Pullstart 69,792 #25826 Posted Tuesday at 07:23 AM 3 hours ago, cafoose said: Nope @Pullstart tore up a wobble box running one too fast so I got that off the jungle site to slow it down. Not so much did I tear up a wobble box, but I rattled apart the Frankensteined sickle bar between the Jari and David Bradley components on “Edward” my first sickle creation a few years back. 2 1 Share this post Link to post Share on other sites
Pullstart 69,792 #25827 Posted Tuesday at 07:23 AM 4 Share this post Link to post Share on other sites
953 nut 65,345 #25828 Posted Tuesday at 01:24 PM 9 hours ago, cafoose said: tore up a wobble box running one too fast so I got that off the jungle site to slow it down Slow is good, keeps the vibrations down so it won't rattle the teeth out of your head. 7 Share this post Link to post Share on other sites
Sodaking27 1,152 #25829 Posted Tuesday at 07:37 PM (edited) Finally got some time to start the engine swap on the C175. Next up is a good pressure wash before starting the install. Need to find a 5.25” (hydro) pulley. I broke a chunk out trying to get it off. Edited Tuesday at 11:40 PM by Sodaking27 4 2 Share this post Link to post Share on other sites
ebinmaine 78,356 #25830 Posted Tuesday at 08:18 PM 40 minutes ago, Sodaking27 said: Need to find a 5 1/2” pulley. Check with @76c12091520h Brian Badman Share this post Link to post Share on other sites
Ed Kennell 45,797 #25831 Posted Tuesday at 08:45 PM Got some fence lines mowed before the rain starts. Checked out tomorrows auction. An interesting boat. And a Commando 800 9 1 Share this post Link to post Share on other sites
squonk 46,163 #25832 Posted Tuesday at 09:18 PM 30 minutes ago, Ed Kennell said: . Checked out tomorrows auction. An interesting boat. That would look good in @Pullstart's pool! 1 7 Share this post Link to post Share on other sites
Wishin4a416 2,568 #25833 Posted Tuesday at 09:22 PM Put a tube in front tire. Tired of pumping it up even though it sits 5 feet from the compressor. 5 2 Share this post Link to post Share on other sites
CasaytheMann 47 #25834 Posted 21 hours ago (edited) Decided to try to locate a fuel leak in the carburetor area. I ended up finding that the fuel solenoid rod head (don't know the real name) was slightly bent and not sealing 100%. I'm posting a picture but the bend might not be enough to see in it. I installed a new solenoid and associated wire harness, because the original connector was too loose. The new solenoid has a rubber covering over the head. Edited 21 hours ago by CasaytheMann 6 Share this post Link to post Share on other sites
Pullstart 69,792 #25835 Posted 13 hours ago @CasaytheMann nice work! Make sure to use no ethanol fuel with that rubber snubber, ethanol tends to wreak havoc on rubber components 1 1 Share this post Link to post Share on other sites
CasaytheMann 47 #25836 Posted 5 hours ago I thought all gas has ethanol. Share this post Link to post Share on other sites
ebinmaine 78,356 #25837 Posted 5 hours ago 4 minutes ago, CasaytheMann said: I thought all gas has ethanol. Depends where you live. Here in Maine non ethanol fuel is readily available. CT, not so much. Avoid ethanol if at all possible. Search here: Pure-gas.org Share this post Link to post Share on other sites
19richie66 17,865 #25838 Posted 5 hours ago 23 hours ago, Sodaking27 said: Need to find a 5.25” (hydro) pulley. I broke a chunk out trying to get it off. I may have one. Have to check. Message later to remind me. Yours for shipping cost 2 Share this post Link to post Share on other sites
Sodaking27 1,152 #25839 Posted 5 hours ago 4 minutes ago, 19richie66 said: I may have one. Have to check. Message later to remind me. Yours for shipping cost I’ll be sure to send you a message. Thanks.. 1 Share this post Link to post Share on other sites
Handy Don 16,293 #25840 Posted 3 hours ago 2 hours ago, ebinmaine said: Depends where you live. Here in Maine non ethanol fuel is readily available. CT, not so much. Non-ethanol seems to be more available in areas that have lots of agricultural equipment, boating, and general aviation customers. Metropolitan areas, rarely. Where it is available, it’s frequently 91 Octane and priced at or a bit below super premium. Often it is a separate hose or even a separate pump. In some upstate NY stations, I’ve seen the pump have its own island! When storing non-ethanol gas be sure to keep the container very tightly sealed. Since “pure gas” has no alcohol to bind with moisture, any water that enters the container (condensation, for example) remains separate--possibly causing rust or being transferred to your tractor when refueling. 1 Share this post Link to post Share on other sites
CasaytheMann 47 #25841 Posted 1 hour ago (edited) No non-ethanol stations anywhere near me, unfortunately. I just looked at the Owner's Manual. It says unleaded gas with less than 10% ethanol is ok. Edited 1 hour ago by CasaytheMann Share this post Link to post Share on other sites
Chris689 182 #25842 Posted 1 hour ago (edited) Finally got to split the trans for the 10-8 today. Sure did have some water in it. Got it cleaned up, replaced all the seals and reassembled. Got it back installed but now needs some new woodruff keys for the axles and drive pulley. In theory it’ll be back up and moving under its own power Monday. Edited 13 minutes ago by Chris689 1 Share this post Link to post Share on other sites
ebinmaine 78,356 #25843 Posted 1 hour ago 40 minutes ago, CasaytheMann said: Owner's Manual. It says unleaded gas with less than 10% ethanol is ok. They HAD to write that .... Reality is a little different. Just be sure to carefully check ALL rubber fuel components. Replace all the lines. Rebuild the carb. Rebuild the fuel pump. Carefully clean out the tank. A little work now saves multitudes of headaches later. 1 Share this post Link to post Share on other sites
mrc 1,071 #25844 Posted 4 minutes ago CasaytheMann, when you say "there are no gas stations near you that sell non-ethanol gas" please define 'near you' the reason i and others on here are sooo adamant about using pure gas is because the ethanol crap causes sooo many headaches down the road. i travel a little over 1 hour each way to get pure gas. for me it is time well spent. Share this post Link to post Share on other sites
