Ed Kennell
What have you done to your Wheel Horse today?
Sparky
  Doing an 8 speed gear oil change..easier to just remove the trans right :eusa-think:
  • Haha 5
  • Confused 1
SylvanLakeWH
Well... er... uhm... it works... I guess... :blink:
  • Haha 1
  • Heart 1
C100guy94
I'm with you.
I mean no,but yea,nope not really,but like yea I kinda get why you would, but why did you. Lmao yep Id have done the same so no room to talk on my part haha
MainelyWheelhorse
@Sparky that works. It makes it easier to fill too.😀
MainelyWheelhorse
IMG_2185.jpeg.3d24eeae5bf56968e205c9392b15ec54.jpegIMG_2186.jpeg.40ccd41bd0cb2b3a24d5465c8314a30a.jpegIMG_2187.jpeg.172911e268129b31f461fdb8f44187be.jpeg
Today after work was touch up and detail painting, fixing scrapes and chips day.. much nicer.
Sparky
  LOL!
  This C-81 is a parts rig and I decided to strip it down today..trans will sit on a shelf as a spare but I wanted fresh fluid in it before it gets stored away.
C100guy94
Now that makes sense.
Super clean for a parts rig
Edited by C100guy94
CRF857
5 hours ago, peter lena said:
@CRF857   like the bolt on stud hubs , noting your  rear seat under spring , have regularly  enhanced mine to this type of bolt on compression spring , also added , stiff  vibration pad  strips under  seat frame rails , for  more height  , more to my liking  . all my paints are  lubrication  soaked , staged , recovery . where did you get the bolt on stud  hubs ?  thanks , pete
Those are the original hubs. Full threaded bolts installed from the backside, with lock washers and loctite.
Have done that on most of my tractors. I will at minimum put in one or two bolts that way. Makes hanging a tire/rim a lot easier.
I usually use chrome acorn lug nuts for some added bling.
On the 520 the studs on the spacer looked a little long for the acorn lug nuts I have. Plus I would be 3 pieces short. Need to get more.
Bar Nuthin
Decided that painting these wheel weights was worth the effort. Now I just need to pull the front wheels and get rid of that bright white that somebody painted them with.
IMG_5431.jpg.257bec9c911b5b2d8de661890d5031fb.jpg IMG_5666.jpg.482ff3d4d543d4948835516b45cb8f3a.jpg
