Colby G 248 #22401 Posted November 24, 2024 7 hours ago, oliver2-44 said: Yes, the Wisconsin is aftermarket. If the Wisconsin runs, they have lots of torque. Post a picture (or link like you did for the tractor) of the engine and any nameplate. Are those rear wheel weights steel or concrete? And the shifter won't go into 1st or 3rd at all, what would I do about that? Share this post Link to post Share on other sites
Colby G 248 #22402 Posted November 24, 2024 7 hours ago, oliver2-44 said: Yes, the Wisconsin is aftermarket. If the Wisconsin runs, they have lots of torque. Post a picture (or link like you did for the tractor) of the engine and any nameplate. Are those rear wheel weights steel or concrete? https://photos.app.goo.gl/bZXNq7WfZU1HDUMV7 Share this post Link to post Share on other sites
Lee1977 7,637 #22403 Posted November 24, 2024 (edited) Wisconsin Robin 185 3 HP at 3000 RPM, and 5 HP at 4000 RPM Edited November 24, 2024 by Lee1977 1 Share this post Link to post Share on other sites
dmoore 1,026 #22404 Posted November 24, 2024 Pulled the C-101 off the show circuit long enough to put it to work after our latest blow. 6 9 Share this post Link to post Share on other sites
dmoore 1,026 #22405 Posted November 24, 2024 And so it wouldn't be jealous, I pulled out the 854. 3 12 Share this post Link to post Share on other sites
kpinnc 18,252 #22406 Posted November 25, 2024 I repacked the bearings in an electric PTO that I am getting ready to put on my Bronco. Thank you @WHX?? 2 5 Share this post Link to post Share on other sites
WHX?? 56,598 #22407 Posted November 25, 2024 When you say repacked did you just pick the seal out @kpinnc? Share this post Link to post Share on other sites
kpinnc 18,252 #22408 Posted November 25, 2024 1 minute ago, WHX?? said: When you say repacked did you just pick the seal out @kpinnc? Yessir. Cleaned them out and repacked. Pretty smooth now. 1 Share this post Link to post Share on other sites
Chevy_59 19 #22409 Posted November 25, 2024 5 hours ago, dmoore said: And so it wouldn't be jealous, I pulled out the 854. what size and what brand of tri ribs are those Share this post Link to post Share on other sites
dmoore 1,026 #22410 Posted November 25, 2024 4.00 - 8 Deestone's bought from M.E.Miller Tire in Ohio. 1 Share this post Link to post Share on other sites
kpinnc 18,252 #22412 Posted November 25, 2024 On 11/24/2024 at 4:06 PM, dmoore said: And so it wouldn't be jealous, I pulled out the 854. That 854 is beautiful! 2 1 Share this post Link to post Share on other sites
dmoore 1,026 #22413 Posted November 25, 2024 (edited) Thanks! I like this pic better.. Edited November 25, 2024 by dmoore 2 7 Share this post Link to post Share on other sites
dmoore 1,026 #22414 Posted November 25, 2024 Or maybe this one.. 3 9 Share this post Link to post Share on other sites
kpinnc 18,252 #22415 Posted November 25, 2024 All of them look great! 1 1 1 Share this post Link to post Share on other sites
oliver2-44 11,482 #22416 Posted November 26, 2024 On 11/24/2024 at 10:50 AM, Colby G said: And the shifter won't go into 1st or 3rd at all, what would I do about that? Put the shifter in what feels like neutral. Pull the shifter out and look in the hole. The top of the forks should form a square. If the square looks like 2 offset pieces use a large screw driver or pry bar and move the pieces so the form a square. You may have to rock the tractor back and forth a little to help them move. Report back how it works out. 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #22417 Posted November 26, 2024 (edited) Shift knob restore. Still Waiting on more odds and ends for my C121 resto. In the meantime I noticed the shift knobs were wrecked no matter how much I scrubbed wire brush chemicals etc they still wouldn’t get clean. I’m too cheap to buy new. Used med grit sandpaper finished with 2500 . Now they are almost like new just need decals . I have too much time on my hands I guess or maybe just need help Shiny new balls !! Edited November 26, 2024 by Wheelhorse#1 8 4 1 Share this post Link to post Share on other sites
ebinmaine 78,868 #22418 Posted November 26, 2024 13 minutes ago, Wheelhorse#1 said: I have too much time on my hands I guess or maybe just need help Niiiiice work!! 1 Share this post Link to post Share on other sites
dmoore 1,026 #22419 Posted November 26, 2024 I think you're in perfect health 4 Share this post Link to post Share on other sites
ebinmaine 78,868 #22420 Posted November 26, 2024 6 minutes ago, dmoore said: I think you're in perfect health ........ and WE'RE the crowd to know! 5 Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #22421 Posted November 27, 2024 2 hours ago, ebinmaine said: ........ and WE'RE the crowd to know! Thank god for RS . I knew y'all would understand 2 Share this post Link to post Share on other sites
ebinmaine 78,868 #22422 Posted November 27, 2024 Before! 5 1 1 Share this post Link to post Share on other sites
WHGuy413 2,859 #22423 Posted November 27, 2024 I’ve been absent again but I’m still picking away. My repowered 12 automatic (18hp Briggs and Stratton vanguard v twin) was running like garbage so I cleaned the carb and fixed a ground kill wire leading to the front coil that I saw the mice had chewed. Took it out to do a load of firewood and it sounded off and had no power. Come to find out I had no spark on the back cylinder. I replaced both wires and then had no spark whatsoever. Confused I dug into the repair manual and surfed the internet. Turns out there are diodes in the coil ground kill wires. Reached out to a friend who has a repair shop and he had a junk engine that had the wire on it. Plugged it in and it’s back up and running on both cylinders. I decided it’s going to be my firewood/ back up plow tractor for the winter. Just need to install a plow on it if one of @WheelHorse_Kid‘s tractors or his brothers 856 fail on us but I don’t see that happening. Also got my fiancé’s little guy and my dog who I’m trying to get more comfortable in the garage out there with me. 3 4 3 Share this post Link to post Share on other sites
kpinnc 18,252 #22424 Posted November 27, 2024 6 hours ago, Wheelhorse#1 said: I have too much time on my hands I guess or maybe just need help Not at all I did the same thing with mine. 2 Share this post Link to post Share on other sites
Lee1977 7,637 #22425 Posted November 27, 2024 My shifter nobs were not that bad, and I didn't get them as good as you did, but we had the same idea. Clean them up and use them. 1 Share this post Link to post Share on other sites
