ebinmaine 80,893 #22976 Posted February 16, 2025 14 minutes ago, adsm08 said: I can't fill the fluid, because I can't find the pointy bottle cap Still technically a win if you're not mopping up the floor. 1 Share this post Link to post Share on other sites
adsm08 5,193 #22977 Posted February 16, 2025 1 hour ago, ebinmaine said: Still technically a win if you're not mopping up the floor. Eh, I found it. I think there is still air to purge because I can't get the plow the whole way up. I've found a drill is better than the engine for that though. 1 Share this post Link to post Share on other sites
stvski80085 279 #22978 Posted February 17, 2025 Still working on the mower deck. Almost all pulleys with a bearing had to be replaced. Those are now ordered. Now doing a basic paint job to stop the rust. Want all the moving parts working as they should. Takes a long time but by next weekend I should start putting together. 3 10 Share this post Link to post Share on other sites
cleat 9,380 #22979 Posted February 17, 2025 1 hour ago, stvski80085 said: Still working on the mower deck. Almost all pulleys with a bearing had to be replaced. Those are now ordered. Now doing a basic paint job to stop the rust. Want all the moving parts working as they should. Takes a long time but by next weekend I should start putting together. Looks great so far. 2 1 Share this post Link to post Share on other sites
stvski80085 279 #22980 Posted February 17, 2025 From a few feet away it looks good. Not a perfect paint job but it's a mower deck so I'm ok with it. 2 Share this post Link to post Share on other sites
dmoore 1,042 #22981 Posted February 17, 2025 (edited) Last minute checks prior to big snowfall coming Wednesday evening. Edited February 17, 2025 by dmoore 4 18 Share this post Link to post Share on other sites
stvski80085 279 #22982 Posted February 18, 2025 22 hours ago, dmoore said: Last minute checks prior to big snowfall coming Wednesday evening. She is pretty. I want mine to look like that some day. 2 Share this post Link to post Share on other sites
dmoore 1,042 #22983 Posted February 18, 2025 I've had this C-101 (121 now) for 30 years. She's a worker that's had a little work done. Not Joan Rivers type of work but maybe Cindy Crawford 6 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #22984 Posted February 19, 2025 Well we didn't get the snow we were supposed to get. We have a nice ice glazing that will hang around a few days and got a snow dusting. So decided to have some fun in the 5 degree temps and do some spin outs and figure eights! 4 5 13 1 Share this post Link to post Share on other sites
dmoore 1,042 #22985 Posted February 20, 2025 Not enough to justify a startup. Drive right through. 4 Share this post Link to post Share on other sites
dmoore 1,042 #22986 Posted February 20, 2025 Darn 1 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,997 #22987 Posted February 21, 2025 I hooked up my plow weeks ago for nothing apparently. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,489 #22988 Posted February 21, 2025 On my 520-8 project: Got the transmission input shaft seal in (2nd attempt, destroyed the first seal )…installed fuel tank supports (still waiting on my fuel tank to be shipped).. carefully removed a wire harness from a “doner” tractor that originally had a Magnum 10 that I will blend with the 520’s Onan harness when I land the Kohler Magnum on it. 9 4 Share this post Link to post Share on other sites
953 nut 69,757 #22989 Posted February 22, 2025 On 2/18/2025 at 7:14 PM, OutdoorEnvy said: have some fun in the 5 degree temps and do some spin outs and figure eights! Figure skating with a Wheel Horse, I'd give that a 10. 2 4 Share this post Link to post Share on other sites
ebinmaine 80,893 #22990 Posted February 22, 2025 7 hours ago, Sparky said: Got the transmission input shaft seal in (2nd attempt, destroyed the first seal )… And now you have another reason for why I order in bulk. 7 hours ago, Sparky said: installed fuel tank supports (still waiting on my fuel tank to be shipped).. Man I wish I knew ya needed a tank. I only got like 9 here. 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #22991 Posted February 22, 2025 20 minutes ago, 953 nut said: Figure skating with a Wheel Horse, I'd give that a 10. LMAO! I’ll take it! I did stick the landing 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,489 #22992 Posted February 22, 2025 31 minutes ago, ebinmaine said: Man I wish I knew ya needed a tank. I only got like 9 here. Appreciate that…but I wanted one with a fuel sending unit so I can use the fuel gauge in the dash. 1 Share this post Link to post Share on other sites
ebinmaine 80,893 #22993 Posted February 22, 2025 13 minutes ago, Sparky said: Appreciate that…but I wanted one with a fuel sending unit so I can use the fuel gauge in the dash. One here with the mounting hole but no senders. Share this post Link to post Share on other sites
lynnmor 9,050 #22994 Posted February 22, 2025 35 minutes ago, Sparky said: Appreciate that…but I wanted one with a fuel sending unit so I can use the fuel gauge in the dash. A Dorman 55818 can be used in place of the original sending unit. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,489 #22995 Posted February 22, 2025 44 minutes ago, lynnmor said: A Dorman 55818 can be used in place of the original sending unit. Good to know, bought a used 520 tank off FB Marketplace that hopefully works. Share this post Link to post Share on other sites
wallfish 20,654 #22996 Posted February 22, 2025 10 hours ago, Sparky said: carefully removed a wire harness from a “doner” tractor that originally had a Magnum 10 that I will blend with the 520’s Onan harness when I land the Kohler Magnum on i HA, Look for the magic smoke and all of the black spots after you're done when troubleshooting the wiring issues! After all, Sparky is your name so no doubt you'll live up to that. LOL Bring a strap so I can tow you back to base camp at the Zag show! 4 Share this post Link to post Share on other sites
TonyToro 1,190 #22997 Posted February 22, 2025 19 hours ago, Sparky said: On my 520-8 project: Got the transmission input shaft seal in (2nd attempt, destroyed the first seal )…installed fuel tank supports (still waiting on my fuel tank to be shipped).. carefully removed a wire harness from a “doner” tractor that originally had a Magnum 10 that I will blend with the 520’s Onan harness when I land the Kohler Magnum on it. We have a few tanks…we take them out for the pulling tractors.you could have one or all…lol 2 1 Share this post Link to post Share on other sites
ebinmaine 80,893 #22998 Posted February 22, 2025 I sat and scanned through the rest of the Michael Martino book this morning. Straight from the Horses Mouth. Found this interesting little tidbit. 4 5 Share this post Link to post Share on other sites
MainelyWheelhorse 3,145 #22999 Posted February 23, 2025 11 hours ago, ebinmaine said: I sat and scanned through the rest of the Michael Martino book this morning. Straight from the Horses Mouth. Found this interesting little tidbit. @ebinmaine It must have been in Portland or down that way as I don’t recognize any of the restaurants as being in Waterville or Augusta. But it did take place six years before I was born…..😁 2 Share this post Link to post Share on other sites
stvski80085 279 #23000 Posted February 23, 2025 (edited) Replaced a bearing and started putting back together after paint. I ordered a new tension pulley but it’s like an inch bigger and won’t work. Was rubbing the belt wierd so in need to look for another. Original is back on for now. New belt also. Wheel horse 7434 I ordered from wheel horse parts vendor but I am thinking it has a different part number then the manual. The one they sent is too big. Edited February 23, 2025 by stvski80085 1 4 Share this post Link to post Share on other sites
