Ed Kennell
What have you done to your Wheel Horse today?
peter lena
@sqrlgtr  have mine for years now , amazingly  smooth . easy to  operate . my reference to the lower , squeeze lever  , shoulder bolt swing point  is a vital one . as I originally  set mine up , went after  every  hang up area , also set it up on 2 milk crates , so I could,roller stool around it  experiment  with swing quadrant reaction . came to shoulder bolt  m as the  SMOOTH , SWING  lever  main issue , correction . dialed in funcion , with flat washers on each side of  its , threaded / smooth  areas , used a regular  nut to experiment  with , once found , remove regular nut , held setting with a , elastic lock nut . then squeeze lever response , to  quadrant slide pin , like aerosol red grease , its so smooth easy  function is still amazing  , top off with a lubricated finish  for snow slide off  , also added a heim joint to my pto lever rod end , smooth / solid  , enhanced that  battery tray , start area . hides in plane site  , glad you are doing it  , pete
ebinmaine
1 hour ago, sqrlgtr said:
 the first hole from middle gets used a lot.
Exactly my logic...
Really more for Trina's smaller & lighter tractors.
She has a LOT of steering issues when it's anywhere near slippery out. Like in the snow. When plowing....
Every time.
I'm thinking if her plow blade was angled less it might be better.
ri702bill
2 hours ago, ebinmaine said:
how did you drill that? Is that nasty steal to get through? I've been considering doing that for several years.
That was done at work in a milling machine.... That hot rolled steel can be difficult. HRS has a thin "coating" if you would - like scale. I used an endmill to break thru that, then drilled it to size. Perhaps a masonry bit would work. Hardest part was adding the angled lead-in - had to hand file a lot of it due to the radius.....
sqrlgtr
1 hour ago, ebinmaine said:
Exactly my logic...
Every time.
I usaally have loaded tires for snow removal and helps a lot but you get enough snow it will push you side ways for sure. The first hole past center doesn't shed the snow as much so there is a tradeoff. I like it because it makes a wider path for tractor and seems to work better when making long sweeping turn....
ebinmaine
Trina and I have two very different machine preferences overall.
She likes her short frame light weight quick steering 8 HP rigs.
Mine are all long frame very heavy 16 HP.
We've tried 4 fluid filled tires on her 867. It was NOT happy. Sluggish.
The rears also have steel weights.
We knocked it back to fronts being filled only and kept the rear steel.. it's definitely better.
It steers reasonably well. As stated above the hard tilting plow with any volume of snow is an issue.
Mine.... HEAVY.
I have 4 oversized fluid filled tires. Steel weights on the back. A huge plow blade.
All go. No issues except a heavy sticky snow several inches deep.
Most of our work is that exact type of turn....
sqrlgtr
@ebinmaine I love driving and the looks of the short frame tractors (square and round hood), but when it gets serious I like the ol c-160 with the loaded tires all way around and that is usually what I plow snow with but am going to try the 1257 this year, only because it has Hy unit and sure is sweet not having to pull that plow up manually :D. The 1257 does have wheel weights on all four corners. It is snowing here right now but don't think we will get enough to play in...
ebinmaine
One flake.
JUST ONE FLAKE!!!
:occasion-snowman:
  • Haha 3
kpinnc
One flake.
JUST ONE FLAKE!!!
Snowed here for about 30 mins. Light flurries with no accumulation. First November snow in years.
Racinbob
3 hours ago, ebinmaine said:
One flake.
JUST ONE FLAKE!!!
:occasion-snowman:
Some records around here. We got about 5" and that will be it. Our daughter about 15 miles from here has 14" and still counting. Goofy lake effect.
ebinmaine
Meanwhile... here in Maine...
Yesterday we had mid 40s and rain.
This morning however,  30⁰ and everything is frozen solid.
Ed Kennell
28F and 15mph winds this morning.  Good day to stay close to the wood stove.
  • Excellent 2
sqrlgtr
Absolutely
we did get snow but dont think I will have to put my chains on yet.;)
702854boy
On Sunday, I was looking at a broken creeper and realized the headrest piece looked a lot like the wooden back for the round hood back rests so, I took it off and put it in my brother's lawn Ranger it looks like it was meant to be
  • Like 4
sqrlgtr
Put modified push/pull rod and modified main pivot  pin back on 1257 snow plow. Also angle lever was on plow bass ackwards :eusa-think:. I always thought there was sumin different about this plow and just assumed lever was harder to reach because it was a long frame plow!!!!! What a dummy, so much easier to reach now. Last pic is way it was before and I forgot to take a pic after I turned it around :angry-banghead:
  • Excellent 2
kpinnc
The temps dropped here rapidly yesterday evening. Wind chills in the teens.
I let my dog out last night, and I wish I'd made a video. He slid to a stop and ran back inside and dove under the bed. I can't say I blame him! :lol:
  • Haha 5
ebinmaine
I've run em that way on purpose to make Bear reach Freedom of movement.
I do have looonng ape arms though.
  • Haha 2
sqrlgtr
Before I turned it around, I was setting on top of shifter to reach trigger on handle :D.
  • Haha 2
kpinnc
  • Haha 4
ebinmaine
YES!!
  • Haha 1
cafoose
:eek:
  • Haha 3
sqrlgtr
Is that a bearillo or goribeararilo
30 minutes ago, kpinnc said:
  • Haha 1
ebinmaine
Yes
  • Haha 1
