Lee1977 7,365 #2876 Posted August 15, 2019 I used one like that on my 520, put a 5 amp fuse in the line connect it to the switch also put a toggle switch on the dash. I can run it out of gas for storage If I don't plan to use it for a while. 6 Share this post Link to post Share on other sites
pfrederi 18,895 #2877 Posted August 15, 2019 (edited) I used a cheap electric pump like that on a C-141 it failed after only a few hours ... a long way from the shop of course and her front mount mower made recovery all the more difficult. I have Facet posiflo pumps on three tractors, two for several years no issues.... Edited August 15, 2019 by pfrederi 2 Share this post Link to post Share on other sites
WildmanC120 613 #2878 Posted August 15, 2019 49 minutes ago, pfrederi said: I used a cheap electric pump like that on a C-141 it failed after only a few hours ... a long way from the shop of course and her front mount mower made recovery all the more difficult. I have Facet posiflo pumps on three tractors, two for several years no issues.... I have also had 2 of those die recently. Just replaced them with the Facet as recommend here. Will see if that works better. 2 Share this post Link to post Share on other sites
Lee1977 7,365 #2879 Posted August 15, 2019 With all these companies engineering things to fail shortly after the guarantee runs out. I don't think what or where you buy or how much you payed makes much difference. It's all a crap shoot it might work or it might not and they are hopeing it last longer then the guarantee. 3 Share this post Link to post Share on other sites
TonyToro 1,132 #2880 Posted August 16, 2019 On 8/14/2019 at 7:04 AM, pullstart said: I’m glad nobody was hurt! Without a picture of the damage, I’d suggest heat and a hammer will put it back for ya! I smash on it for while to get it “Good Enough”. I’ll take a picture of the spindle tomorrow. Share this post Link to post Share on other sites
posifour11 723 #2881 Posted August 16, 2019 On 8/10/2019 at 1:12 PM, 953 nut said: Meed to put a belt guard on that woods tractor. Lot less gear grinding then. @953 nut, I did you one better. Because I remembered that I stole this drive belt off of a parts tractor and it was in bad shape to start with. I replaced it today and I'm going to put the belt guard on in the morning. You guilted me into being a good horse owner. 😁 1 2 Share this post Link to post Share on other sites
ebinmaine 74,328 #2882 Posted August 16, 2019 5 hours ago, posifour11 said: You guilted me into being a good horse owner. 😁 That's what you get for hangin' around these parts... 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2883 Posted August 17, 2019 Paint was cured enough on my wheel weights to put them on the tractor today. Sure did improve the looks! 2 6 1 Share this post Link to post Share on other sites
ebinmaine 74,328 #2884 Posted August 17, 2019 We just spent about 4 hours cutting wood and clearing brush. We cleared about 250 - 350 feet of path. Almost to the back of the property now. Also cut down a BUNCH of small white pines to give breathing and sun space to the hardwoods. Also cut up a red oak which will be for firewood in a season or two. This section of the path begins back around the white poplar that's laying on the forest floor. Zoom in just above the tractor seat and you can see the pile of oak fire wood. There's a path cut from here to there... Then to the left and around the corner and another couple hundred feet down in... We're almost all the way to the back of the property now. Awesome. 8 1 1 Share this post Link to post Share on other sites
pfrederi 18,895 #2885 Posted August 18, 2019 Made a modification to Matts Foot Control on my 418A. Bought it several years ago and then took a couple years to install it. It gets really hard to work sometimes. Turns out the steel bushing that slides up and down in bracket #2 Doesn't slide nicely. Getting lube on it is not straight forward and if you look at the picture you can see where a groove has been worn in the bushing. I put in a longer bolt and a jam nut on tighten it to the bracket so now the bushing can spin on the bolt. I know this will wear over time but if it works out I will come up with a oilite bearing on the bolt and a steel bushing over that. 3 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2886 Posted August 18, 2019 Put the blade back on IRV proceeded to push some dirt in the woods back behind my house. This is one strong a little beast. It's amazing what a little weight will do for the backend of these machines. 3 Share this post Link to post Share on other sites
Herder 2,355 #2887 Posted August 18, 2019 On 8/17/2019 at 3:22 PM, ebinmaine said: We just spent about 4 hours cutting wood and clearing brush. We cleared about 250 - 350 feet of path. Almost to the back of the property now. Also cut down a BUNCH of small white pines to give breathing and sun space to the hardwoods. Also cut up a red oak which will be for firewood in a season or two. This section of the path begins back around the white poplar that's laying on the forest floor. Zoom in just above the tractor seat and you can see the pile of oak fire wood. There's a path cut from here to there... Then to the left and around the corner and another couple hundred feet down in... We're almost all the way to the back of the property now. Awesome. That's what I'm talking about. Beautiful property EB, I just have to make it to retirement and I will see you in Maine. Share this post Link to post Share on other sites
Herder 2,355 #2888 Posted August 18, 2019 10 minutes ago, The Tool Crib said: Put the blade back on IRV proceeded to push some dirt in the woods back behind my house. This is one strong a little beast. It's amazing what a little weight will do for the backend of these machines. Ya and they look good too. 1 Share this post Link to post Share on other sites
ebinmaine 74,328 #2889 Posted August 18, 2019 13 minutes ago, Herder said: That's what I'm talking about. Beautiful property EB, I just have to make it to retirement and I will see you in Maine. You come on up and visit. 1 Share this post Link to post Share on other sites
Lee1977 7,365 #2890 Posted August 18, 2019 (edited) 1 hour ago, pfrederi said: Made a modification to Matts Foot Control on my 418A. Bought it several years ago and then took a couple years to install it. It gets really hard to work sometimes. Turns out the steel bushing that slides up and down in bracket #2 Doesn't slide nicely. Getting lube on it is not straight forward and if you look at the picture you can see where a groove has been worn in the bushing. I put in a longer bolt and a jam nut on tighten it to the bracket so now the bushing can spin on the bolt. I know this will wear over time but if it works out I will come up with a oilite bearing on the bolt and a steel bushing over that. That bushing looks to be the size of a no. 688 roller skate bearing. it's 8mm ID is just .003 over 5/16" and the OD is 16 mm just ,0049 over 5/8" you need two as they are only 5mm wide. Edited August 18, 2019 by Lee1977 2 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2891 Posted August 18, 2019 19 minutes ago, Herder said: Ya and they look good too. I had to switch out the wheels on the front to my 6 inch because I'm having troubles getting the blade to go down low enough. So the wheels don't match ! Oh well dont really care about style its all about functionality ! 1 Share this post Link to post Share on other sites
TonyToro 1,132 #2892 Posted August 19, 2019 On 8/15/2019 at 8:38 PM, TonyToro said: I smash on it for while to get it “Good Enough”. I’ll take a picture of the spindle tomorrow. Here is the left spindle that was bent along side of the parts tractor spindle. I used a pipe wrench and a 3lb hammer to get it close enough to use. I am thinking I should make a pair of adjustable tie rods. 1 Share this post Link to post Share on other sites
8ntruck 8,109 #2893 Posted August 19, 2019 I haven't done anything with mine for a couple of weeks. The grass is crispy brown and we haven't had much rain to correct that. Most of my time has been spent putting new flooring into the lake house. Still have two bedrooms to finish. I did put a want ad into the classifieds for a 42" RD deck. Maybe something will come of it. Share this post Link to post Share on other sites
Pullstart 68,005 #2894 Posted August 19, 2019 Big Junky is getting some attention today. To pull fuel into the carb, I normally have to cover the carb completely with my hand and make sure the tank is full. I’ve been meaning to swap on a pump from a broken rod engine.... since this tractor has obviously had some fuel issues in the past. It’s now pumping and will start on it’s own! Why should I work on this beast, when I’ve got nicer looking workers? It’s heavy and has a drawbar AND slot hitch... so I can spread chicken poo from a trailer AND disc the food plot... that’s why Some day, Big Junky will be complete when this Big Junky stack finds it’s way on! 3 3 Share this post Link to post Share on other sites
Pullstart 68,005 #2895 Posted August 19, 2019 What more fitting, than using the Polished Turd to bring spares out to Big Junky! I was cruising along and believe to have lost spark. I have two coils and a new set of points to try out today! 4 2 1 Share this post Link to post Share on other sites
Pullstart 68,005 #2896 Posted August 19, 2019 I believe my issue was the points, but the funny thing was that it ran great for a few minutes, died, sat for a while, fired back up... like a weak coil would act. I replaced the coil, and it did the same thing. I never touched the points, trying one thing at a time. It fired back up, ran for a few minutes, then died again! I swapped my spare set in and whalla! It worked and I’m back in business! 5 2 Share this post Link to post Share on other sites
Burnerman 759 #2897 Posted August 19, 2019 I removed the hardware store spring and put a brand new Toro clutch spring on my C101. I wheelied right outta the garage! 😲 I wasn’t ready for that. 😂 What a difference!! 1 1 6 Share this post Link to post Share on other sites
ebinmaine 74,328 #2898 Posted August 19, 2019 8 minutes ago, Burnerman said: I removed the hardware store spring and put a brand new Toro clutch spring on my C101. I wheelied right outta the garage! 😲 I wasn’t ready for that. 😂 What a difference!! Well done! Share this post Link to post Share on other sites
adsm08 3,564 #2899 Posted August 19, 2019 Not a got-dang thing. Haven't even used it in two weeks. It didn't rain for 8 says after my last mow, and the grass hasn't recovered from the end of last week. I got a nice box from Lane yesterday though. Took it down to work hoping to clean up the new pump a bit over lunch, got busy and ended up working through lunch instead. Share this post Link to post Share on other sites
TonyToro 1,132 #2900 Posted August 20, 2019 One of the guys from the pulling club came by and got my Sons pulling tractor Good Ole Rusty the Raider 12 running! My son is so happy. I’m pretty relieved as well. From what we can tell it was just bad grounding from the block to the Chevy points bracket. Although we installed a new ignition switch(because the old one was smoking when we were cranking it... lol), new spark plug, cleaned up the valves and the head. Now it actually starts right away, not like before when it had to crank for a few revolutions before firing off. 2 1 Share this post Link to post Share on other sites
