sqrlgtr 4,224 #26801 Posted October 8 1 hour ago, peter lena said: @sqrlgtr got one for you , as usual HIDING IN PLANE SITE ! your front end tie rod area , nice improvement on that , been using heim joints for years , no failures , anyway , pto outer swing arm clip , with round hole end ? directly RELATED TO THAT ? HITCH PIN CLIP ON FRAME ,? what could you possibly do ? connect the loops wit a medium pull hooked extension spring ? you know what that does ? STOPS THE RELATED BUZZING AND RATTELING , TA DA ! as a millwright I was always looking for a problem elimination , BTW ANY BEARING I have with rubber side shields , guess what ? carefully remove shield , wipe out , carb cleaner flush . LUCAS GREEN XTRA HD , CHASSIS GREASE , walmart $ 7 , specs 550 deg flash point , polyurea , stays with bearing , WHAT A CONCEPT ! these COLLECTIVE DETAILS ARE A GAME CHANGER , my 3 horses are loaded with them , years in , no issues OR FAILURES , dare to try something , let me know , pete Agreed Pete, Ive made a few tie rods up for some of my other tractors but don't believe the Heim joints would look right on the 701. here is a couple/3 pics. The bottom pic is the 701 and they are different design than the later models. 8 Share this post Link to post Share on other sites
Bar Nuthin 3,642 #26802 Posted October 8 23 minutes ago, sqrlgtr said: Ive made a few tie rods Are you turning the rods yourself. I'd love to get my tractors converted over. 2 Share this post Link to post Share on other sites
sqrlgtr 4,224 #26803 Posted October 8 (edited) 15 minutes ago, Bar Nuthin said: Are you turning the rods yourself. I'd love to get my tractors converted over. yeah, just repurposed old tie rods. Ive used the older ones that were not threaded on either end and some of the later ones that were already threaded on one end. Turn and thread to a left-hand thread so they are easily adjustable. Really helps when you want to center the steering wheel up also. Edited October 8 by sqrlgtr 1 3 Share this post Link to post Share on other sites
peter lena 10,125 #26804 Posted October 8 @sqrlgtr , initially used threaded rod on my tie rod ends / flat heim joints , as a durability test , guess what ? many years in , no failures or issues , slide a hose over the threaded rod , it disappears . dialed in same original tie rod measurement , been bombproof , pete 3 1 Share this post Link to post Share on other sites
Racinbob 13,290 #26805 Posted October 8 I've made several pairs over the years using 3/8"-24 threaded rod with 3/8" ID steel tube over it. Also made them with heims. 1 10 Share this post Link to post Share on other sites
Lane Ranger 12,167 #26806 Posted October 8 I put a different Schnacke recoil on my patina 1958 RJ today! i had Joe Papke replace a spring and stainless steel cable in my spare Schnacke recoil! This old motor with the Schancke starts on the first pull! I changed oil in the oil bath air cleaner and motor! Still smokes a bit but runs best of any Kohler I own! I also changed air filter in my 314-8 today! 1 13 Share this post Link to post Share on other sites
702854boy 1,245 #26807 Posted October 8 On Tuesday we were able to snag a 6 speed for a Ulysses S Grant 7 4 Share this post Link to post Share on other sites
sqrlgtr 4,224 #26808 Posted October 8 Replaced front axle pivot pin/bolt, drilled drag link out and made a couple bushings on lathe for drag link on 701. I didnt relize how wore everything was until I really got to looking closer at front end. My niece was driving it around the other day and I could see it better watching it go by I guess . 6 6 Share this post Link to post Share on other sites
peter lena 10,125 #26809 Posted October 9 @Lane Ranger l ike chain and cable lube on any cable , keeps its very supple , also been using rislone Zink additive in all my oils for years , biggest , gain ? engine VARNISH KILLER , none of my engines smoke , oil changes are like a , hot coal oil flush , also like your vintage oiled paint look , looks perfect to me , valvoline oil makes a classic flat tappet oil . personally can hear and feel a easier running ease , always trying something , pete 1 Share this post Link to post Share on other sites
peter lena 10,125 #26810 Posted October 10 @sqrlgtr those SHOULDER BOLTS , without threading , are what you want on a plow frame set up ? did this years ago , DIAL IN A PERFECT SWING / MOVEMENT SETTING ? swing quadrant and related lever squeeze , show you the way , pete 1 Share this post Link to post Share on other sites
peter lena 10,125 #26811 Posted October 10 @sqrlgtr started experimenting with swing movement areas , years ago , NEVER LOOKED BACK, also regularly refer to building something from a roller stool , so I can scoot around , and verify change ? . thats a base line for me , HOW CAN i MAKE THIS BETTER ? this gold mine of repetitive hang ups ? done years ago , led me to , bearing lubrication , failure . fixed that too, pete 1 Share this post Link to post Share on other sites
ML3 2,571 #26812 Posted October 10 Took mower off 654- cleaned & oiled for winter storage. Did oil change, new drive belt, misc maint, installed weights & plow. 702 is next on list. Should just need some minor maint before winter. 416 is ready for snow, except for a couple cosmetic items, especially a new seat. I know I'm getting ready early but gotta get stuff done while I have the time..... 3 2 Share this post Link to post Share on other sites
Bar Nuthin 3,642 #26813 Posted October 11 (edited) Installed some of the goodies I picked up at the Portland Swap Meet. Changed out the lug tires for this $50 set I picked up. Popped on the "everyday" set of hubcaps (keeping an NOS set stored for shows or potential restoration). Installed a different ammeter - the original was bouncing around like crazy. Hard to find a 15-amp ammeter. Installed the snowplow bracket that came with an HY-3 kit. Soaked up some beautiful weather putting around the yard and tending to a pile of limbs I was burning. Next on the list is to replace all the seals on the transmission. After that, popping the head off, checking the valves, breather, and repairing or replacing a leaking fuel pump. Edited October 11 by Bar Nuthin 1 8 Share this post Link to post Share on other sites
cafoose 3,883 #26814 Posted October 12 Just replaced the stator on my 520-HC Vanguard swap because it wasn't charging. One of the stator wires had insulation missing by the flywheel. After replacing, voltage was still not much more than 12 VDC. I replaced the regulator and then it jumped up to 14.03 VDC. I also adjusted the valves. They were between 0.011 and 0.014. Specs are .005. Now it runs great and the tach moves but I don't think it's accurate because of the Vanguard having only 8 poles on the stator. 5 4 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #26815 Posted October 12 Attempted to mount these brand new 4 ply tires. Actually felt something in my shoulder while I was leaning into my Harbor Freight tire mounting rig. Stopped before I did damage to some muscle that doesn’t see much action in my day to day activities ! Was just too much and ya gotta know when to let the pro’s handle it. Local garage popped em on for me. Gotta love all the nubbies…but they won’t last. 11 3 Share this post Link to post Share on other sites
peter lena 10,125 #26816 Posted October 12 @Sparky that shoulder issue ? in todays world , joint work is a no brainer , place I went to in waterford / niantic , thats all they do . my 20 year old knees are doing fine , very arduous compared to today , weeks / months of learning how . also had lower spine L 4/5 fused , stroke in eye years back , learn from everything , most important ? ADAPTING TO IT , regularly talk to OBVIOUS PAIN , with people , most glairing ? FEAR every excuse to avoid operation , not me , just sayin . pete Share this post Link to post Share on other sites
ebinmaine 81,278 #26817 Posted October 12 17 hours ago, cafoose said: valves. They were between 0.011 and 0.014. Specs are .005. Same spec on both intake and exhaust? Share this post Link to post Share on other sites
cafoose 3,883 #26818 Posted October 12 19 minutes ago, ebinmaine said: Same spec on both intake and exhaust? From my research, both intake and exhaust is between 0.004 and 0.006. I set mine at 0.005 and it runs great. 1 1 Share this post Link to post Share on other sites
davem1111 2,453 #26819 Posted October 12 (edited) 2 hours ago, Sparky said: Attempted to mount these brand new 4 ply tires. Actually felt something in my shoulder while I was leaning into my Harbor Freight tire mounting rig. Stopped before I did damage to some muscle that doesn’t see much action in my day to day activities ! Was just too much and ya gotta know when to let the pro’s handle it. Local garage popped em on for me. Gotta love all the nubbies…but they won’t last. I have both the small and large HF tire rigs. I picked up the large one a while back in a bulk deal and hadn't mounted it yet, so this weekend I drilled holes in the garage floor, put anchors in, and set it up. Then I realized that the 8" fronts I wanted to work on wouldn't fit on that rig. I was going to abandon the small one because the vertical threaded bar got all bent the last time I used it (where do they actually manage to get metal that soft? ) Anyway, I was actually able to get one tire dismounted on the floor, using downpressure on the large rig's arm. These are so bad that the tubes are stuck to the inside of the rusty rims... I have the second one half off, using the small rig. using a lot of soapy water. Rears, no thanks. Belle Tire will mount those for $10 each - that's a better option for me. I don't think they'd want to deal with the rusty fronts I'm working on right now though. Hope the shoulder didn't take any lasting damage. I had cortisone injections in both of mine last year and have been going easy on them since then. Edited October 12 by davem1111 3 2 1 Share this post Link to post Share on other sites
sqrlgtr 4,224 #26820 Posted October 12 (edited) Making some wide wheels. got um cut and tacked together but had to come home and get some supper I was getting hungry. Edited October 12 by sqrlgtr 2 5 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #26821 Posted October 12 4 hours ago, davem1111 said: Rears, no thanks. Belle Tire will mount those for $10 each - that's a better option for me. Hope the shoulder didn't take any lasting damage. I had cortisone injections in both of mine last year and have been going easy on them since then. Exactly! A local place did them for $15 each. Well worth it to me. Shoulder is fine, I could tell I was going to mess up something as I started to wrestle the first tire trying to get it on, so stopped before any damage was done. 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #26822 Posted October 12 5 hours ago, davem1111 said: $10 each 25 minutes ago, Sparky said: $15 each Wish we could get that 'round here. $25 per tire and most places don't have the machine to mount a 12 inch rim anymore. I don't think there's a small wheel machine like that anywhere within 20 or 30 miles of home. Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #26823 Posted October 13 25 minutes ago, ebinmaine said: I don't think there's a small wheel machine like that anywhere within 20 or 30 miles of home. Your local power equipment dealer must have one right? Share this post Link to post Share on other sites
ebinmaine 81,278 #26824 Posted October 13 Just now, Sparky said: Your local power equipment dealer must have one right? "Local" is 4 towns away and they charge premium prices. I've stopped calling them altogether. My favorite small engine repair place has no machine. What tires they can't do manually get sent out. At $25 each. 1 1 Share this post Link to post Share on other sites
sqrlgtr 4,224 #26825 Posted October 13 15 minutes ago, ebinmaine said: "Local" is 4 towns away and they charge premium prices. I've stopped calling them altogether. My favorite small engine repair place has no machine. What tires they can't do manually get sent out. At $25 each. We're pretty lucky around here got 3 tire shops within 15 mins. and they all will do them for 10 to 15 dollars apiece and one of them will pump in liquid ballast if you bring it with you no extra charge . I try and not go to the same one over and over so as not to ware out my welcome and always give whoever doing the actual work a tip also. 2 3 Share this post Link to post Share on other sites
