lynnmor 9,026 #7276 Posted October 26, 2020 11 hours ago, ArturHawk said: At least it's not pigeon toed. 1 Share this post Link to post Share on other sites
ArturHawk 195 #7277 Posted October 26, 2020 10 minutes ago, ebinmaine said: I understand that some of the Kohler carbs can be adapted on and it's been known to make a good difference in running quality. If this other carb doesn't work, that's what i'll do next. My 12hp kohler runs like a champ. 1 Share this post Link to post Share on other sites
8ntruck 9,246 #7278 Posted October 26, 2020 7 hours ago, ebinmaine said: Definitely understandable. Fine dust settles on everything really well. I haven't messed with the carburetor on a Tecumseh engine but I understand that some of the Kohler carbs can be adapted on and it's been known to make a good difference in running quality. @pullstart - didn't you make this conversion on one of your machines? 1 1 Share this post Link to post Share on other sites
Pullstart 71,160 #7279 Posted October 26, 2020 On 10/21/2020 at 9:07 PM, 8ntruck said: Did some more cart work today, hauling 5 boxes of books down to the lake house. More mulching of leaves along the way. Rained last night, knocking , more leaves to the ground. Will have to mulch or tow the sweeper around in the near future. Gripe for today: I filled up yesterday at $1.78 per gallon. Drove by the gas station this evening and noticed the price was up to $2.15 per gallon. Anybody understand what drives these large price changes? Sure wish I did. I must have missed the dip in price, but at least you didn’t wait to fill up! Share this post Link to post Share on other sites
8ntruck 9,246 #7280 Posted October 26, 2020 3 minutes ago, pullstart said: I must have missed the dip in price, but at least you didn’t wait to fill up! Seems to be a local thing. South of M57, gas prices are frequently 10 to 20 cents higher. 1 Share this post Link to post Share on other sites
Pullstart 71,160 #7281 Posted October 26, 2020 7 hours ago, ebinmaine said: Definitely understandable. Fine dust settles on everything really well. I haven't messed with the carburetor on a Tecumseh engine but I understand that some of the Kohler carbs can be adapted on and it's been known to make a good difference in running quality. yep, I did that with “Jane”, my Commando 6 Tecky powered rig. A worn out old K-161 carb runs great on it! Share this post Link to post Share on other sites
Pullstart 71,160 #7282 Posted October 26, 2020 Hung a Wheel Horse sign in the barn... 1 3 2 Share this post Link to post Share on other sites
Pullstart 71,160 #7283 Posted October 26, 2020 Showed Mrs. P the newest member of her collection... Thank you so much, @Bow_Extreme for your leg work in this matter! 3 3 10 Share this post Link to post Share on other sites
Pullstart 71,160 #7284 Posted October 26, 2020 2 1 11 Share this post Link to post Share on other sites
Jhook 849 #7285 Posted October 26, 2020 More progress today. Have about 45 mins after work to weld some mounting plates for the motor on the frame. Im by no means an experienced welder. Im practicing and learning as i go. They are no where near good welds but for this little engine they should hold. And if they dont, no big deal i can fix it and make it stronger as i learn more. These 3/16x3 inch flat stock will give me plenty of room to shift the engine side to side and forward and back as i fine tune it for my final installation. I am going to try my best to get it perfect and have only 4 holes rather than a slotted plate for adjustment. 4 1 Share this post Link to post Share on other sites
Bostman67 54 #7286 Posted October 26, 2020 23 hours ago, 953 nut said: The light is a Generator Indicator light and will go out if the generator is working. The replacement light is Cole-Hersee PL 20 RC. This diagram will help. https://www.amazon.com/Dorman-84926-Red-Indicator-Light/dp/B003SYWZZS Thhis is the switch I purchased. Seems similar to the others. Share this post Link to post Share on other sites
johnnymag3 2,646 #7287 Posted October 26, 2020 35 minutes ago, Jhook said: More progress today. Have about 45 mins after work to weld some mounting plates for the motor on the frame. Im by no means an experienced welder. Im practicing and learning as i go. They are no where near good welds but for this little engine they should hold. And if they dont, no big deal i can fix it and make it stronger as i learn more. These 3/16x3 inch flat stock will give me plenty of room to shift the engine side to side and forward and back as i fine tune it for my final installation. I am going to try my best to get it perfect and have only 4 holes rather than a slotted plate for adjustment. Looks good to me !!!!! That plate wont move 2 Share this post Link to post Share on other sites
953 nut 68,831 #7288 Posted October 26, 2020 It probably will work. I have LED lights that I added to one of my tractors and the headlight bar was polarity sensitive but the rears didn't seem to mater. The idea with the generator light is that when the generator is working the light goes out because the voltage on both sides is about equal so there is little or no electrical current flowing through the bulb. The minimal amount of current required by an LED may prevent it from going out. Give it a try and let us know how it comes out. 1 1 Share this post Link to post Share on other sites
953 nut 68,831 #7289 Posted October 26, 2020 1 hour ago, pullstart said: newest member of her collection.. Share this post Link to post Share on other sites
Jhook 849 #7290 Posted October 26, 2020 4 minutes ago, johnnymag3 said: Looks good to me !!!!! That plate wont move Thanks, 2 plates! One for the front 2 holes and one for the rear 2. Could have done one big plate but this 3 inch flat stock was most easily accessible. Also no expert on engine swapping. Ive pulled and replaced dozens, but never one that isnt supposed to be in the machine. Going smooth so far. Good project to learn on with such a small machine and simple pullstart engine. Impressed with the new 125 welder from harbor freight though, weighs only 14 pounds and is about the size of a 6 pack! 5 Share this post Link to post Share on other sites
tom2p 2,396 #7291 Posted October 26, 2020 1 hour ago, pullstart said: Showed Mrs. P the newest member of her collection... Thank you so much, @Bow_Extreme for your leg work in this matter! nice - two thumbs up ! 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,799 #7292 Posted October 26, 2020 1 hour ago, pullstart said: Hope no one tells her you were aiming for the tractor..oops 1 6 Share this post Link to post Share on other sites
pfrederi 21,097 #7293 Posted October 26, 2020 56 minutes ago, Bostman67 said: https://www.amazon.com/Dorman-84926-Red-Indicator-Light/dp/B003SYWZZS Thhis is the switch I purchased. Seems similar to the others. Hard to tell from the description but based on comments where it was used This is NOT the correct light. If there is any continuity between either of the terminals and the housing it is wrong. This one will work. note that the lens is somewhat smaller than the original if you are a rivet counter...Cole Hersee Pilot Light PL-20-RC000-BX 1 Share this post Link to post Share on other sites
tom2p 2,396 #7294 Posted October 26, 2020 pullstart - forgot you have the old chevy truck - soon the girls will be driving it ! 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,292 #7295 Posted October 26, 2020 Well done @pullstart!!! One night out of the doghouse for you... One question - Did she like the color? 1 3 Share this post Link to post Share on other sites
19richie66 17,932 #7296 Posted October 26, 2020 @pullstart A senior! Great addition and a smile from momma. 2 1 Share this post Link to post Share on other sites
8ntruck 9,246 #7297 Posted October 27, 2020 @pullstart - looks like I need to come up with some sort of excuse to visit. Mabe take your new acquisition for a turn around the yard while I'm there. 1 Share this post Link to post Share on other sites
Mark Bartlett 83 #7298 Posted October 27, 2020 Built a rear hitch today. I spent a career in the oilfield industry where the moto is, "when in doubt go he_ _ for stout". 2 5 Share this post Link to post Share on other sites
ohiofarmer 3,475 #7299 Posted October 27, 2020 12 hours ago, pullstart said: I must have missed the dip in price, but at least you didn’t wait to fill up! i try to always keep my powder dry when it comes to gas prices. We build up kroger fuel points and on occasion they run specials of gift cards for 4 times the normal amount. when you go to the Kroger fuel price app, they give you the lowest prices in the state. If local prices are pretty close to the bottom statewide, you have at the most, a bit more than one day to cash in. So locally, they hit $1.81 and we had a dollar off a gallon. I bought the maximim of 35 gallons for $28.70 4 Share this post Link to post Share on other sites
953 nut 68,831 #7300 Posted October 27, 2020 13 hours ago, Bostman67 said: https://www.amazon.com/Dorman-84926-Red-Indicator-Light/dp/B003SYWZZS Thhis is the switch I purchased. Seems similar to the others. Please start your own thread on this subject. Having in the midst of a general thread with over 7,000 posts is not beneficial to you and will not be helpful to people searching the site for information about S/G indicator lights. Share this post Link to post Share on other sites
