Tuneup 1,459 #12176 Posted July 12, 2021 That'll keep the 312 moving along! My kids called and said the electric dryer stopped working so Mr. Maintenance took a drive - I like to teach and they absorb it like a sponge (well one of them does). Dryer all cleaned and checked. The old multimeter has a new home. A 30A breaker actually crapped out on one side. I have never seen this! Yeah, this place is my Facebook. In Wheel Horse news, the trip to the hardware store yielded three cans of Sunrise Red so the 48" deck gets its paint this week. 7 Share this post Link to post Share on other sites
Jeff-C175 7,209 #12177 Posted July 12, 2021 26 minutes ago, Tuneup said: 30A breaker actually crapped out on one side. I have never seen this! I've seen that happen from time to time. Not often... but my 'day job' deals with circuit breakers a lot. (not in the panel boards but in the equipment racks) I've also seen them go what I call 'soft', where they trip at a lower current than their rating. 5 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #12178 Posted July 12, 2021 Was surprised the turf tires moved this big log! Was thinking for sure it wouldn't have enough bite. Must have been all the added extra weight with me sitting on it 7 2 1 4 Share this post Link to post Share on other sites
ebinmaine 79,754 #12179 Posted July 12, 2021 7 hours ago, OutdoorEnvy said: Was surprised the turf tires moved this big log! Was thinking for sure it wouldn't have enough bite. Must have been all the added extra weight with me sitting on it Ballast is ballast brother man. I'll bet I outweigh you some anyway..... 2 Share this post Link to post Share on other sites
Ed Kennell 46,639 #12180 Posted July 12, 2021 I started out planning to mow the right o way around the farm and some woods trails. I got about a 1/4 mile from the house and the deck drive belt came off. I loosened the mule drive andreached under to put the belt back on the center pulley and it was gone. I found the pulley in the grass to the left of the tractor. Lucky it didn't go the other way into the beans. The spindle had dropped downnand the blade was dragging, so I had to find some ramps to get it high enough to get the spindle out for the ride home. When I took the deck off, the bolt and washers were still laying on top of the deck. While I had the deck off, I removed the other two spindles and greased the bearings. These do not have zerks. Back to mowing after the 2 hour delay. 12 8 Share this post Link to post Share on other sites
Jeff-C175 7,209 #12181 Posted July 12, 2021 1 hour ago, Ed Kennell said: the bolt and washers That little bitty bolt is all that holds that together? Share this post Link to post Share on other sites
Ed Kennell 46,639 #12182 Posted July 12, 2021 Yep, that's all folks. 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #12183 Posted July 12, 2021 1 minute ago, Ed Kennell said: Yep, that's all folks. Betcha there's some 'blue goo' on it now? 2 Share this post Link to post Share on other sites
Ed Kennell 46,639 #12184 Posted July 12, 2021 The right spindle was the only one with loctite. Thay all have it now 4 1 Share this post Link to post Share on other sites
D_Mac 9,337 #12185 Posted July 13, 2021 Well since I have the flywheel off of the 500 Special to get new coil, points, and condenser. I thought I would do some more painting. The engine was not original and had nice paint on it but it was gray. Not anymore. I'm not going to paint the whole engine as the blower housing covers most of it. I will be painting the wheels when they come back from getting new tires mounted. I wanted to paint the wheels beforehand but didn't have time. 13 4 Share this post Link to post Share on other sites
Tuneup 1,459 #12186 Posted July 13, 2021 Dying to test that the tweak on the throttle cable on the 516 allows it to sit at 3600 instead of dropping over time. Fired it up and headed out to the tall grass - overdue since it's rained almost every day and I won't mow wet if I can help it. Hit the blades and all was well. Stopped after 50 feet and looked back. Scalping with the center and left??? Back to the garage to drop the deck and the left bracket bolt and spacer had decided to make a home somewhere in the lawn. This is how my machine tells me it needs maintenance. Found replacements from the parts of an old 36" stripped deck. Pulled the deck and, crap!, what a dirty clumped mess! So now it's to cleaning, pressure washing, lubing, blade sharpening and locktiting this 42 SD. The lawn can wait a few more days. 6 Share this post Link to post Share on other sites
OldWorkHorse 3,156 #12187 Posted July 13, 2021 (edited) Drilled a hole to run the battery cables on the 1257 through, reused a rubber ring off the Toro 117 that alone made the purchase worth it . Edited July 13, 2021 by OldWorkHorse 6 6 Share this post Link to post Share on other sites
D_Mac 9,337 #12188 Posted July 13, 2021 Well more progress on the 500 Special. New coil, points, and condenser installed. Pulled the head and going to clean it off and put in new head gasket. Going to run new fuel line and put in a shut off valve. Went and got a new drive belt from Tractor Supply. The tabs for the belt cover are all missing or busted. Going to have to jury rig something for that. Shouldn't be long now but tomorrow I go back to work again. 6 3 Share this post Link to post Share on other sites
sparkie333 265 #12189 Posted July 14, 2021 16 hours ago, D_Mac said: Shouldn't be long now but tomorrow I go back to work again. Yep work does put a bummer in the fun don't it? 1 1 Share this post Link to post Share on other sites
19richie66 17,930 #12190 Posted July 14, 2021 17 hours ago, D_Mac said: Well more progress on the 500 Special. New coil, points, and condenser installed. Pulled the head and going to clean it off and put in new head gasket. Going to run new fuel line and put in a shut off valve. Went and got a new drive belt from Tractor Supply. The tabs for the belt cover are all missing or busted. Going to have to jury rig something for that. Shouldn't be long now but tomorrow I go back to work again. I have a Tecumseh 7hp out of a 700 special. Let me know if you need anything. 1 Share this post Link to post Share on other sites
Tuneup 1,459 #12191 Posted July 15, 2021 I do love those tecs. The 516 has its deck again, cleaned and sharpened. The central arbor can use new bearings - a little rough. It can wait the season, though. She mowed the deep stuff wonderfully and the throttle stayed locked at 3500. Can't say enough good things about these old machines. They take some lovin' but it is always worth it. 3 Share this post Link to post Share on other sites
ebinmaine 79,754 #12192 Posted July 15, 2021 5 minutes ago, Tuneup said: Can't say enough good things about these old machines. They take some lovin' but it is always worth it. Absolutely agreed! I would even go so far as to say that shop time is part of the fun. 2 Share this post Link to post Share on other sites
D_Mac 9,337 #12193 Posted July 15, 2021 Got the new tires mounted and the rims painted for the 500 Special. Painted rims white to match the decals. Won't be long now until it's finished. 4 6 Share this post Link to post Share on other sites
Lee1977 7,712 #12194 Posted July 15, 2021 On 7/12/2021 at 6:55 PM, Jeff-C175 said: That little bitty bolt is all that holds that together? Later around 1975 or 1976 they went with a heavy cupped washer along with the little bitty bolt. 1 Share this post Link to post Share on other sites
Pullstart 70,820 #12195 Posted July 15, 2021 Tugged a heavy load into the back barn today. 8 horse powers was all I needed... and a little extra grip might have helped! 3 4 7 Share this post Link to post Share on other sites
Snoopy11 5,731 #12196 Posted July 15, 2021 (edited) 2 hours ago, pullstart said: Tugged a heavy load into the back barn today. 8 horse powers was all I needed... and a little extra grip might have helped! If I would have tried to pull that load with my 51 horse tractor, there would be nothing but rims left... LOL You should get some sticky compound for those tires!!! Don Edited July 15, 2021 by Snoopy11 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #12197 Posted July 15, 2021 On 7/14/2021 at 10:32 AM, 19richie66 said: I love the "100% Saved By Grace Sign" Don 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #12198 Posted July 15, 2021 Hoisted the colors today... 20210715_151658.mp4 5 6 1 Share this post Link to post Share on other sites
ebinmaine 79,754 #12199 Posted July 15, 2021 44 minutes ago, Snoopy11 said: I love the "100% Saved By Grace Sign" Don I have a distant cousin named Grace but I'm not sure what she's ever saved 2 Share this post Link to post Share on other sites
WHX?? 57,472 #12200 Posted July 15, 2021 What flavor and your source are those rears @D_Mac? I like those ...kinda like a town & country but not. 4 1 Share this post Link to post Share on other sites
