HyperPete 788 #23226 Posted March 30 5 minutes ago, squonk said: Take the points cover off and try drying the points. I've had the points get wet even with a good gasket and grommet. A few shots with a blow gun and it fires right up. Thank you. Where's the points cover on these guys? I was figuring I was going to have to pull the flywheel to access them. I think I have downloaded every manual for the M8 - I guess they aren't going to read themselves. 1 Share this post Link to post Share on other sites
HyperPete 788 #23227 Posted March 30 (edited) Yay! No points! I think I'll be going through this. Edited March 30 by Pete D 1 Share this post Link to post Share on other sites
MainelyWheelhorse 1,354 #23228 Posted March 30 4 minutes ago, Pete D said: Yay! No points! I think I'll be going through this. @Pete D You beat me to it! I was just going to say I didn't think the Magnums had points. 2 Share this post Link to post Share on other sites
HyperPete 788 #23229 Posted March 31 Since I touched wiring, too, I'm going to completely replace the wire I re-spliced. I'm uncertain why a non-waterproof 30 amp fuse was installed in the solenoid control feed, but it's coming back out. (Just an additional point of failure to worry about.) I'm going through possibly problems, and I'm concerned about a possible high-draw starter. All grounds & connections have been cleaned to bare metal & protected with dielectric grease. I did not pull the starter bolts and clean the starter mounting surfaces, however. I guess I could remove the starter back cover to blow it out & check the brushes just to be safe. 1 Share this post Link to post Share on other sites
ML3 1,569 #23230 Posted March 31 Got optimistic & took snowplow off then installed mower deck. Lawn service already fertilized last week so grass is starting to grow. Also changed oil & greased all fittings. 11 5 Share this post Link to post Share on other sites
JoeM 8,162 #23231 Posted April 1 Cleaned up the C81 sluggish starter and got it working good. I did have to put a .010 shim under the front bolt. Brushes were good. Used a drill to turn the armature and cleaned the commutator with a stone. 5 3 1 Share this post Link to post Share on other sites
Handy Don 13,681 #23232 Posted April 1 (edited) 36 minutes ago, JoeM said: Used a drill to turn the armature and cleaned the commutator with a stone. Looks nice. Hoping you made sure to cut a bit of relief into the phenolic separating the commutator contacts and used compressed air to thoroughly remove any grinding/cleaning residue. Edited April 1 by Handy Don 3 Share this post Link to post Share on other sites
JoeM 8,162 #23233 Posted April 1 1 hour ago, Handy Don said: relief into the phenolic separating the commutator contacts and used compressed air Yep all good! 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 22,823 #23234 Posted April 1 A buddy welded up the fuel tank/fender support rails in the 520-8. Both sides cracked. 4 7 Share this post Link to post Share on other sites
HyperPete 788 #23235 Posted April 1 (edited) I replaced the starter solenoid. The wiring diagram shows an optional fuse that was in line with the solenoid, so I installed a waterproof fuse and replaced the previous wiring. When I looked, there was some sloppy electrical tape which I unwrapped and found the wire had been burnt and most of these strands were broken. I cut back beyond the damage and ran the new wire. Everything should be waterproof now, and the engine cranks. I have spark now, but it doesn't start. I used clear nail polish around the Welch plugs, and I'm afraid it may have gotten past them and blocked the air passages. Major DUH moment. I'm quite angry with myself. I have a ton of incredibly small drills so I will clean them out and try again. Hopefully, my local small engine shop sells Welch plugs. The other possibility is the fuel pump. I don't smell gas when I crank, even with the choke on, so after I'm sure that the carb is attached tightly and getting vacuum, I may reach out for assistance with these old fuel pumps. I know nothing about them. Edited April 1 by HyperPete 2 Share this post Link to post Share on other sites
ebinmaine 71,804 #23236 Posted April 1 7 minutes ago, HyperPete said: Hopefully, my local small engine shop sells Welch plugs. I have some. Tell me what size. I'll send a couple. They're aluminuminuminuminum. NOT steel. I get em from a place called Rick's Carbs I think?? 7 minutes ago, HyperPete said: The other possibility is the fuel pump. I don't smell gas when I crank, even with the troop on, so after I'm insure that the carb is bolted tightly and getting vacuumed, I may reach out for assistance with these old fuel pumps. I know nothing about them @Pullstart and @wallfish have both showed me a neat trick. Mebbe @Stepney too. With the carb air cleaner base off so your hand can sit flat on the carb front, start cranking the engine. Very quickly use your hand to completely cover the whole carb front for a half second. For some reason this often causes the engine to start. Super vacuum?? 1 Share this post Link to post Share on other sites
HyperPete 788 #23237 Posted April 1 3 minutes ago, ebinmaine said: I have some. Tell me what size. I'll send a couple I'll start with the local shop simply because I don't know what size. I'll bring the carb and let them match them. Thank you. 6 minutes ago, ebinmaine said: For some reason this often causes the engine to start. Super vacuum?? Yep, but it's a long reach! I'll ask the Mrs to help. 1 Share this post Link to post Share on other sites
Ed Kennell 41,323 #23238 Posted April 2 Put the rear weights back on the 310-8. These new wider wheels required longer bolts, so I fired up the mig bolt extender and added an inch. I know, the carriage bolt head is supposed to be inside the wheel. But I don't like the nuts sticking out on the outside. 6 9 Share this post Link to post Share on other sites
SylvanLakeWH 28,078 #23239 Posted April 3 3 hours ago, Ed Kennell said: But I don't like the nuts sticking out on the outside. And it maximizes aerodynamic efficiency when traveling at high speeds... better fuel economy... very green... 1 1 7 Share this post Link to post Share on other sites
Blasterdad 3,044 #23240 Posted April 3 (edited) Sunday we had a severe thunderstorm with 80 mph winds roll through. It snapped the top off a big pine tree in my side yard, taking some branches of the maple tree next to it on the way down. Monday I bought bar oil and a new chain for the saw. Tuesday after work I got it all cleaned up wth help from the C-81. From plowing at @Pullstart's plow day on Saturday, to yard duty on Tuesday, she's been a happy . Edited April 3 by Blasterdad 6 13 1 Share this post Link to post Share on other sites
953 nut 59,216 #23241 Posted April 3 9 hours ago, Blasterdad said: snapped the top off a big pine tree in my side yard, taking some branches of the maple tree next to it on the way down. Glad it missed the camper and building. 1 1 Share this post Link to post Share on other sites
Blasterdad 3,044 #23242 Posted April 3 13 minutes ago, 953 nut said: Glad it missed the camper and building. It was close! I was standing on the front porch when it happened. It was LOUD! Sounded to me like something hit the roof of the house. I ran through the side yard to go in the back door & didn't even see it till later, it was raining so hard. Lol. Was quite relieved that nothing hit the house. 4 Share this post Link to post Share on other sites
Handy Don 13,681 #23243 Posted April 3 4 hours ago, Blasterdad said: It was close! I was standing on the front porch when it happened. It was LOUD! Sounded to me like something hit the roof of the house. I ran through the side yard to go in the back door & didn't even see it till later, it was raining so hard. Lol. Was quite relieved that nothing hit the house. Run outside in pouring rain. Check Run outside in pouring rain during high wind event near trees. Check Quite relieved nothing landed on YOU! 1 Share this post Link to post Share on other sites
Blasterdad 3,044 #23244 Posted April 3 (edited) 3 hours ago, Handy Don said: Run outside in pouring rain. Check Run outside in pouring rain during high wind event near trees. Check Quite relieved nothing landed on YOU! When I went out front it wasn't raining. When the front blew in it happend in seconds & the front door was locked. Not one of my better thought out plans for sure. Edited April 3 by Blasterdad 3 Share this post Link to post Share on other sites
HyperPete 788 #23245 Posted April 4 Broke out the pressurized (canister) sandblaster today, finished blasting the weight box for the '73, and got a coat of primer on that and other related parts. Hopefully I'll get the red on tomorrow. Low end paint job; Rustoleum and a roller. Maybe I'll try to learn how to use a sprayer one of these days. I need to get an air feed for the sandblaster headgear and some gloves that won't fill up with media. (I'm going to try to modify an old CPAP machine to blow air into the hood.) 2 1 Share this post Link to post Share on other sites
MainelyWheelhorse 1,354 #23246 Posted April 4 I bought some stick on reflectors from Harbor Freight for the 308. The original ones on it are chipped pretty deeply. I'll drill out the old rivets and stick them on tomorrow. 2 Share this post Link to post Share on other sites
953 nut 59,216 #23247 Posted April 4 10 hours ago, HyperPete said: (I'm going to try to modify an old CPAP machine to blow air into the hood.) Lung transplants can be done but why take the chance? Filtration is the key here, not intending to rain on your parade but don't think an old CPAP will push enough air through a good filter. 1 Share this post Link to post Share on other sites
squonk 43,346 #23248 Posted April 4 (edited) Been working on the 1965 Fireball 8 that came out of my 875. This engine had some vertical scratches on the piston and the valve faces were dished pretty good. So new piston, rings and valves. I need to do a cleaning on the test stand carb a traitor! This is a spark advance/non compression release style engine. I'm going to put it in HHHOOOWWWAAARRRDDD!!! my 857. That engine stinks to high heaven when I use the tractor. So this engine will go in and I will rebuild the 857 engine and reinstall it when done. Then this 875 engine will be sold or put on the shelf. Edited April 4 by squonk 3 6 Share this post Link to post Share on other sites
ebinmaine 71,804 #23249 Posted April 4 1 minute ago, squonk said: Then this 875 engine will be sold or put on the shelf. If/when you decide to sell, let me know. Depending on half reasonable timing, Trina might be in the market again. Share this post Link to post Share on other sites
HyperPete 788 #23250 Posted April 4 7 hours ago, 953 nut said: Lung transplants can be done but why take the chance? Filtration is the key here, not intending to rain on your parade but don't think an old CPAP will push enough air through a good filter. I was using it with no air yesterday. It kept fogging up. I'm not sure how else to feed it, definitely NOT via the air compressor! Share this post Link to post Share on other sites
