Ed Kennell
What have you done to your Wheel Horse today?
sqrlgtr
Replaced seal behind brake drum(I just noticed when I posted pics I put brake drum on backwards :D), and changed oil in rear of the 312-8 I been working. Also  got to try out my new headlight, and before anyone ask, no thats not a professional model in last pic just me.
  • Haha 9
whtractors24
Show prep . Had a little axle drip going on, and decided it’s time to make it like new again . That oem seal from 40 years ago sure gave me a run for my money . IMG_8753.jpeg.888269b24ef7618c3585d288b62cbc8a.jpeg
  • Like 5
WHX??
8 hours ago, sqrlgtr said:
changed oil in rear of the 312-8:D
Looks Like that spring has seen better days too.
  • Haha 2
MainelyWheelhorse
Mowed all my parent’s lawn with the 312. It powered through with only one stop to tighten the mule drive. The PTO went bad on their mower so it had been a week since it was mowed. The grass is growing like crazy with our odd weather for the time of year lately.
IMG_2092.jpeg.21adc25ab00492464e1d6fc17fb888bb.jpegIMG_2093.jpeg.e0e2ad2ec7234a8acf917dac30d42d2c.jpegIMG_2094.jpeg.d5bcd61b4e2dfbbd75b54e7bd8e4a1f7.jpeg
I also recruited the 308 for them to use if they need to. Just a little grease in the mule drive and a once over to check it over as my test after I put the deck on had a new noise up front. After it’ll be good to go.
  • Like 5
kpinnc
They can be a pain, but well worth it when replaced.
Brockport Bill
i always thought my 37 SD on my 312-8 was terrific cut - - maybe the 2 blade design, or the lift attachment on the one blade -- but it sure leaves nice cut - and the 12 Kohler always enough power
  • Like 5
sqrlgtr
That's a PO fix and is actually 3 springs, works but will eventually get replaced.
  • Haha 1
953 nut
2 hours ago, sqrlgtr said:
PO fix
:ROTF:              I always blame things on the previous owner too.           :hide:
  • Haha 2
8ntruck
@Brockport Bill what is the story on that 'lift attachment' on your 37 SD?
kpinnc
That and several other things combined. The two blade design means the blades are longer which gives a higher tip speed for a given input RPM. The design of the deck also provides much higher lift per revolution and distributes clippings better as well.
The only downside to the 37SD is that it's only 37 inches wide. Otherwise it's probably the best cutting deck Wheel Horse ever produced. The 60SD cuts very nice as well. Both are actually Toro "influenced".
Of course the kind of grass and how often it is cut and how well a given deck is maintained are additional factors.
But overall the 37SD is optimized. The size is sacrificed to give the best cut for it's given application. If you know you know. :thumbs:
Edited by kpinnc
Brockport Bill
That blade lift piece is OEM ....i have bagger system which on my 312-8 with 37 deck apparently was engineered by wh to provide the thrust/turbulence etc to send grass leaves etc freely up tube without needing the assist units required on the 42 and 48 bagger systems
Brockport Bill
here are some photos of the 312-8 with bagger system as well as the underneath of a 37 deck with the 2 blades and the lift attachments on the outside blade to propel the clippings and leaves up the chute
MainelyWheelhorse
I had the same system which the original owner bought new on my 312-8. I never got to use it. I still have the same deck on that tractor. The deck size and configuration along with the 12 horse garden tractor definitely work well together.
sqrlgtr
A little patch work on hieght adjustment on the 4” deck off of 312-8 I been working on. Its on discharge side of deck all the other decks I have seen where on the other side?
MainelyWheelhorse
No pics today but I worked on the 308 more after work. Since I was giving things a once over I also checked the PTO on the engine which was greased but I gave it a bit more. I did find that the PTO clutch was worn flat. Off to the parts bin I went for a used but good one. I greased the mule drive too as the pulleys were good but almost stuck on the shaft. A bit of grease and that was good. A bit more adjustment and I’ll be good.
Handy Don
You may want to go back and remove some of that grease. “More is better” is NOT the motto for PTO lubrication since if it gets warm, the grease can migrate to, and fatally contaminate, the clutch plate.
MainelyWheelhorse
@Handy Don I should be ok. The grease is wheel bearing grease. The bearing inside the bell that rides on the shaft just got a skim. I don’t remember the last time I was in there. It was just enough to lube it. The clutch seemed to work fine with no excessive slipping squealing or weird smells after since I tested the deck out once I put it back together.
fiftyfordfloored
I'm getting very close to being in trouble, but I managed to sneak another one home.  Pretty sure it is a 701.  Hard to see in the photo but the sticker under the "K" in Kohler still faintly reads 7hp.  Not entirely sure where the seat came from...  There is a funky back rest, not sure if this was ever an option or accessory?
ineedanother
Interestingly, when I subscribed to a machine of a different color :ph34r::hide:, I ran old units from the '60s, s/g 10 and 12hp for the most part. 36" decks were surprisingly poorer performers compared to 48" or larger under the same tractors. The longer blades in good shape just performed much, much better and didn't drag power away like I thought they would. A product of inertia when the longer blades are turning? IDK.
