JoeM 10,246 #25076 Posted December 9, 2025 Changed out the TU pulley on Frankie. I has a few of these plastic ones. JD uses them and my son has a 324 that has them on the hydro pulley. I know he has to be pushing 500 hours with no issues. I put one on the hydro and I must say they are smooth. Very smooth. Now I know why they are used by JD. 8 2 1 1 Share this post Link to post Share on other sites
ML3 2,504 #25077 Posted December 10, 2025 Added a lift assist spring for snowblower on the 702. Made it definitely easier to raise up. With my lower back issues I need any help I can. 4 7 Share this post Link to post Share on other sites
cleat 9,324 #25078 Posted December 10, 2025 6 minutes ago, ML3 said: Added a lift assist spring for snowblower on the 702. Made it definitely easier to raise up. With my lower back issues I need any help I can. May help the blower to float and reduce wear on the skids as well. 4 Share this post Link to post Share on other sites
ML3 2,504 #25079 Posted December 10, 2025 11 minutes ago, cleat said: May help the blower to float and reduce wear on the skids as well. The blower has the steel wheels instead of skids. I did adjust spring so snowblower isn't bouncing around when down but yet its definitely lighter on the wheels. I'm sure I'll maybe need to adjust it some???? 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,129 #25080 Posted December 10, 2025 (edited) Today, I looked at them does that count? Edited December 10, 2025 by MainelyWheelhorse 1 4 2 Share this post Link to post Share on other sites
ebinmaine 80,600 #25081 Posted December 10, 2025 10 minutes ago, MainelyWheelhorse said: Today, I looked at them does that count? Yes 2 1 1 Share this post Link to post Share on other sites
Bar Nuthin 3,157 #25082 Posted December 10, 2025 Got the transaxle case back together on my C-120, after changing out the differential assy. Of course, that's when I realized that the only oil I have on hand is all 30W Anybody need a good diff with trashed axles? Or, does anyone have any good "repurposing" ideas? I suppose I could get a forge and make a few swords. 4 3 Share this post Link to post Share on other sites
kpinnc 18,939 #25083 Posted December 10, 2025 4 hours ago, MainelyWheelhorse said: Today, I looked at them does that count? Yes, X2! 3 Share this post Link to post Share on other sites
Red Stallion 231 #25084 Posted December 10, 2025 7 hours ago, MainelyWheelhorse said: Today, I looked at them does that count? I looked at mine, and swore at it for a bit because the side panel wont go back on. Then went back inside. 2 4 Share this post Link to post Share on other sites
sqrlgtr 3,860 #25085 Posted December 10, 2025 3 hours ago, Red Stallion said: I looked at mine, and swore at it for a bit because the side panel wont go back on. Then went back inside. When they start to swear back then it's definitely time to go back inside. 1 2 Share this post Link to post Share on other sites
WHX?? 58,052 #25086 Posted December 10, 2025 (edited) 23 hours ago, ebinmaine said: f I used my Wheelhorse it goes in this thread. If I didn't use my Wheelhorse it goes in the other thread, "What did you do today?" I looked a little bit for the work your horse thread but failed ... my penance is reading all upmteen pages of this one ... As long as we're wrenching on sno machines. This one in the shop for oil & filter. Is it just me or does a motor just seem to run better with fresh oil? Should have cleaned the carb ... surging abit and seafoam aint workin. Need it tho so after today's cleanup. Grass screen was rusty ... I think they look cool in red ... Do I have a problem? Edited December 10, 2025 by WHX?? 9 1 1 Share this post Link to post Share on other sites
8ntruck 9,278 #25087 Posted December 10, 2025 9 hours ago, kpinnc said: Yes, X2! I used mine yesterday as a place to put the shed pad lock while I got a couple ears of corn for the squirrel feeder. 4 Share this post Link to post Share on other sites
Lee1977 7,764 #25088 Posted December 10, 2025 (edited) On 12/9/2025 at 10:38 AM, nylyon said: I don’t recall a what did you do with your wheel horse today thread. It's called "Horses at work" located down in "Wheel Horse Picture Gallery". I made the last post there in September. 2023. Edited December 10, 2025 by Lee1977 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,860 #25089 Posted December 10, 2025 Put custom decal from @Vinylguy on this morning. I wanted a decal that matched the seat latch decal and think he done a great job. 8 2 Share this post Link to post Share on other sites
pfrederi 21,145 #25090 Posted December 10, 2025 (edited) . First run after complete K181 engine overhaul. Always a fingers crossed time hoping no loud banging noises. Don't know what happened to the sound Try again Edited December 10, 2025 by pfrederi 5 8 Share this post Link to post Share on other sites
WHX?? 58,052 #25091 Posted December 10, 2025 40 minutes ago, pfrederi said: Don't know what happened to the sound Working fine for me... 2 Share this post Link to post Share on other sites
Handy Don 17,459 #25092 Posted December 10, 2025 1 hour ago, pfrederi said: . First run after complete K181 engine overhaul. Always a fingers crossed time hoping no loud banging noises. Curious. Was the sideways coil mount your mod or original? 1 Share this post Link to post Share on other sites
pfrederi 21,145 #25093 Posted December 10, 2025 18 minutes ago, Handy Don said: Curious. Was the sideways coil mount your mod or original? My Mod. This engine was originally on a C-81 with obviously bendix starter and under seat tank. Coil was mounted up top. I converted her to a S/G setup. Some S/G engines the coil was mounted on a bracket bolted to the bottom front of the engine. I didn't have the bracket but looking at a K181 I picked up for parts it had the cross mount so I went with that as no bracket was needed. 5 1 Share this post Link to post Share on other sites
WHX?? 58,052 #25094 Posted December 10, 2025 33 minutes ago, Handy Don said: Curious. Was the sideways coil mount your mod or original? I've had a few service eights that are mounted like that. 1 Share this post Link to post Share on other sites
ebinmaine 80,600 #25095 Posted December 10, 2025 6 minutes ago, WHX?? said: I've had a few service eights that are mounted like that. Seen a couple here too Share this post Link to post Share on other sites
Handy Don 17,459 #25096 Posted December 10, 2025 1 hour ago, pfrederi said: a K181 I picked up for parts it had the cross mount so I went with that as no bracket was needed. And it had the longer spark plug wire you needed, as well. Nice. 1 Share this post Link to post Share on other sites
sqrlgtr 3,860 #25097 Posted December 11, 2025 (edited) Pressure washed and mounted some 24-12-12 wheels and tires on Ol Thumper (C160). Almost to cold to play in water and got my feet wet.. Edited December 11, 2025 by sqrlgtr 7 2 Share this post Link to post Share on other sites
Stan50 218 #25098 Posted December 11, 2025 (edited) I installed hourmeter, there were cables ready so I just hooked it up, after some cutting and drilling of course. New ignition key switch was installed too. By the way I noticed that I don't have any power in cables for lights switch :/ Edited December 11, 2025 by Stan50 5 1 Share this post Link to post Share on other sites
Wayne0 1,632 #25099 Posted December 11, 2025 3 hours ago, Stan50 said: I installed hourmeter, there were cables ready so I just hooked it up, after some cutting and drilling of course. New ignition key switch was installed too. By the way I noticed that I don't have any power in cables for lights switch :/ Wow, only .4 hours! You've got yourself a new machine!! 1 5 Share this post Link to post Share on other sites
Stan50 218 #25100 Posted December 12, 2025 This is good start for new beginning 1 Share this post Link to post Share on other sites
