Sodaking27 1,342 #26751 Posted Friday at 06:10 PM New tires and wide rims for the 314H. Waiting on the weather to cooperate so I can paint the rims. Plan on using the 314H as my plow tractor this year. 12 4 Share this post Link to post Share on other sites
nylyon-(Admin) 9,054 #26752 Posted Friday at 07:02 PM 3 hours ago, Sparky said: Cleaned off the underside of my 42”RD. Found the right side attach-a-matic bracket super loose where it bolts to the frame. Never had a loose one before…I’ll be checking more often I guess. I did one of mine yesterday as well. The deck belt broke and while waiting for the replacement decided to remove the deck and check everything out. Loaded with grass, but it cleaned up nicely. I think next year I will repaint the underside. This is the deck I redid last year! 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,219 #26753 Posted Friday at 08:24 PM Mowed a couple rounds with the 48"SD on the 312H and on the next round I noticed the right blade was not cutting. Thinking the spindle belt tensioner was jammed with grass, I pulled under the hoist and lifted her up to check it out. The blade was missing. A quick search and I found the blade but not the bolt and washer. I dumped a deck parts bucket and grabbed a new bolt and washer and sharpened the blade while it was off. Put the blade back on but the bolt would not start in the hole. The bolt didn't vibrate out, it broke off. So the deck came off and went on the repair/storage rack. It also needs a hole patched then cleaned and oil soaked. I put the plow on this tractor every fall just a little earlier than usual this year. Got out the 310-8 to finish mowing. The grass was due to be vacuumed up any way. I use the Trac Vac every 3-4 mowings. 11 Share this post Link to post Share on other sites
SylvanLakeWH 32,407 #26754 Posted Friday at 09:32 PM 1 hour ago, Ed Kennell said: I dumped a deck parts bucket and grabbed a new bolt and washer and sharpened the blade while it was off. Good thing you know a guy... 2 2 Share this post Link to post Share on other sites
sqrlgtr 3,846 #26755 Posted Friday at 10:14 PM 1 hour ago, Ed Kennell said: The blade was missing. Wow did you hear/see it come off? Ive always worried about losing a blade and it hurts someone a pet or sumin. Share this post Link to post Share on other sites
Ed Kennell 47,219 #26756 Posted Saturday at 12:23 AM 2 hours ago, sqrlgtr said: Wow did you hear/see it come off? Not a clue until I completed a round and saw it wasn't cutting. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,107 #26757 Posted Saturday at 12:39 AM I made some progress on the hydro deck lift retrofit tonight. The shaft is in and the ram is on. The shaft isn’t attached to the bar that lifts the deck as I wanted to go look at how it’s attached before I drill any holes etc…It still might need to be adjusted but I wanted to get things together then figure out where the sticking point is. More progress tomorrow…maybe 4 1 Share this post Link to post Share on other sites
Fj40z 239 #26758 Posted Saturday at 01:33 AM Swapped the 48” deck from my coaster C160 onto the the 314-8 with a little help from my oldest son. Had to remove the 42” off the 314 first. This was my first time removing the decks off of any WH. Really nice and well thought out. On a side note I did find a nice chunk of motor block from the K341. Found it on top of the 48” deck, still kind of heart broken. 5 Share this post Link to post Share on other sites
ineedanother 2,859 #26759 Posted Saturday at 02:14 AM 38 minutes ago, Fj40z said: Swapped the 48” deck from my coaster C160 onto the the 314-8 with a little help from my oldest son. Had to remove the 42” off the 314 first. This was my first time removing the decks off of any WH. Really nice and well thought out. On a side note I did find a nice chunk of motor block from the K341. Found it on top of the 48” deck, still kind of heart broken. Really hated to hear about the c-160 but that's a nice looking 314-8 4 Share this post Link to post Share on other sites
Fj40z 239 #26760 Posted Saturday at 03:23 AM @ineedanother thank you sir! 1 Share this post Link to post Share on other sites
sqrlgtr 3,846 #26761 Posted Saturday at 04:08 PM Patched up a couple seats. Used some liquid repair type stuff and some vinyl with sticky on back, both came from the jungle site and seems to work great. IDK how long or tough it will be but at least I aint leaving a trail of foam everywhere they go. 8 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,407 #26762 Posted Saturday at 06:54 PM (edited) New axle and brake seal on the C-125. The hub puller I bought from a member here worked like a charm!!! Thanks @Blue Chips!!! Ordering axle seal for the B-80. Had to remove chains from the C-125 plow mule... they were rubbing in a few spots... Ran them all around the hood to give them some exercise...then they posed for a quick pic... Edited Saturday at 07:04 PM by SylvanLakeWH 3 10 Share this post Link to post Share on other sites
ML3 2,504 #26763 Posted Saturday at 08:03 PM (edited) Took advantage of the nice weather today. Put the show tractors away for the year along with the patio furniture & grill. I know its still kinda early but finding time to get things done is getting harder. Work is busy, home to-do projects that have become must-do, & helping mom at her place now that dad is gone. Edited Saturday at 10:23 PM by ML3 6 5 2 Share this post Link to post Share on other sites
Handy Don 17,430 #26764 Posted Saturday at 08:27 PM 1 hour ago, SylvanLakeWH said: The hub puller I bought from a member here Interesting design. I’d probably use it with the center nut on the side toward the hub and not rely entirely on the weld to hold it. But then, I rarely walk on the wild side! 5 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,407 #26765 Posted Saturday at 09:24 PM 54 minutes ago, Handy Don said: Interesting design. I’d probably use it with the center nut on the side toward the hub and not rely entirely on the weld to hold it. But then, I rarely walk on the wild side! Didn't come with a manual!!! I figured flat on flat would be most effective spreading the load on the hub. But, I now see what you are saying as well... Appreciate the input! 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,107 #26766 Posted Sunday at 03:30 AM (edited) More progress on the hydrolift retrofit. The valve block and lines are now attached to the ram. It is semi permanent as it’s a PITA to put in. I made a mounting plate out of aluminum, that the valve block bolts to then bolted to the frame. It’s relatively close to where the original was. So as of tonight everything but the hard lines and the handle are in, that will be tomorrow’s project. Edited Sunday at 03:30 AM by MainelyWheelhorse 9 1 Share this post Link to post Share on other sites
JoeM 10,233 #26767 Posted Monday at 08:13 AM On 9/26/2026 at 1:27 PM, Handy Don said: not rely entirely on the weld to hold it It that weld lets go that guy needs to stop welding! 3 3 Share this post Link to post Share on other sites
squonk 48,038 #26768 Posted Monday at 10:35 AM Flat on flat is better IMHO. Rather the weld break then the plate shatter from bowing around the nut. 2 2 1 Share this post Link to post Share on other sites
Bill D 3,132 #26769 Posted Monday at 03:12 PM (edited) Here's some pictures of the pulller I built. On 9/26/2026 at 4:27 PM, Handy Don said: Interesting design. I’d probably use it with the center nut on the side toward the hub and not rely entirely on the weld to hold it. But then, I rarely walk on the wild side! Edited Monday at 03:13 PM by Bill D 8 Share this post Link to post Share on other sites
davem1111 2,326 #26770 Posted Monday at 08:29 PM Hauling some firewood out of the woods this weekend with the GT-1848. Major deck maintenance going on recently: I had the baffle come loose on one of the 48" SD's a few weeks ago and it got a bit mangled. Deck and spindles have significant rot so I'm probably going to scrap that one. Oh, and the 312-A is back there getting a cleanup and repaint of the rear, tins, and wheels. Not pulling it all apart to repaint everything. It's got fairly new rear tires so I got a matching pair of new ones for the front. Been sitting on a set of nice hubcaps and black belt cover - those will go on here when done. New decals from @Vinylguy - will post pictures when those go on. 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,219 #26771 Posted Monday at 08:57 PM Hoisted the 48"SD up to see if I could get the broken bolt out of the spindle. I got lucky. A few taps with a punch and it spun right out. Threw a patch on the left rear corner. Sharpened the blades. Finish scraping, wire brushing and oil down for the winter. 8 1 Share this post Link to post Share on other sites
wfopete 50 #26772 Posted 7 hours ago (edited) My new to me D160 came with a paint job that I think was done in a hay barn. If you ran your hand over the hood it was ruff. You could feel and see all sorts of imbedded dirt in the paint. I took some #2000 paper and did a light wet sand followed up with a orbital polisher and it came out shiny and smooth as glass. Edited 7 hours ago by wfopete 1 6 Share this post Link to post Share on other sites
ebinmaine 80,513 #26773 Posted 5 hours ago 1 hour ago, wfopete said: came out shiny and smooth as glass Niiiiice work!! 1 Share this post Link to post Share on other sites
Handy Don 17,430 #26774 Posted 4 hours ago 3 hours ago, wfopete said: smooth as glass Nice result, and WAY less work than repainting, too! 2 Share this post Link to post Share on other sites
