Sodaking27 1,335 #26751 Posted 9 hours ago New tires and wide rims for the 314H. Waiting on the weather to cooperate so I can paint the rims. Plan on using the 314H as my plow tractor this year. 10 1 Share this post Link to post Share on other sites
nylyon-(Admin) 9,054 #26752 Posted 8 hours ago 3 hours ago, Sparky said: Cleaned off the underside of my 42”RD. Found the right side attach-a-matic bracket super loose where it bolts to the frame. Never had a loose one before…I’ll be checking more often I guess. I did one of mine yesterday as well. The deck belt broke and while waiting for the replacement decided to remove the deck and check everything out. Loaded with grass, but it cleaned up nicely. I think next year I will repaint the underside. This is the deck I redid last year! 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,143 #26753 Posted 7 hours ago Mowed a couple rounds with the 48"SD on the 312H and on the next round I noticed the right blade was not cutting. Thinking the spindle belt tensioner was jammed with grass, I pulled under the hoist and lifted her up to check it out. The blade was missing. A quick search and I found the blade but not the bolt and washer. I dumped a deck parts bucket and grabbed a new bolt and washer and sharpened the blade while it was off. Put the blade back on but the bolt would not start in the hole. The bolt didn't vibrate out, it broke off. So the deck came off and went on the repair/storage rack. It also needs a hole patched then cleaned and oil soaked. I put the plow on this tractor every fall just a little earlier than usual this year. Got out the 310-8 to finish mowing. The grass was due to be vacuumed up any way. I use the Trac Vac every 3-4 mowings. 6 Share this post Link to post Share on other sites
SylvanLakeWH 32,322 #26754 Posted 5 hours ago 1 hour ago, Ed Kennell said: I dumped a deck parts bucket and grabbed a new bolt and washer and sharpened the blade while it was off. Good thing you know a guy... 1 2 Share this post Link to post Share on other sites
sqrlgtr 3,813 #26755 Posted 5 hours ago 1 hour ago, Ed Kennell said: The blade was missing. Wow did you hear/see it come off? Ive always worried about losing a blade and it hurts someone a pet or sumin. Share this post Link to post Share on other sites
Ed Kennell 47,143 #26756 Posted 3 hours ago 2 hours ago, sqrlgtr said: Wow did you hear/see it come off? Not a clue until I completed a round and saw it wasn't cutting. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,093 #26757 Posted 2 hours ago I made some progress on the hydro deck lift retrofit tonight. The shaft is in and the ram is on. The shaft isn’t attached to the bar that lifts the deck as I wanted to go look at how it’s attached before I drill any holes etc…It still might need to be adjusted but I wanted to get things together then figure out where the sticking point is. More progress tomorrow…maybe 1 Share this post Link to post Share on other sites
Fj40z 232 #26758 Posted 1 hour ago Swapped the 48” deck from my coaster C160 onto the the 314-8 with a little help from my oldest son. Had to remove the 42” off the 314 first. This was my first time removing the decks off of any WH. Really nice and well thought out. On a side note I did find a nice chunk of motor block from the K341. Found it on top of the 48” deck, still kind of heart broken. 1 Share this post Link to post Share on other sites
ineedanother 2,847 #26759 Posted 1 hour ago 38 minutes ago, Fj40z said: Swapped the 48” deck from my coaster C160 onto the the 314-8 with a little help from my oldest son. Had to remove the 42” off the 314 first. This was my first time removing the decks off of any WH. Really nice and well thought out. On a side note I did find a nice chunk of motor block from the K341. Found it on top of the 48” deck, still kind of heart broken. Really hated to hear about the c-160 but that's a nice looking 314-8 1 Share this post Link to post Share on other sites
Fj40z 232 #26760 Posted 7 minutes ago @ineedanother thank you sir! Share this post Link to post Share on other sites
