pfrederi 20,964 #26226 Posted June 5 One set up is for floating the other allow down pressure 2 Share this post Link to post Share on other sites
DLF 74 #26227 Posted June 5 17 hours ago, MainelyWheelhorse said: I also gave the muffler on the C-141 a touch up as the high heat paint was coming off where the exhaust turned and went up the pipe. It’s been a productive day. That muffler may melt your Wheel Horse decal. 3 Share this post Link to post Share on other sites
MainelyWheelhorse 2,974 #26228 Posted June 5 @DLF It seems to be fine so far. The muffler is about 2 1/2 inches away from it. There has been no discoloration or visible heat damage after the decal has been on there since the end of October. I’ll keep an eye on it though. Thanks for the heads up. 3 Share this post Link to post Share on other sites
kpinnc 18,812 #26229 Posted June 6 4 hours ago, MainelyWheelhorse said: about 2 1/2 inches away from it Plenty far enough away. A couple of mine are closer than that and they don't damage the decals. 3 Share this post Link to post Share on other sites
MainelyWheelhorse 2,974 #26230 Posted June 6 (edited) 15 hours ago, kpinnc said: Plenty far enough away. A couple of mine are closer than that and they don't damage the decals. That’s what I thought when I was figuring out how far out to cut the exhaust extension. Enough to not be a damage magnet but close enough to not damage the decals/paint. The 312 and 308’s exhaust are closer like yours. No issues there either. So far so good. Edited June 6 by MainelyWheelhorse 1 Share this post Link to post Share on other sites
kpinnc 18,812 #26231 Posted June 6 Added some creature comfort to where most of them sleep... 2 3 Share this post Link to post Share on other sites
ebinmaine 79,957 #26232 Posted June 6 21 minutes ago, kpinnc said: Added some creature comfort to where most of them sleep... Nice of you to keep the Horses happier. 1 1 Share this post Link to post Share on other sites
C100guy94 116 #26233 Posted June 6 17 hours ago, kpinnc said: Plenty far enough away. A couple of mine are closer than that and they don't damage the decals. I like em. Want em all. Haha 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,119 #26234 Posted June 6 Just mowing with the 414…nothing special to see here. Then getting it in the shed up the steeper ramp it lost traction, rolled and the idiot driving it slipped the clutch pedal to much and she did a small wheelie. Well the right spindle drops out of the axle and when it comes down it snaps the ball outa the socket on the tie rod. All fixed now. The E clip on top of the spindle is nowhere to be found. But the groove for it is full of crud making me think it’s been gone awhile and the accidental wheelie has brought it to my attention. My new HF floor jack came in useful today 6 5 Share this post Link to post Share on other sites
ebinmaine 79,957 #26235 Posted June 6 48 minutes ago, Sparky said: new HF floor jack Good timing on that purchase! Share this post Link to post Share on other sites
squonk 47,587 #26236 Posted June 6 Darn Hot Rod Kids! 4 Share this post Link to post Share on other sites
Blaine 261 #26237 Posted June 7 I’ve been tinkering with my 702 over this past week, going over it, putting together a mental list of what it needs with hopes to find at the big show, but the list keeps growing. I’ve kept the 702 stored indoors for over a decade now after the steering sector snapped. I have my trusty 401 that has been keeping my yard mowed for almost 30 years, so the 702 project has been at the bottom of lifes list of projects. But now the deck on the 401 is sounding louder than ever. Bearings are worn, shafts are worn, keyways are rough, but the deck is still solid. More oil is on the wheels than is inside the trans. Hubs are loose on the axles. I lost a wheel a couple weeks ago. Hub set screw threads are gone, so there’s a blob of weld holding the wheel on the axle. It’s in serious need of some TLC. It did get a fresh predator motor this spring. The last one was on there maybe 12 years. Still ran but was getting low on power and temperamental starting. Thought i’d get 702 going because I know the deck is good, or so i thought. It’s weird how time makes you forget stuff. Luckily it was just a woodruff key for the left side had sheared. So that’s all good now. Since someone had got all happy with nickel rod and welded just about everything together on the rest of the tractor, i just mig welded what was left of the sector to the shaft, mainly to make it easier to move around until i find replacements at the big show. i bought the 702 15-20 years ago as a “ran when parked”. Well sure enough, after a battery and carb n tank clean, it was running, but it seemed tired. At the time i had planned on occasionally plowing snow with it so no big deal. Shortly after replacing all of the tires, the sector broke. So once again, it was a “ran when parked”. Since then we had moved. The new tires got swapped on to the 401 because the original tires were coming apart and the front wheels were rusted through. The new place has a fairly steep bank sloping to the rear of the property. After fixing the deck on the 702, welding the sector, and charging up the 12 year old battery it fired up. I took it for a lap around the yard. At first i thought the deck belt was slipping, but no. That’s how quiet it’s supposed to sound. Lol. Poor little 401. But boy was that 7 horse struggling. So LOUD. I made the mistake of going down back. Had to disengage the deck and pulled the throttle out all the way, i barely made it back up the hill. So last night i was thinking about how loud it seemed and just so little power. So this morning i went out and sprayed soapy water around the head and cranked the starter. Sure enough, bubbles coming out near the exhaust side of the head. AH HA. So i pulled the head, gasket wasn’t complete toast, maybe the bolts were loose, but i zipped them off with an impact gun, so no idea. Soaped the valves and aired the exhaust and carb. Had some light bubbling, so i pulled the carb and breather and checked the valves. .006” intake .023” exhaust. Good enough for me. I got on the phone and located a new gasket locally but I figured i couldn’t make a 25 minute drive in 9 minutes before they closed today, so i cleaned everything up and put it back together. Finished mowing the level area of the yard with it. Struggled getting it out of all 4 gears every time i had to back up. It started to get a little better, but i’m hoping a new shifter pin will fix it because the shifter has a lot of rotational slop. A new pin fixed the 401 when i had the same problem. I did drain the trans and filled it with ATF to flush it out. Hoping it comes around. I checked the bore, 4 times. I kept getting the same thing. 2.882”. I don’t know what that is in dog years, but that’s what it is. I could push the piston around, as there is a serious gap to the cylinder wall and the piston is stamped STD. Obviously no visible crosshatch, but no scoring either. I couldn’t pick up on any rod noise, but it’s hard to hear anything over the steering shaft buzzing in the aluminum tank. After mowing with the 401 for over a quarter of a century, the 702 just felt odd. Maybe it’s just the whole low power, but it definitely seemed geared lower too. I like a 32” cut as i have obstacles and tight areas. I can wheel the 401 around quick and easy. I just don’t see that happening on the 701. Always loved the easy steering on the 401. All 4 tires are foam filled, and i have a pair of Taurus rotors that i filled the vents with lead, 25# each, so the 401 sticks to the ground. I’ll probably be looking for a complete correct deck for the 401 and another motor for the 702, some front wheels (the 702 is currently rolling on my old 867 tires and wheels that i foolishly parted out back in the 90’s) So yeah, that was my day. The 702 cut beautifully, but it’s had a rough life long before i got it. It might be best as yard art. 9 3 Share this post Link to post Share on other sites
ineedanother 2,686 #26238 Posted June 7 Brought the c-161 to the shop for the first time. It's in great shape. Blew the critter debris from everywhere compressed air could reach. Likely going to put the FEL on here instead of on the 165 since that sub-frame doesn't like the square hood. 5 1 Share this post Link to post Share on other sites
ebinmaine 79,957 #26239 Posted June 7 Got a couple BIG loads of firewood brought up from down back of the barn. I've never tried to stack as much wood in the trailer as I did today. The first load is taller but has shorter length pieces. The second load felt heavier. I figured for sure that tractor tire traction would be the limiting factor. Nope. The ole beast Cinnamon Horse C160-8 just kept on ah-chuggin'... I was very pleasantly surprised at how well that went. Second load: 3 5 1 Share this post Link to post Share on other sites
ineedanother 2,686 #26240 Posted June 8 I pulled decks from two this weekend. I've never had anything other than 48" until the 42" I recently got on a c-161. The 42" is SO MUCH more manageable 5 1 Share this post Link to post Share on other sites
ineedanother 2,686 #26241 Posted June 8 A rubdown with Penetrol. It was thirsty and will get another... 4 6 Share this post Link to post Share on other sites
Fj40z 209 #26242 Posted June 8 @ineedanother when using the Penetrol do you avoid applying directly to the decals? One of the main reasons I haven’t applied anything like boiled linseed oil or Fluid Film to my C160 is I’ve never used them on anything that had decals and have been worried that it may cause them to come off. Share this post Link to post Share on other sites
ineedanother 2,686 #26243 Posted June 8 1 hour ago, Fj40z said: @ineedanother when using the Penetrol do you avoid applying directly to the decals? One of the main reasons I haven’t applied anything like boiled linseed oil or Fluid Film to my C160 is I’ve never used them on anything that had decals and have been worried that it may cause them to come off. I tested it on a damaged decal and it was fine so now I apply it right over them. Mine are all original so I can't say how new ones would react and can't say for certain that even the originals are all the same. 1 Share this post Link to post Share on other sites
Fj40z 209 #26244 Posted June 8 5 hours ago, ineedanother said: I tested it on a damaged decal and it was fine so now I apply it right over them. Mine are all original so I can't say how new ones would react and can't say for certain that even the originals are all the same. 10-4. I feel like it’s highly unlikely it damaging the decal. I read on fluid films instructions that it’s the edge of the decal you have to worry about. It being lanolin based can lead to the product bleeding under the edge and causing the decal to let go. I think I’m going to go with Penetrol since you’ve had no issues with it. 1 Share this post Link to post Share on other sites
Shynon 7,634 #26245 Posted June 9 Went out for a test drive. 5 13 2 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,308 #26246 Posted June 9 Looking Good!!!👍 1 Share this post Link to post Share on other sites
CasaytheMann 231 #26247 Posted June 9 (edited) I've been wanting to replace my mulching cover, due to it being broken at the corners, and the PO hacking it. WHX?? was kind enough to sell an extra one he had (including the mounting bolts/nuts which I didn't have). Today I used rust reforming primer and GM Red spray paint on the rusty areas of the deck. After it all cured I added a little weatherstripping to the back edges of the cover and installed. My mild OCD is doing better now. Once my son in law has the time he's going to 3D print me another one for the spare parts shelf. Edited June 9 by CasaytheMann 7 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,119 #26248 Posted June 12 C-85 I bought awhile back has always had two leaky fronts. Been stored in the shed up on blocks so the rubber wouldn’t get ruined sitting flat..well today I decided to tube em both. I hate tubing the small tires ! This old HF tire changer comes in handy still. But now it’s done and the big test will be to see if they stay “up”. 10 5 Share this post Link to post Share on other sites
kpinnc 18,812 #26249 Posted June 12 14 minutes ago, Sparky said: HF tire changer comes in handy still. I have certainly got my money out of mine. Not perfect but they do help a great deal. The C85 looks great! 1 1 Share this post Link to post Share on other sites
Andy N. 2,804 #26250 Posted June 12 Picked up this front deck mount about 1 month ago and the 42" deck on the way home from @Pullstart's plow day. Finiched getting it all mounted up and working today. The instructions want you to cut out a notch on the RH belt cover in order to clear the drive belt. Don't think I'll be doing that for now. Mows pretty good, but will get a little getting used to. Also need to get a hydro to install it on. Way too wet to mow due to all the storms that past few days, btu wanted to to make 1 pass around the garden to check the cut. IMG_9702.mp4 IMG_9703.mp4 IMG_9706.mp4 6 3 1 Share this post Link to post Share on other sites
