM 10,246 #25394 Posted February 7 1 hour ago, Ed Kennell said: all I had to do was sell the Ber Vac and here we are told you so! lol It like turning the water on to the out building thinking all is good and it goes down to 9 for 3 nights! 2 Share this post Link to post Share on other sites
JoeM 10,246 #25395 Posted February 7 8 hours ago, Blue Chips said: In this case, I was in too big of a hurry to apply the red paint over the single-stage primer One good thing is you get to sand and smooth her out even more! 2 Share this post Link to post Share on other sites
rjg854 13,341 #25396 Posted February 7 2 hours ago, Ed Kennell said: You're welcome Randy. No problem, all I had to do was sell the Ber Vac and here we are. It just works that more times than not. Would you have been able to use it, if you still had it? 1 Share this post Link to post Share on other sites
Ed Kennell 47,254 #25397 Posted February 8 1 hour ago, rjg854 said: It just works that more times than not. Would you have been able to use it, if you still had it? I prefer to plow rather than blow the snow due to throwing stones from the gravel roads. And the small wet snows we have had for the past 10 years were easy to plow. This one was 8-10" with a heavy crust making it very difficult to plow. Yes, I'm sure the Ber Vac would have chewed right thru it. 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,535 #25398 Posted February 8 Got some snow today. Probably now about 3” but still really windy so I expect some drifts. Monday will be final cleanup day since it’s going to be real windy tonight and all day tommorow. IMG_1540.mov 6 5 Share this post Link to post Share on other sites
WHX?? 58,052 #25399 Posted February 8 (edited) 22 hours ago, ML3 said: Used the 702 to clean up You just working the snot outta that thing this winter ain't ya. Brought a 867 in for work. This is one @Pullstart picked up for me. Probably overpaid but got good bones & actually a nice survivor under all the gunk. Putting a shelf 8 on it. Old motor is real tired ... smokes & head gasket blown ... crank end play measured in inches. Will go thru it for another shelf motor. Repair all the cobblements & get her ready for re-sale. Edited February 8 by WHX?? 3 7 Share this post Link to post Share on other sites
c-series don 12,421 #25400 Posted February 8 Today I took out my 417-A after replacing the transmission idler pulley. The old one was making noise so I got a new one from Brian at K+B Wheel Horse Parts. Put in a new correct belt and it worked perfectly. They called for 1”-2” of snow today, we got at least 5”! I was going to plow with my 418-C but it doesn’t have a cab and the temperature was in the teens with wind blowing 20-30mph, so in the cab I went! Sorry no pics this time! 4 4 Share this post Link to post Share on other sites
