sparkie333 265 #8976 Posted January 30, 2021 3 hours ago, Tuneup said: P216 gets its other head done today so might have it running next weekend. I see that 16HP on the work bench --looking good. Share this post Link to post Share on other sites
sparkie333 265 #8977 Posted January 30, 2021 2 minutes ago, squonk said: 615 Narrows Rd. Biglerville Pa. is the proper GPS address On your Electrician quote----We always said ---Let a Electrician Remove your Shorts. ---Just saying. 2 Share this post Link to post Share on other sites
squonk 46,807 #8978 Posted January 30, 2021 1 minute ago, sparkie333 said: On your Electrician quote----We always said ---Let a Electrician Remove your Shorts. ---Just saying. That might not always be a desirable outcome! 1 2 Share this post Link to post Share on other sites
sparkie333 265 #8979 Posted January 30, 2021 I'm stilling having trouble when I get a --Notification from you guys I click on it and it don't go to you guys. 1 minute ago, squonk said: That might not always be a desirable outcome! Yep but if you just going to check might not find what u looking for. IMHP. 1 Share this post Link to post Share on other sites
haydendavid380 759 #8980 Posted January 30, 2021 17 hours ago, Gregor said: While on the subject, what's the farthest you have driven, to pick up a Wheel Horse. 7 hours round trip for me. About the same here. Was towards the middle of last year for a $125 running tractor 1 Share this post Link to post Share on other sites
JohnD 145 #8981 Posted January 30, 2021 4 hours ago, Flat Thunder Channel said: Anyone have a standard tube size / part number available? I couldn't find one in my search with the correct valve stem. Partstree shows the tube for a 16x6.5-8 is Toro 105293 (112819) for $27.48 TSC has this one available for $7.99. Valve stem type: straight (TR-13), can you tell if that is what you need? https://www.tractorsupply.com/tsc/product/martin-wheel-16x650-8-16x750-8-18x650-8-tr13-inner-tube-1128224 1 Share this post Link to post Share on other sites
sparkie333 265 #8982 Posted January 30, 2021 4 minutes ago, squonk said: That might not always be a desirable outcome! I don't know what it is but when I get nOTIFI 1 minute ago, JohnD said: 4 hours ago, Flat Thunder Channel said: When I thought I was going to use a tube there was one that could be used in several of the different size front tires. they don't have to be exact. Just kinda close ---some times they will tell you when you are looking them up on the web. Good Luck. 1 Share this post Link to post Share on other sites
sparkie333 265 #8983 Posted January 30, 2021 Guys I'm having trouble getting to you when I get a Notification from you. I will try to just quote on you if i get one sorry.. Share this post Link to post Share on other sites
haydendavid380 759 #8984 Posted January 30, 2021 26 minutes ago, sparkie333 said: I agree must be clean --works the best--great to see the fix. This is how it came out after putting a wire wheel on it to knock off all the rust Sprayed it down with brake cleaner, spread glue down to both surfaces, and clamped it for about 4 hours Got everything back together once the glue was tacky enough to hold the material to the back during installation, and then tightened it down and set the parking brake. Hopefully everything will be golden by tomorrow morning to shove around some snow. 4 1 Share this post Link to post Share on other sites
ebinmaine 79,098 #8985 Posted January 30, 2021 2 minutes ago, sparkie333 said: quote on you Nothing wrong with that. I do it quite often. Especially in a busy thread. That way there's a reminder of what you are writing about. 1 Share this post Link to post Share on other sites
sparkie333 265 #8986 Posted January 30, 2021 Just now, ebinmaine said: do it quite often. Just now, ebinmaine said: othing wrong with that. I do it quite often. Ok I got to you that way--thanks 1 Share this post Link to post Share on other sites
sparkie333 265 #8987 Posted January 30, 2021 3 minutes ago, haydendavid380 said: Hopefully everything will be golden by tomorrow morning to shove around some snow. Looks good I'm sure every thing will work out fine. 2 Share this post Link to post Share on other sites
sparkie333 265 #8988 Posted January 30, 2021 7 minutes ago, haydendavid380 said: This is how it came out after putting a wire wheel on it to knock off all the rust Sprayed it down with brake cleaner, spread glue down to both surfaces, and clamped it for about 4 hours Got everything back together once the glue was tacky enough to hold the material to the back during installation, and then tightened it down and set the parking brake. Hopefully everything will be golden by tomorrow morning to shove around some snow. I yot your note but there was not any thing said is this the way it works? Share this post Link to post Share on other sites
sparkie333 265 #8989 Posted January 30, 2021 9 minutes ago, ebinmaine said: That way there's a reminder of what you are writing about. I got your notification but I clicked on it and found you but nothing was said is this normal? Share this post Link to post Share on other sites
sparkie333 265 #8990 Posted January 30, 2021 14 minutes ago, haydendavid380 said: This is how it came out after putting a wire wheel on it to knock off all the rust That looks real good should do the trick. 1 Share this post Link to post Share on other sites
Flat Thunder Channel 178 #8991 Posted January 30, 2021 30 minutes ago, JohnD said: Partstree shows the tube for a 16x6.5-8 is Toro 105293 (112819) for $27.48 TSC has this one available for $7.99. Valve stem type: straight (TR-13), can you tell if that is what you need? https://www.tractorsupply.com/tsc/product/martin-wheel-16x650-8-16x750-8-18x650-8-tr13-inner-tube-1128224 The ones I found had the valve stem directly in the middle. I think/thought they need to be offset. Not 100% sure 1 Share this post Link to post Share on other sites
twiisted71 51 #8992 Posted January 30, 2021 (edited) I finally had enough of wires breaking in the original harness on my C-81! So I started gutting all the wires on the machine except the regulator harness and removed all the nanny devices designed to keep it from running! In the process I started making other discoveries: The rock hard original fuel hose was behaving more like a sponge and the prev owner had punched a hole through the inline fuel filter!!!! My gear shift boot was nothing more than a rubber band left on the shift handle. The muffler also had a couple holes blown out the end cap and a broken lower mounting tab. So she now has new wiring (minimal-no lights, horn etc), coil, condensor, fuel line, filter, shifter boot, and nicely welded up and solidly mounted exhaust! I was surprised how much quieter it is now. Edited January 30, 2021 by twiisted71 6 3 Share this post Link to post Share on other sites
ebinmaine 79,098 #8993 Posted January 30, 2021 2 hours ago, sparkie333 said: I got your notification but I clicked on it and found you but nothing was said is this normal? Not sure. One of the mods might be able to narrow it down for you. Each system varies a little. 1 Share this post Link to post Share on other sites
953 nut 66,468 #8994 Posted January 30, 2021 21 hours ago, Gregor said: Someone tell me again, when and where is the "big show". All I know for sure is a fairgrounds some place, the Friday after Fathers Day. I need to Mapquest it. Thanks Greg Keep checking in on the Wheel Horse Collectors Face Book page for the latest information. https://www.facebook.com/WheelHorseCollectorsClub/ 1 Share this post Link to post Share on other sites
ebinmaine 79,098 #8995 Posted January 31, 2021 2 hours ago, twiisted71 said: new wiring Nice work. Oddly enough I find wiring tractors to be quite relaxing. 2 Share this post Link to post Share on other sites
Horse Newbie 7,404 #8996 Posted January 31, 2021 Okay, so today I finally painted the center of my 520H hubcaps...an idea I stole from @WVHillbilly520H... 3 6 Share this post Link to post Share on other sites
JohnD 145 #8997 Posted January 31, 2021 4 hours ago, Flat Thunder Channel said: The ones I found had the valve stem directly in the middle. I think/thought they need to be offset. Not 100% sure If you find the right one, please share it in a new thread. Things get too buried in this thread! 2 Share this post Link to post Share on other sites
Horse Newbie 7,404 #8998 Posted January 31, 2021 So today I disassembled my hydraulic control valve on my 1994 520H...the shaft was coming too far out of the front of the valve body exposing the o- ring ( not sure if this was the source of leak )... looked at parts list for the valve body and discovered that I was missing the small washer and screw that goes on the left end of the shaft that runs through the valve body. 4 1 Share this post Link to post Share on other sites
JohnD 145 #8999 Posted January 31, 2021 6 minutes ago, Horse Newbie said: Okay, so today I finally painted the center of my 520H hubcaps...an idea I stole from @WVHillbilly520H... Nice caps! I like the tread on those tires the caps are sitting on. What brand and model are those tires? 1 1 Share this post Link to post Share on other sites
sparkie333 265 #9000 Posted January 31, 2021 18 minutes ago, Horse Newbie said: Okay They look great to me. 1 Share this post Link to post Share on other sites
