Ed Kennell
What have you done to your Wheel Horse today?
Sparky
  Doing an 8 speed gear oil change..easier to just remove the trans right :eusa-think:
  • Haha 7
  • Confused 1
SylvanLakeWH
Well... er... uhm... it works... I guess... :blink:
  • Haha 2
  • Heart 1
C100guy94
I'm with you.
I mean no,but yea,nope not really,but like yea I kinda get why you would, but why did you. Lmao yep Id have done the same so no room to talk on my part haha
MainelyWheelhorse
@Sparky that works. It makes it easier to fill too.😀
MainelyWheelhorse
IMG_2185.jpeg.3d24eeae5bf56968e205c9392b15ec54.jpegIMG_2186.jpeg.40ccd41bd0cb2b3a24d5465c8314a30a.jpegIMG_2187.jpeg.172911e268129b31f461fdb8f44187be.jpeg
Today after work was touch up and detail painting, fixing scrapes and chips day.. much nicer.
Sparky
  LOL!
  This C-81 is a parts rig and I decided to strip it down today..trans will sit on a shelf as a spare but I wanted fresh fluid in it before it gets stored away.
  • Like 5
C100guy94
Now that makes sense.
Super clean for a parts rig
Edited by C100guy94
CRF857
5 hours ago, peter lena said:
@CRF857   like the bolt on stud hubs , noting your  rear seat under spring , have regularly  enhanced mine to this type of bolt on compression spring , also added , stiff  vibration pad  strips under  seat frame rails , for  more height  , more to my liking  . all my paints are  lubrication  soaked , staged , recovery . where did you get the bolt on stud  hubs ?  thanks , pete
Those are the original hubs. Full threaded bolts installed from the backside, with lock washers and loctite.
Have done that on most of my tractors. I will at minimum put in one or two bolts that way. Makes hanging a tire/rim a lot easier.
I usually use chrome acorn lug nuts for some added bling.
On the 520 the studs on the spacer looked a little long for the acorn lug nuts I have. Plus I would be 3 pieces short. Need to get more.
  • Excellent 2
Bar Nuthin
Decided that painting these wheel weights was worth the effort. Now I just need to pull the front wheels and get rid of that bright white that somebody painted them with.
IMG_5431.jpg.257bec9c911b5b2d8de661890d5031fb.jpg IMG_5666.jpg.482ff3d4d543d4948835516b45cb8f3a.jpg
UPDATE:
Edited by Bar Nuthin
  • Excellent 5
Wheelhorse#1
22 hours ago, Sparky said:
  LOL!
Sure is nice to have spare parts tractors around especially as these things become more expensive and hard  to find.
sqrlgtr
Painted some WH rear wheel weights and some JD front weights red today.
  • Like 5
  • Excellent 4
sqrlgtr
19 minutes ago, squonk said:
RS 20th anniversary banner hung up
Looks great hate I didnt get to make this year show. Btw what is next years featured tractor?
Sparky
  The 67 towed the 83 from the back shed up to the garage for a drive belt swap. Thought I was saving a few $$ using the belt I just removed from a junk C-81..but it ended up being a little shorter and she just doesn’t declutch like it should. Grinds the gears a bit. Crud!!
  I guess I’ll be using a brand new belt I picked up at this years WH Show. The idler pulley was shot on the 83 (GT-1600) so the C-81 did donate a nice smooth one so there’s that :eusa-think:
  • Like 4
ebinmaine
Those for sale somewhere?
squonk
You'd have to contact Terry.
ebinmaine
@Vinylguy
cleat
That Twin cylinder Briggs looks a lot like a single cylinder Kohler......JK looks great.
  • Haha 3
Sparky
 Good eye Cleat!! :lol:
  She now has a Kohler 14 Magnum single under the hood!
cleat
Funny, I rebuilt a GT1600 and converted it to hydro a couple of years ago and am now in the process of rebuilding a 314 that has a Kohler M14.
sqrlgtr
Decepticon
CRF857
The C41 has two rubber stops and springs under the seat/spring mounting plate.
one spring was broken and one rubber stop was missing. After scrounging through the “extra parts” I found two heavier springs and two rubber stops. A few minutes later they were installed.
  • Like 4
CRF857
The safety tread on the C141 was worn and peeling. Heat gun and scraper made short work of removing them. I had more on the shelf. Used four smaller pieces rather than cutting into a large one. Good result for a  little effort.
Started to quit for the day, but Edy was mopping the utility room and kitchen floors. So I was marooned to the shop for a little while longer.
 Tried putting a shine on the hoods of the 520H and the C141. I will work on the rest of the tins a little at a time.
The mower decks will get spiffed up this winter.
Edited by CRF857
  • Excellent 3
sqrlgtr
Put my newly rebuilt mule drive and new belt on the 312-8 today. This drive and belt was destined for the 520H but the 312’s belt was wore out so just swapped both out while I was at it. Notice I bent gaurd on mule drive the belt was rubbing bad for some reason but it ain’t rubbing now :D. Have no idea what this mule drive came off of but didnt think there was any difference in any of them besides the ones for the 60” 520 decks.
