lynnmor 7,824 #24201 Posted July 29 2 hours ago, ebinmaine said: Brakes. Well... Inadequate for slowing and stopping. Fixed that sentence for you. 1 Share this post Link to post Share on other sites
ebinmaine 72,719 #24202 Posted July 29 4 minutes ago, lynnmor said: Fixed that sentence for you. Gotta give ya that one Share this post Link to post Share on other sites
Shed 293 #24203 Posted July 29 4 hours ago, ebinmaine said: Some things to keep in mind about speeding up a Wheelhorse. Unidrive bearings. The bearings in these transmissions have limitations like anything else. I've read that the race mower crowd seems to think 20 - 25 is a lot for these. Brakes. Well... Inadequate for high speed slowing and stopping. Tie rods. You will NEED to change the tie rods to a different type altogether. Steering. The steering system as a whole is actually very loose the way it was designed... for 6 mph. Put that to a 5X and it'll be startling. If you've never been on a "fast" garden tractor you'd be shocked at what 12 mph feels like. 20+ is obviously doable but there are serious considerations to be addressed. This wasn't built for speed it doesn't have the stock transmission at all but a separate gear box and a tourqe convertor now all chain drive. It has rear disc brakes not installed yet. But I was just joking around with the comment about the Bonneville salt flats. It should have good tourqe though with the gearing I picked. 60 tooth axle sprocket and two jack shaft type reduction setups and the belt driven tourqe convertor. The steering I'll clean up but for now I just need to get it together. If the flat bed doesn't look right I thought I'd make a gooseneck trailer for it and he can tow his pedal tractors and stuff. 1 3 1 Share this post Link to post Share on other sites
Pullstart 66,825 #24204 Posted July 31 I got this black hood running… and it works great! 2 1 2 Share this post Link to post Share on other sites
MainelyWheelhorse 1,520 #24205 Posted Friday at 12:35 AM Today, I repurposed a few extra coffee cups for workshop stuff. I built an exhaust pipe with assistance from my father and mounted the new muffler to it for the C -141. And drove it over to my house. it’s been it’s been sitting at my parents next door for the last 2 months or so. Just little things and painting now. 6 1 Share this post Link to post Share on other sites
Andy N. 2,393 #24206 Posted Saturday at 03:06 PM Productive few days of doing an engine swap on my 418-A with one that I found locally that has a transmission issue. The original is worn out and starting to use alot of oil. It's all back together now and I mowed with it yesterday and the newer engine is working good so far. I also took the opportunity to replace the lift actuator with a unit that I rebuilt this past winter. 3 8 Share this post Link to post Share on other sites
WHX?? 51,777 #24207 Posted Saturday at 03:29 PM SCORED! 12 1 Share this post Link to post Share on other sites
pfrederi 18,689 #24208 Posted Saturday at 06:39 PM (edited) Not my brightest day ...I had been sorting through my box of spark pugs... went to the Workhorse GT-1848 to see what plugs were in the B&S twin. pulled the front plug found it to be Bosch concentrated very hard on remembering the plug number. Went to mow later she didn't start well and was running a bit rough but when i engaged the blades something was wrong as she slowed way down. Opened the hood and you guessed it ...I hadn't put the plug wire back on... a 9 hp B&S can't handle hydro and 48" deck Edited Saturday at 07:50 PM by pfrederi 7 Share this post Link to post Share on other sites
lynnmor 7,824 #24209 Posted Saturday at 08:48 PM 2 hours ago, pfrederi said: I hadn't put the plug wire back on... a 9 hp B&S can't handle hydro and 48" deck It wasn't even 9 HP, some of that HP was used pulling the dead one along. 3 Share this post Link to post Share on other sites
rjg854 12,209 #24210 Posted Saturday at 09:08 PM 2 hours ago, pfrederi said: hadn't put the plug wire back on... a 9 hp B&S can't handle hydro and 48" deck I think we've all pulled things similar to that 😅 2 2 Share this post Link to post Share on other sites
MainelyWheelhorse 1,520 #24211 Posted Sunday at 01:13 AM (edited) Today, after work I took the C-141 for a spin then modified the new exhaust pipe, removing a little over an inch, painted it and attempted to build a battery hold down for it. no pics as I was really getting into it. Edited Sunday at 01:14 AM by MainelyWheelhorse 3 Share this post Link to post Share on other sites
adsm08 3,265 #24212 Posted Sunday at 08:23 PM Did a little work addressing some running issues on the Commando. Found the plug carbon fouled and the points set at about .002". Reset the points, got a new plug, it seems to be better, but I didn't drive it, I just left it run for a bit. I also replaced the plug in the 855 after noticing it was the wrong one. 2 Share this post Link to post Share on other sites
horseman with no horse 30 #24213 Posted yesterday at 02:35 AM 855 7 slot grille cold start today. https://www.youtube.com/shorts/D0uM71cHmt4 1 Share this post Link to post Share on other sites
Pullstart 66,825 #24214 Posted 22 hours ago On 7/30/2025 at 8:25 PM, Pullstart said: I got this black hood running… and it works great! 1 2 1 Share this post Link to post Share on other sites
Shed 293 #24215 Posted 22 hours ago Latest of my build the bed still not done 6 1 Share this post Link to post Share on other sites
Ed Kennell 42,042 #24216 Posted 21 hours ago 15 minutes ago, Shed said: Latest of my build the bed still not done Not sure if it will be a problem, but I would prefer to see that long brake rod in tension rather than compression. 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,443 #24217 Posted 21 hours ago 28 minutes ago, Pullstart said: I got this black hood running… and it works great! She's purdy!!! Can't wait to see if that seat makes my butt look fat... 3 Share this post Link to post Share on other sites
Pullstart 66,825 #24218 Posted 21 hours ago @Shed that’s great! Any idea the load capacity of the axle? That’s 1”, correct? 1 Share this post Link to post Share on other sites
Shed 293 #24219 Posted 20 hours ago 46 minutes ago, Pullstart said: @Shed that’s great! Any idea the load capacity of the axle? That’s 1”, correct? I was told around 250 pounds Share this post Link to post Share on other sites
Shed 293 #24220 Posted 20 hours ago 1 hour ago, Ed Kennell said: Not sure if it will be a problem, but I would prefer to see that long brake rod in tension rather than compression. I would have to make another Z bar some how. I wanted it to pull but couldn't get it to work any ideas Share this post Link to post Share on other sites
8ntruck 7,842 #24221 Posted 18 hours ago 1 hour ago, Shed said: I would have to make another Z bar some how. I wanted it to pull but couldn't get it to work any ideas How about a cable instead of a rod? Share this post Link to post Share on other sites
Handy Don 14,076 #24222 Posted 15 hours ago (edited) Posting today because the work was last week at my son and daughter’s extremely remote and off-the-grid camp. “Clyde” (the camp tractor) needed some attention—reports from the field declared it was hard-starting, had grown loud, and was running poorly, requiring some choke always. I brought a replacement muffler, carb, and other parts it might need. Muffler had a number of rust-through holes. Replaced it and gained a 5 or 6db drop in sound level. Fuel was draining back from carb to tank after only a couple days. Added a primer bulb and starts are instantaneous. Rough running cause was revealed during the muffler swap—the Welch plug on the carb had fallen out. Amazingly, it was still there on top of the engine and I was able to clean out its port, wrangle it back into place and secure it. Going forward, I’ll be adding ⅜” Welch plugs to my spares kit as a guarantee that I’ll never need another one! Greased everything in sight and a lot of stuff that wasn’t. Topped up the oil in the engine and transaxle My “shop away from home.” A step up from relying on a shade tree. The tarp was a lifesaver when I inevitably dropped a nut, bolt, or washer. I took some heat about bringing a shop stool but by the end of the week all the assistants were converts. Sharpening one of the 80 knives on the flail mower. Had to replace six knives broken or lost due to overly enthusiastic attacks on saplings—I had some words for the operators on that 😉. Milwaukee’s ¾” x 18” M12 Bandfile is exactly the right tool for this job. I made a removable boom to fit into the 2” receiver of the front lift to help with moving around some heavy and awkward things. Until now, the lift was only used for the flail. Hoist.mov Edited 15 hours ago by Handy Don 5 Share this post Link to post Share on other sites
chip61 665 #24223 Posted 15 hours ago Tarp's a great idea, wish I had thought of that. Much better than searching the grass for a dropped nut or bolt. 1 Share this post Link to post Share on other sites
Ed Kennell 42,042 #24224 Posted 15 hours ago 5 hours ago, Shed said: any ideas You could use a rod that is less likely to bend. Maybe a length of 1/2" pipe and weld the 3/8" ends on. Share this post Link to post Share on other sites
kpinnc 14,651 #24225 Posted 12 hours ago 3 hours ago, Handy Don said: Sharpening one of the 80 knives on the flail mower. A flail mower, front or rear mount is one of the implements I hope to have one day. Definitely a useful tool! 1 Share this post Link to post Share on other sites
