wallfish 19,744 #21676 Posted July 6, 2024 59 minutes ago, squonk said: @wallfish Took the guides off and tried to fit the belt guard. It seems the front pulley is too big. I got it from K & B and it was marked an RJ engine pulley. Might explain why I had to use a 31" belt to fit. Could be. Should be a 2.5 inch OD pulley with the set screw in the groove. Brian said he is making more. They do ride tight in there but should leave about 1/8" of space for the belt to release from the pulley groove. Yes, the belt guide fingers would need to be removed to install it and the guard will then guide the belt instead. That belt appears to be riding a little high in the groove but maybe not. Does it seem to go a little faster that it should be? 3 Share this post Link to post Share on other sites
Sparky-(Admin) 25,027 #21677 Posted July 6, 2024 It’s the little things…didn’t like how the PO painted the lugs but ignored the hubs . Luckily I have a coffee can full of unpainted lugs. Shot the hubs with dark red primer, goes well with the patina. 3 1 Share this post Link to post Share on other sites
wallfish 19,744 #21678 Posted July 6, 2024 2 minutes ago, Sparky said: It’s the little things…didn’t like how the PO painted the lugs but ignored the hubs . Luckily I have a coffee can full of unpainted lugs. Shot the hubs with dark red primer, goes well with the patina. Yeah, the contrast makes it look much better IMO. And stop being a lug nut nazi. I might need some more from ya if I can get the hubs off that Commando 800 to swap them to normal good ones. 4 Share this post Link to post Share on other sites
squonk 46,117 #21679 Posted July 6, 2024 6 minutes ago, wallfish said: Could be. Should be a 2.5 inch OD pulley with the set screw in the groove. Brian said he is making more. They do ride tight in there but should leave about 1/8" of space for the belt to release from the pulley groove. Yes, the belt guide fingers would need to be removed to install it and the guard will then guide the belt instead. That belt appears to be riding a little high in the groove but maybe not. Does it seem to go a little faster that it should be? I'll have to measure the pulley but the guard doesn't fit over all of the pulleys. Doesn't seem faster than it should be. Share this post Link to post Share on other sites
ebinmaine 78,298 #21680 Posted July 6, 2024 23 minutes ago, MainelyWheelhorse said: That's sound advice, however a wind break when its -10 isn't a bad thing either. Ahhh yes! We live in a thick forest so there's a VERY large windbreak. Share this post Link to post Share on other sites
ebinmaine 78,298 #21681 Posted July 6, 2024 Working on our friend's Workhorse. A little maintenance. A little repair. All good. 2 2 Share this post Link to post Share on other sites
cafoose 3,685 #21682 Posted July 6, 2024 Working on my sickle project today and I got a visitor 6 1 Share this post Link to post Share on other sites
wallfish 19,744 #21683 Posted July 6, 2024 Just now, squonk said: I'll have to measure the pulley but the guard doesn't fit over all of the pulleys. Doesn't seem faster than it should be. There might be bigger holes drilled into the frame which allows the motor to "slide" more. And yes, some of those little nut roasters can be a pain to get the guard on and work correctly Share this post Link to post Share on other sites
ebinmaine 78,298 #21684 Posted July 6, 2024 2 minutes ago, wallfish said: Yeah, the contrast makes it look much better IMO. And stop being a lug nut nazi. I might need some more from ya if I can get the hubs off that Commando 800 to swap them to normal good ones. John we got a pile of stock Wheelhorse lugnuts for ya headed down mebbe this Friday. 2 Share this post Link to post Share on other sites
wallfish 19,744 #21685 Posted July 6, 2024 1 minute ago, cafoose said: Working on my sickle project today and I got a visitor Imagine just reaching over and grabbing that instead of the belt or an air hose! LOL 6 Share this post Link to post Share on other sites
squonk 46,117 #21686 Posted July 6, 2024 Just now, wallfish said: There might be bigger holes drilled into the frame which allows the motor to "slide" more. And yes, some of those little nut roasters can be a pain to get the guard on and work correctly Engine is back and close to the trans as it can go. It's not a WH spec. Engine so maybe that's got something to do with it. Exhaust port was only 1/2 " and I had to lower the entire exhaust from it's normal height. Had to drill new holes for the pipe hanger. Share this post Link to post Share on other sites
Ed Kennell 45,761 #21687 Posted July 6, 2024 15 minutes ago, cafoose said: I got a visitor A good mouser. 2 Share this post Link to post Share on other sites
wallfish 19,744 #21688 Posted July 6, 2024 4 minutes ago, squonk said: Engine is back and close to the trans as it can go. It's not a WH spec. Engine so maybe that's got something to do with it. Exhaust port was only 1/2 " and I had to lower the entire exhaust from it's normal height. Had to drill new holes for the pipe hanger. I don't remember if they put a plate under the H55 Teccys to raise the shaft for those tractors or not, but don't think so. Maybe Cas @formariz could shed some light about changing from a H55 to K91 and fitting the guard. Share this post Link to post Share on other sites
WHGuy413 2,851 #21689 Posted July 7, 2024 Hot and muggy here in western Massachusetts but @WheelHorse_Kid and I spent a little time outside yesterday under the trees working on a C-105 that came as a package deal when I bought my c-160 auto. It’s pretty rough body wise but the transmission shifts into all gears. It’s an absolute wiring nightmare with random wires with a zillion connectors and splices everywhere. We got the engine running by jumping the starter direct and putting a jumper wire to the coil. The idea was to use it as our base for his pulling tractor build but…. I went to my friends house to pick up a tractor he sold to my older sons friend and came home with another c-105 (from a package deal him and I went in on a few months ago). It’s in much better shape body wise and should be easier to clean up when we are ready for paint. So now the plan is to take the best of both the tractors and make one real good one and Save the transmission and engine from what ever one we aren’t using as spares for his puller. The good looking c-105 is on the left in the picture. C-85 is going to my older sons friend tomorrow. while out yesterday working on the first c-105 Alex took the rear tire off and was swarmed with yellow jackets. Thank god he didn’t get stung since he’s allergic. I watched the tire go flying and him Go running. They had built a nest under the flat rear tire. How neither of us got stung all day working on and around that tire I don’t know. But glad someone was looking out for him. 2 7 Share this post Link to post Share on other sites
76c12091520h 4,133 #21690 Posted July 7, 2024 Got the 401 up and running and gave it a bath , first time it's been cleaned since we've owned it and the first time it's moved under it's own power in at least 35 years. 2 14 Share this post Link to post Share on other sites
squonk 46,117 #21691 Posted July 7, 2024 When I purchased this 551 the transmission had new seals already installed. Noticed a small puddle under the tractor this morning. The brake shaft seal left the chat a tad early! 1 5 Share this post Link to post Share on other sites
ML3 2,246 #21692 Posted July 7, 2024 Put a tach & gps speedo on rat rod. Wanted the "old school" look on the hood but with modern gages. And fortunately everything works! 5 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,102 #21693 Posted July 7, 2024 (edited) The Federal Railroad Administration - Railroad Safety Board stopped by for an unannounced inspection today at the Sylvan Lake & Wheel Horse Northern RR... Apparently, there are millions of new regulations to accompany the new Green Deal for electrification of our nation's railways and they are picking on the small pathfinders - on the tip of the spear so to speak... You know, regulations to guide and assist... Well the SL&WHN RR passed with flying colors after i explained to the inspector that there was a Bourbon named after the RR... He was very impressed - with the bourbon - and he had me assist him in filling out the inspection form after he "tested" the bourbon a few times... All i needed to do was post this sign, and promise to keep a bottle on hand for future visits... Edited July 9, 2024 by SylvanLakeWH 16 Share this post Link to post Share on other sites
ebinmaine 78,298 #21694 Posted July 7, 2024 Darn good thing those 'lectrikk horses cain't go 88 mph or you'd be all over time n back again!! 3 Share this post Link to post Share on other sites
953 nut 65,265 #21695 Posted July 7, 2024 On 7/6/2024 at 6:49 PM, wallfish said: Imagine just reaching over and grabbing that instead of the belt or an air hose! LOL Been there, Went into the garden shed without turning on the light and reached for a pair of clippers at the back of a shelf. As I felt what I thought was the handle it moved, turned out to be a small black snake about two feet. He was gone and I decided to turn on the light next time. 5 Share this post Link to post Share on other sites
Streetrodchev 1,080 #21696 Posted July 8, 2024 Swapped out the non-WH front weights for the set I found at a swap meet earlier this year. 5 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #21697 Posted July 8, 2024 Flat right front tyre yesterday. Mowing must be interrupted with the suicidal Mowerdeck. Heck the Grass is now still 80cm high... 🤪 ordered new one. 3 Share this post Link to post Share on other sites
sqrlgtr 2,610 #21698 Posted July 8, 2024 On 7/6/2024 at 6:46 PM, cafoose said: Working on my sickle project today and I got a visitor I sure am glad we didnt meet him the other day when we were out stomping around your place looking for wheel horse stuff . Surprises got to love them... 1 4 Share this post Link to post Share on other sites
ebinmaine 78,298 #21699 Posted July 8, 2024 I wish we had those larger non-venomous snakes. It would help a lot with our rodent issues. 2 1 Share this post Link to post Share on other sites
Pullstart 69,691 #21700 Posted July 8, 2024 Unc got to give William and Rosaleigh a tractor ride this weekend! It’s hard to believe, but he is 2 and she is 4! 3 2 8 Share this post Link to post Share on other sites
