ebinmaine 75,775 #25126 Posted Sunday at 09:33 PM Got some shop time today. Popped a couple 520H tie rods off for a fellow Redsquare member. Trina got the Military Tribute Tractor "Millie" in for a couple belts. The S/G belt was so worn the unit was barely charging. The drive belt was also well worn. We did some investigating here and found that the universal transmission pulley was too wide and also too deep. 68" belt is far too short. 70" too long... Unfortunately the middle option of 69" belt was also about two hairs too long. This tractor has a 6 speed that had no pulley with it. I believe the best course would be to get a bushing from 3/4" down to 5/8" so she can use the original 3 speed pulley. We do need to figure out how to find that bushing/ adapter. @Achto @kpinnc or others? We also found the belt guard is bent and/or has a broken section near the engine. Trina filed that down. 5 5 Share this post Link to post Share on other sites
Achto 30,205 #25127 Posted Sunday at 09:53 PM 19 minutes ago, ebinmaine said: We do need to figure out how to find that bushing/ adapter. @Achto @kpinnc or others? https://www.ebay.com/itm/374229841487 1 1 Share this post Link to post Share on other sites
Ed Kennell 43,789 #25128 Posted Sunday at 09:56 PM 36 minutes ago, Lane Ranger said: the angle rod push pin fell out of the rod! Yep, happened to me once. Replaced my hairpin clip with a cotter pin. Share this post Link to post Share on other sites
sqrlgtr 1,342 #25129 Posted Sunday at 10:39 PM 1 hour ago, Lane Ranger said: Sunday December 14, 2025 after the big and cold snowstorm! 6 inches of snow and about ten degrees this am. I cleaned off my driveway and my neighbors! The 1974 Wheel Horse 8 hp B-80 worked great! Those little 8's sure punch above their weight. 2 Share this post Link to post Share on other sites
kpinnc 16,202 #25130 Posted Sunday at 11:42 PM 2 hours ago, ebinmaine said: We do need to figure out how to find that bushing/ adapter. @Achto beat me to it. 1 1 Share this post Link to post Share on other sites
ebinmaine 75,775 #25131 Posted Sunday at 11:51 PM @Achto Thanks man! 1 Share this post Link to post Share on other sites
Blue Chips 402 #25132 Posted Monday at 12:04 AM (edited) I got one step closer to putting the snowblower on my 522xi. I replaced the flaky old PTO clutch (which slipped intermittently when it was warmed up) with a new aftermarket unit. As far as I can tell, the build/fit/finish looks as good as the old clutch, which I assume is the original, since the machine had very low hours on it when I bought it years ago. The only difference I noticed is that the new clutch hub doesn't extend as far forward as the old one, making it a bit harder to get a good grip on it with a 1-1/2" wrench. The new clutch came with a 1/4-inch-thick washer to make up for it (based, I suppose, on the assumption that the user would install a replacement bolt of the same length as the old one), but instead of using the thick washer, I opted for a 1/4-inch shorter replacement bolt of the same grade as the original and torqued per the service manual instructions. After installing the clutch, in hindsight it occurred to me that I 'might' have been able to swap the old hub for the new one to make it easier to get a wrench on it, but it's in now and working fine, so it will stay that way. Edited Monday at 12:23 AM by Blue Chips 4 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,183 #25133 Posted Monday at 08:57 PM Yesterday we got some snow. Saturday I put the blade on the c-145 since my C-120 that is supposed to have a plow on it is in pieces. Yesterday morning put a new scraper blade from a public works snowplow on. That should last awhile! Then it was time to shine. Love plowing fluffy snow! And today did a bit more cleanup. IMG_1281.mov 4 8 Share this post Link to post Share on other sites
lynnmor 8,259 #25134 Posted Tuesday at 12:24 PM On 12/14/2025 at 4:17 PM, Lane Ranger said: The 1974 Wheel Horse 8 hp B-80 worked great! When i went to my neighbors to plow the angle rod push pin fell out of the rod! Went back to the garage to retrieve another! Back in business. I gave up on using any kind of easy to use pins there, now I use only cotter pins and bend them both ways. I replace them as needed. 5 1 Share this post Link to post Share on other sites
Handy Don 15,205 #25135 Posted Tuesday at 03:33 PM 3 hours ago, lynnmor said: I gave up on using any kind of easy to use pins there, now I use only cotter pins and bend them both ways. I replace them as needed. If you aren’t gonna switch to Heim joints, cotters (with a washer) are strong and tenacious! 2 Share this post Link to post Share on other sites
Blue Chips 402 #25136 Posted Tuesday at 09:07 PM (edited) The foam seal between the engine blower housing and the bulkhead had deteriorated on both my GT18 and my 522xi, so I installed new foam seals today. I managed to do it without removing the bulkheads or pulling the engines, but it was a bit tedious. I thoroughly cleaned the surfaces with a solvent rag wrapped around the end of a rod, cut new foam strips out of oil-resistant, closed-cell foam, brushed 3M 90 adhesive onto the bulkhead surfaces, and pushed the foam strips into place with a rod while the adhesive was still wet. It turned out pretty good, and I was able to get them sealed about 95% of the way around the fan openings. The foam seal should improve the cooling air flow by reducing the amount of hot air around the engine that gets drawn back past the bulkhead and into the engine's fan inlet, so hopefully these engines will run a little cooler. Edited Tuesday at 09:23 PM by Blue Chips 1 Share this post Link to post Share on other sites
dmoore 1,020 #25137 Posted Tuesday at 09:10 PM Nothing left to do on either 3 of mine! I need another! 3 Share this post Link to post Share on other sites
Handy Don 15,205 #25138 Posted Tuesday at 09:30 PM 22 minutes ago, Blue Chips said: so hopefully these engines will run a little cooler. Might also take out a bit of noise? 1 Share this post Link to post Share on other sites
Stan50 45 #25139 Posted 4 hours ago New throttle cable installed, way better performance. Thanks to Forum I've been able to remove that knob with ease.... 3 Share this post Link to post Share on other sites
