ebinmaine 79,208 #4801 Posted May 18, 2020 3 minutes ago, Achto said: steel I'd recommend it. 2 Share this post Link to post Share on other sites
danweikert21 166 #4802 Posted May 18, 2020 I’m working on my exhaust and I want to put a vertical exhaust on it. Like the big farm tractors. Does anyone know how to do that and what parts I need. I’m new to this 4 Share this post Link to post Share on other sites
SylvanLakeWH 31,575 #4803 Posted May 18, 2020 May want to contact @jimkemp. He does the stack mufflers... 3 Share this post Link to post Share on other sites
ebinmaine 79,208 #4804 Posted May 18, 2020 6 minutes ago, Raider10danweikert said: I’m working on my exhaust and I want to put a vertical exhaust on it. Like the big farm tractors. Does anyone know how to do that and what parts I need. I’m new to this Couple different ways that you could do it is to purchase a muffler for a Cub model 125. Run a horizontal with an elbow out of your engine and over to the pipe that goes into the muffler. That becomes your stack effectively. Another way would be to contact a member of ours named Jim Kemp. Jim makes little stack mufflers for these garden tractors and does a great job at it. 1 Share this post Link to post Share on other sites
danweikert21 166 #4805 Posted May 18, 2020 3 minutes ago, ebinmaine said: Couple different ways that you could do it is to purchase a muffler for a Cub model 125. Run a horizontal with an elbow out of your engine and over to the pipe that goes into the muffler. That becomes your stack effectively. Another way would be to contact a member of ours named Jim Kemp. Jim makes little stack mufflers for these garden tractors and does a great job at it. Yeah thank you I appreciate it. Like I said I don’t have much experience with this stuff so I don’t know what to look for when I’m buying parts I’ll take a look at Jim’s profile 1 Share this post Link to post Share on other sites
danweikert21 166 #4806 Posted May 18, 2020 How do I find his profile Share this post Link to post Share on other sites
ebinmaine 79,208 #4807 Posted May 18, 2020 6 minutes ago, Raider10danweikert said: Yeah thank you I appreciate it. Like I said I don’t have much experience with this stuff so I don’t know what to look for when I’m buying parts I’ll take a look at Jim’s profile I'm not actually sure how to find his profile. I do know how to send him a message but I'm not sure if that's his only contact. Possibly check the Vendors section and see if he's listed in there. If you want to see pictures of either of the two exhausts that I mentioned I could take a couple when I get home. Share this post Link to post Share on other sites
danweikert21 166 #4808 Posted May 18, 2020 Sure that sounds good. thank you 1 Share this post Link to post Share on other sites
squonk 46,937 #4809 Posted May 18, 2020 8 minutes ago, Raider10danweikert said: How do I find his profile Just click on this blue @jimkemp icon. It takes you to his profile. Click message and type away! 3 2 Share this post Link to post Share on other sites
danweikert21 166 #4810 Posted May 18, 2020 thank you 1 Share this post Link to post Share on other sites
Pullstart 70,133 #4811 Posted May 18, 2020 37 minutes ago, danweikert21 said: I’m working on my exhaust and I want to put a vertical exhaust on it. Like the big farm tractors. Does anyone know how to do that and what parts I need. I’m new to this I like stacks! Pipe fittings, some clamps, some support here and there and a good imagination... you’ll be stacked in no time! 3 Share this post Link to post Share on other sites
danweikert21 166 #4812 Posted May 18, 2020 Awesome like the tractors man Share this post Link to post Share on other sites
Pullstart 70,133 #4813 Posted May 18, 2020 10 minutes ago, danweikert21 said: Awesome like the tractors man There’s a couple around here... 2 1 2 Share this post Link to post Share on other sites
danweikert21 166 #4814 Posted May 18, 2020 question, I need to remove the old muffler but it is rusted on. Two hex polts are holding it to the block I cant seem to get it loose could i use a torch to heat it up causing it to loosen? Share this post Link to post Share on other sites
Pullstart 70,133 #4815 Posted May 18, 2020 14 minutes ago, danweikert21 said: question, I need to remove the old muffler but it is rusted on. Two hex polts are holding it to the block I cant seem to get it loose could i use a torch to heat it up causing it to loosen? could you share a picture of what you’re working with? Maybe you could cut the pipe and slip a stack on and clamp it? 1 Share this post Link to post Share on other sites
Sam Pasch 450 #4817 Posted May 18, 2020 Maybe this can help. 3 1 Share this post Link to post Share on other sites
danweikert21 166 #4818 Posted May 18, 2020 yes thank you 1 Share this post Link to post Share on other sites
Sam Pasch 450 #4819 Posted May 18, 2020 No problem.☺ Share this post Link to post Share on other sites
ebinmaine 79,208 #4820 Posted May 18, 2020 6 hours ago, ebinmaine said: see pictures of either of the two exhausts that I mentioned I could take a couple when I get home 6 hours ago, danweikert21 said: Sure that sounds good. thank you @danweikert21 Here's a few pics of the 2 I have. Patriot Horse (Red, white and blue) is an 8 horse Kohler using the Cub muffler turned up to be a stack. I normally have a piece of chrome pipe on top like the other one. Cinnamon Horse C160 has a @jimkemp custom on it with a piece of chrome bathroom floor drain pipe I cut/fit to add height and prettyfulness. Note the bracket I fabbed for the Cinnamon exhaust. It's a fair amount of weight and vibration to be relying on the engine block alone. 6 Share this post Link to post Share on other sites
WHX?? 56,933 #4821 Posted May 19, 2020 (edited) Found out another one of our favorite tractor shows is cancelled.... got ticked off and went to the bar... sickel bar that is.... got the wobble box put together.... i think....now just to figure out how this pile of parts goes together. Thinkin this thing is gonna be a pita to put on a tractor so we all know what that means! Shus up ... she don't havta know it will fit on one we have... Edited May 19, 2020 by WHX24 6 2 Share this post Link to post Share on other sites
ClevelandBrown 47 #4822 Posted May 19, 2020 I should have some pictures soon of the RM 367 deck I'm rebuilding. But in the meantime, I'll share a picture of my boys and me prepping the front yard for sod. The boys were my weights for the drag. And the 867 pulled beautifully! 2 5 6 Share this post Link to post Share on other sites
Tractorhead 9,217 #4823 Posted May 19, 2020 7 hours ago, Sam Pasch said: Maybe this can help. Nice Cupholder also 👍 😁 2 2 Share this post Link to post Share on other sites
Copper116 63 #4824 Posted May 19, 2020 Well, after spending weeks getting it brought back to life and ready to mow, I trailered my C-101 up to our deer camp, planning on using it on a small food plot to keep the weeds down. I had torn it down over the past weeks, after it had set for a year+. While riding it through the woods on a two track, I caught the deck on some heavy oak root and knocked it off it's carrier and breaking the spacers on the mower deck carriage. After limping and dragging the mower and deck back to camp, I removed the deck and hauled it home for repairs. Other than noticing a small oil leak from the valve cover, the tractor is running very well. Once I get the parts, I'll find another way of getting it to where it needs to go, hopefully without incident. Maybe trailer it in if it'll fit down those paths. 2 Share this post Link to post Share on other sites
ebinmaine 79,208 #4825 Posted May 19, 2020 4 minutes ago, Copper116 said: trailer That was the first thought I had. Probably your best idea. Adaptability is key sometimes. 1 Share this post Link to post Share on other sites
