Ed Kennell
What have you done to your Wheel Horse today?
Ed Kennell
36 minutes ago, Lane Ranger said:
the angle rod push pin fell out of the rod!
Yep, happened to me once.   Replaced my hairpin clip with a cotter pin.
sqrlgtr
1 hour ago, Lane Ranger said:
Sunday December 14, 2025 after the big and cold snowstorm!  6 inches of snow and about ten degrees this am.  I cleaned off my driveway and my neighbors!
The 1974 Wheel Horse 8 hp B-80 worked great!
Those little 8's sure punch above their weight.:violence-blades:
kpinnc
2 hours ago, ebinmaine said:
We do need to figure out how to find that bushing/ adapter.
@Achto beat me to it.
ebinmaine
@Achto
Thanks man!
Blue Chips
I got one step closer to putting the snowblower on my 522xi. I replaced the flaky old PTO clutch (which slipped intermittently when it was warmed up) with a new aftermarket unit. As far as I can tell, the build/fit/finish looks as good as the old clutch, which I assume is the original, since the machine had very low hours on it when I bought it years ago. The only difference I noticed is that the new clutch hub doesn't extend as far forward as the old one, making it a bit harder to get a good grip on it with a 1-1/2" wrench. The new clutch came with a 1/4-inch-thick washer to make up for it (based, I suppose, on the assumption that the user would install a replacement bolt of the same length as the old one), but instead of using the thick washer, I opted for a 1/4-inch shorter replacement bolt of the same grade as the original and torqued per the service manual instructions.
After installing the clutch, in hindsight it occurred to me that I 'might' have been able to swap the old hub for the new one to make it easier to get a wrench on it, but it's in now and working fine, so it will stay that way.
Edited by Blue Chips
  • Like 4
lynnmor
On 12/14/2025 at 4:17 PM, Lane Ranger said:
The 1974 Wheel Horse 8 hp B-80 worked great!  When i went to my neighbors to plow the angle rod push pin fell out of the rod!   Went back to the garage to retrieve another!
Back in business.
I gave up on using any kind of easy to use pins there, now I use only cotter pins and bend them both ways. I replace them as needed.
  • Like 5
Handy Don
If you aren’t gonna switch to Heim joints, cotters (with a washer) are strong and tenacious!
Blue Chips
The foam seal between the engine blower housing and the bulkhead had deteriorated on both my GT18 and my 522xi, so I installed new foam seals today. I managed to do it without removing the bulkheads or pulling the engines, but it was a bit tedious. I thoroughly cleaned the surfaces with a solvent rag wrapped around the end of a rod, cut new foam strips out of oil-resistant, closed-cell foam, brushed 3M 90 adhesive onto the bulkhead surfaces, and pushed the foam strips into place with a rod while the adhesive was still wet. It turned out pretty good, and I was able to get them sealed about 95% of the way around the fan openings.
The foam seal should improve the cooling air flow by reducing the amount of hot air around the engine that gets drawn back past the bulkhead and into the engine's fan inlet, so hopefully these engines will run a little cooler.
dmoore
Nothing left to do on either 3 of mine! I need another!:lol::lol::lol:
  • Haha 3
Handy Don
Might also take out a bit of noise?
Stan50
New throttle cable installed, way better performance. Thanks to Forum I've been able to remove that knob with ease....
