Oldskool 6,663 #12751 Posted September 12, 2021 So this isn't perfect by no means, but I couldn't look at the gaping hole in the grille any longer. Maybe someday I will end up with the correct parts to fix it rite. A scrap piece of aluminum, an old emblem from a trash 312-8 hood a bit of paint and no more hole. 8 6 Share this post Link to post Share on other sites
peter lena 9,233 #12752 Posted September 12, 2021 @kpinnc hope you get to try the lubriplate chain and cable spray , pry mine up at a 45 deg angle in the sun , and it really gets things hot and dry , at least a couple of hours , it stains the metal black , I do the same thing every time I touch it up . never had any wear off . also do the spindles , sharpen the blades with a small fine file , oil spray to retain edge . that procedure along with lucas xtra heavy duty polyurea chassis grease in the spindle bearings and the same pto drive bearings , makes for some solid quiet operation. since going over to this set up , my decks have been bombproof , no rot very little build up ,and no whining noisy bearings . this is what I do , was tired of repetitive bearing failure , and underside deck issues . pictures above on rustproofing deck maintenance, is on my decks . detail question ? just ask , pete Share this post Link to post Share on other sites
WheelPuke 78 #12753 Posted September 12, 2021 I changed my transmission fluid. The fluid that came out was dirty and old but not contaminated in anyway. With the old fluid looking as it did and I could only get the tractor up so high I was confident the transmission did not need flushing and that I would not be able to get all the kerosine after the flush. From there I just added in the new fluid. I checked the level which was full after 2qts. of 80-90 gear oil. I drove the tractor around through all gears and high and low ranged and checked it again. It was still full and clean. I installed the new transmission shifter boot and then the plow. While having the shift guide off I had a chance to monitor my parking brake “repair”. It was already starting to bend back. I straightened out the switch arm again and reinforced it with a wrapping of electrical tape. I was unable to install the wheel weights. The bolts I have are only eight inches long and come to the mounting hole in the wheel on the inside. I would need another inch. The local hardware store had 10 inch bolts but not enough threading to cut down. After looking elsewhere I figure I’d have to go buy the 10 inch bolts and extend the threading and cut them down. I also got a replacement gas cap with gauge. The original one had became unreadable and cracked with age. I also bolted on the plow bracket and attached the plow. A light horse day. After all the work I pushed some brush back in the rabbit patch with the blade. 3 3 Share this post Link to post Share on other sites
gvthnks 46 #12754 Posted September 13, 2021 Fixed a flooding carb, replaced a bad drive idler pulley and test drove. Lead test driver approves 5 3 3 Share this post Link to post Share on other sites
Snoopy11 5,718 #12755 Posted September 13, 2021 22 hours ago, Oldskool said: Don 3 1 Share this post Link to post Share on other sites
Snoopy11 5,718 #12756 Posted September 13, 2021 13 hours ago, gvthnks said: replaced a bad drive idler pulley I also did this over the weekend! Mine waz... something like 60 years old... so... 'bout time... Don 1 Share this post Link to post Share on other sites
ebinmaine 72,423 #12757 Posted September 14, 2021 We had a metal roof installed back in April and May. Still a bit of trim to be finished up but it was time to get the waste pile moved into he trailer so it can go to the transfer station this weekend. Gotta get cleaned up 'round here what with us having a Meet n Greet coming up!! So we used the Cinnamon Horse C160 and Trina's 867 Pigpen tractor to pull a couple trailers over by the pile. We sorted out the material by type and loaded up. Oh, and bonus dog pic..... 5 4 Share this post Link to post Share on other sites
D_Mac 9,302 #12758 Posted September 14, 2021 I did this. 3 7 Share this post Link to post Share on other sites
Oldskool 6,663 #12759 Posted September 14, 2021 I would like to do something with my horse today. I'm wondering what everyone uses to soften a dried out vinyl seat. Mine is in decent shape but if I keep using it I know it's going to crack. I would really like to safe this one Share this post Link to post Share on other sites
ebinmaine 72,423 #12760 Posted September 14, 2021 4 minutes ago, Oldskool said: I would like to do something with my horse today. I'm wondering what everyone uses to soften a dried out vinyl seat. Mine is in decent shape but if I keep using it I know it's going to crack. I would really like to safe this one Boy it's been a couple decades or more since I've processed that thought. I'm not sure what's available on the market nowadays for final conditioners... I will say this. CLEANLINESS IS KEY and in fact may even solve a lot of the problem. Share this post Link to post Share on other sites
Lee1977 7,189 #12761 Posted September 14, 2021 (edited) Don't know if there is anything that will soften harden aged plastic. Mineral oil is listed as the most widely used product by the internet. Most products only claim to protect against UV damage. My guess is mineral oil the main ingredient in all of them. Edited September 14, 2021 by Lee1977 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,766 #12762 Posted September 14, 2021 I've just used car interior and seat type conditioners/protectors for vinyl and keep it clean as ebinmaine said. I spray it down and wipe it off a few times a year at least. I think it's one of those it will crack at some point as it won't last forever. But pushing it off longer always sounds nice...especially with an original WH seat. 1 Share this post Link to post Share on other sites
cleat 7,243 #12763 Posted September 14, 2021 And keep it out of the sun. UV light will kill almost all plastics. 1 1 Share this post Link to post Share on other sites
bigcreek 205 #12764 Posted September 14, 2021 Down with hurt back, grass still grows, daughter number two got r done 4 7 5 Share this post Link to post Share on other sites
TJ5208 1,841 #12765 Posted September 14, 2021 (edited) Put the spindles on Rebel like the look good with the red in the middle steers easier to Edited September 14, 2021 by TJ salyers 6 Share this post Link to post Share on other sites
ebinmaine 72,423 #12766 Posted September 14, 2021 1 hour ago, bigcreek said: Down with hurt back, grass still grows, daughter number two got r done Nice of her to step up. And wearing the best possible ((Maine)) shirt too! 1 Share this post Link to post Share on other sites
kpinnc 14,582 #12767 Posted September 14, 2021 (edited) 33 minutes ago, ebinmaine said: Down with hurt back, grass still grows, daughter number two got r done This means three things: 1. You raised her right. 2. She is smarter, more dutiful, and more compassionate than 90% of the rest of her generation. 3. You have both earned and been gifted the hallowed right of proud papa! Edited September 14, 2021 by kpinnc 4 1 Share this post Link to post Share on other sites
Oldskool 6,663 #12768 Posted September 14, 2021 8 hours ago, ebinmaine said: I will say this. CLEANLINESS IS KEY and in fact may even solve a lot of the problem. That was the first thing I did when I bolted it on. I dont know what it is about this tractor but I find myself joy riding on it ALOT 1 1 Share this post Link to post Share on other sites
Oldskool 6,663 #12769 Posted September 14, 2021 5 hours ago, Lee1977 said: Don't know if there is anything that will soften harden aged plastic. Mineral oil is listed as the most widely used product by the internet. Most products only claim to protect against UV damage. My guess is mineral oil the main ingredient in all of them. Thanks I will give it a try. 1 Share this post Link to post Share on other sites
ebinmaine 72,423 #12770 Posted September 14, 2021 15 minutes ago, Oldskool said: That was the first thing I did when I bolted it on. I dont know what it is about this tractor but I find myself joy riding on it ALOT That's great but it will not help the addiction. Keep riding. In fact, I've got trails for you to try out!! Those B and C tractors really are fun to cruise around on.... 1 Share this post Link to post Share on other sites
squonk 43,731 #12771 Posted September 14, 2021 58 minutes ago, ebinmaine said: Those B and C tractors really are fun to cruise around on.... D series are a blast to trail ride on. You can even stand up on one and stretch your legs! 1 1 Share this post Link to post Share on other sites
Oldskool 6,663 #12772 Posted September 14, 2021 1 hour ago, ebinmaine said: In fact, I've got trails for you to try out!! I hope that this little buggah doesn't tear them up to bad. Vroom vroom. Bahahahaha 1 Share this post Link to post Share on other sites
ebinmaine 72,423 #12773 Posted September 14, 2021 1 hour ago, Oldskool said: I hope that this little buggah doesn't tear them up to bad. Vroom vroom. Bahahahaha Hahahahaha. Head on down an' try em out!! 1 Share this post Link to post Share on other sites
8ntruck 7,779 #12774 Posted September 15, 2021 Think applying mineral oil will bring this seat back? 1 5 Share this post Link to post Share on other sites
ebinmaine 72,423 #12775 Posted September 15, 2021 7 minutes ago, 8ntruck said: Think applying mineral oil will bring this seat back? Could be close Share this post Link to post Share on other sites
