Ed Kennell
What have you done to your Wheel Horse today?
Bar Nuthin
4 hours ago, Handy Don said:
I’d look for the clutch tensioner/idler gone whack-a-doodle.
:text-yeahthat:
Lee1977
What most of us do it throw it away and just use the clutch spring on the left side.
I usually keep a spare ( 108035 clutch spring ) in my parts drawer.  It attaches to the the clutch bracket and the hole in the brace web on the axle housing.
  • Like 4
Handy Don
And then it can take a bit of repetition to adjust your muscle memory for releasing the clutch!
peter lena
@Handy Don   you can probably relate t this , seen more  rusted / bound  saposed to be , movement spots on  horses , wheelies , and related violent  engagement  , should not be a brag point . in the same engagement  zone as  a  screaming  , pto  lever  .  and related  pulley drag ,  definitely a  corrective  problem .  if they are addressed  correctly  , the problems go away  , pete
Handy Don
1 hour ago, peter lena said:
you can probably relate to this
On my first meeting @wallfish, he lent me an RJ to tool around the Big Show. He emphatically cautioned me about its touchy clutch and willingness to wheelie. Having driven standard shift vehicles since before having a driver’s license, I paid heed and never had the front wheels more than a couple inches off the ground.
Predictability and muscle memory are essential for clutching.
We more mechanically-inclined and capable members do have to keep in mind that things mechanical and electrical can intimidate some of those who join the forum looking for an assist. They often need very specific and detailed answers along with reassurance.
Edited by Handy Don
  • Excellent 3
  • Heart 2
Red Stallion
I'm back on the Wheelhorse wagon now that winter has passed. Finished up the last of my painting, and started putting it all back together...
But now I can't remember how it all goes together!
Anyone got a picture of their seat pan and seat assembly? I don't think my springs are right.
  • Like 5
Ed Kennell
That looks correct to me.  I added a chunk of rubber to stiffen each spring.
I also add a piece of rubber for the springs to rest on.   Make sure you leave a hole for the seat switch.
  • Like 8
Lee1977
I see you have a 520-H and the seat is adjustable. The seat springs will bolt up eater way.  You can move the seat closer or farther back by witch way they are mounted.
Red Stallion
Thanks guys!
I was thinking the rubber trick as I have some left over from the foot wells. The paint is so soft that the springs will chew through it within the first 100m of me bouncing on it.
Handy Don
10 minutes ago, WHX?? said:
Is there a reason why it wasn’t mounted to wear perpendicular to the mounting holes?
wallfish
48 minutes ago, WHX?? said:
A snow shoe needed repairing
That, or you coulda just used that thin part to set your points! LOL
You got your money's worth outta that one
  • Haha 5
WHX??
Yep ... it seems no matter how tight those bolts are they always seem to be they always move. In the heat of the battle the blower gets dropped a little hard and that's what does it. Then they get covered with snow & ice & go unnoticed until spring thaw.  Along with the scraper blade they are meant to wear I guess. Actually a good thing to advance my welding skills. :)
PO had them like this but the adjustability goes out the window.
Edited by WHX??
  • Like 5
lynnmor
Apparently it is a common problem, every time I check mine they need a readjustment.
Lane Ranger
This is one example of where Wheel Horse employees downgraded  their quality in my opinion.   The old steel wheel snowblower setup  was a better idea.
  • Like 5
  • Excellent 2
Ed Kennell
When I still had blowers., I also liked the old style  with wheels.    Made the blowers so easy to move around when off the tractor
  • Like 7
Blue Chips
Worked on restoring the headlights on the 522xi. I had good luck with the headlight reflector, but not quite as good with the lens.
For the reflector, after cleaning and a light bead blasting to roughen the surface slightly, I sprayed it with "Rust-Oleum Automotive 600 Degree Aluminum Engine Enamel," which is great paint. It's quite shiny and adheres really well, although the overspray is messy as it sticks to everything within several feet of where you're spraying. I then top-coated it with "Rust-Oleum Automotive 600 Degree Gloss Clear Engine Enamel." I think the reflector is 'almost' as reflective as the original surface, and it should hold up well.
The headlight lens is much better than it was before (brownish yellow, almost opaque, and heavily oxidized), but it's still rather milky after I spent almost two hours polishing it halfway to China, using all kinds of approaches, including progressively finer sandpaper, headlight restorer kit, polishing compounds, wax, etc. I think the milkiness is very deep, so I guess I'll either have to put up with it or buy a new or used replacement lens. New ones are still available, but kind of expensive.
By contrast, the headlight lens on my GT18 (the same kind of lens) cleaned up beautifully (below) and is crystal clear. I guess my 522xi must have spent a lot more time outside in the sun than the GT18.
Edited by Blue Chips
  • Like 6
  • Excellent 3
adsm08
Not really to, but with:
The first post I couldn't get balanced on the dolly well because there wasn't enough room to work, so I had to leave it attached to the engine crane too. The whole thing was too heavy and unbalanced for me to push up the ramp to the garage by myself, so I got to thinking about my options. The 855 has the plow on, plows are for pushing things. Fired it up and set the plow at the right height to engage the base of the post, and  up the hill we went.
Do we have a "What have you done WITH your WH today?" thread?
  • Like 8
rjg854
A post in the general forum by Mickwhit, "What did you do Today"
WHX??
There is one probably  in the basement ... how did you work your :wh: or somethin like that.
ebinmaine
There used to be one and it disappeared for some reason. Perhaps @nylyon or @Sparky remembers why....
That was when this particular thread was started.
I've kind of gotten into the habit over the years that,  if I used my Wheelhorse it goes in this thread. If I didn't use my Wheelhorse it goes in the other thread, "What did you do today?"
nylyon
I don’t recall a what did you do with your wheel horse today thread.
