ebinmaine 79,789 #20476 Posted December 24, 2023 6 minutes ago, 19richie66 said: Lug studs are the first modification that should be done to a tractor. Should be a rule somewhere. Absolutely agreed. Every one of ours has them. Rules: 1. Procure Wheelhorses. 2. Install lug stud bolts. 3. Blah. Blah. Blah. Whatever.... 1 5 Share this post Link to post Share on other sites
953 nut 67,662 #20477 Posted December 24, 2023 20 hours ago, METAL BENDER said: I checked the oil last week and all was well but now it is jet black so I think the gasket was blown for a few hours leaking internally then it gave out today. The motor has been worked before as the clearance on my plug to the piston top is so close I am using a short tail plug so I think I'm going to need a new head . A new head on an old motor could cause more problems down the road unless I rebuild the whole motor If you are wanting to spend some money to buy a new or rebuilt engine without checking over the engine you have then by all means do it. @richmondred01 does a fine job on engine rebuilds and could fix you up. I would suggest you remove the cylinder head and take a look first. It may just be a new gasket and flattening the head is all that is needed. Your engine oil color change could be a product of a blown head gasket, when the piston is going down it will create a suction on the head gasket flaw and suck in some dirt. Your spark plug should be located between the intake and exhaust valves and would not make contact with the piston at all. The correct spark plug is a Champion H-10. Please pull the head off and post some pictures of what you find. 3 Share this post Link to post Share on other sites
ebinmaine 79,789 #20478 Posted December 24, 2023 20 hours ago, METAL BENDER said: A new head on an old motor could cause more problems down the road unless I rebuild the whole motor. I was wondering about this yesterday too. I've heard of a new/reman head WITH VALVES IN IT causing an increasing in sealing in the engine thereby raising the possibilities of pressure on the lower end such as piston rings. Having no valves in a flathead I'm not sure why a new head or planing the existing one would hurt the engine. Share this post Link to post Share on other sites
D_Mac 9,337 #20479 Posted December 24, 2023 I have a silly question. I would like to install those LED lights on my 310-8. When ordering the PAR-36 8w lights do i need to do any other mods to the tractor to get them to fit or function properly? Thanks 1 Share this post Link to post Share on other sites
ebinmaine 79,789 #20480 Posted December 24, 2023 1 hour ago, D_Mac said: I have a silly question. I would like to install those LED lights on my 310-8. When ordering the PAR-36 8w lights do i need to do any other mods to the tractor to get them to fit or function properly? Thanks Depends whether that particular 310 is one with the lower powered amp alternator or not. If the lamps are connected directly to the battery you should be fine. 1 Share this post Link to post Share on other sites
kpinnc 18,771 #20481 Posted December 25, 2023 (edited) 8 hours ago, D_Mac said: I have a silly question. I would like to install those LED lights on my 310-8. When ordering the PAR-36 8w lights do i need to do any other mods to the tractor to get them to fit or function properly? Thanks The 8 watt versions have less amp load than incandescent bulbs, so if your machine already has lights then you should be fine. Be sure to run a ground strap from the hood to the frame or engine. Using the hinge alone for a ground can make the LEDs flicker. And anything with a higher rating than 4500K will have a blueish tint to it. Edited December 25, 2023 by kpinnc 2 1 Share this post Link to post Share on other sites
OoPEZoO 607 #20482 Posted December 25, 2023 Eric is correct……LED lights don’t like the unregulated AC from the low powered charging systems on the mid-eighty’s tractors. I tried to put a set on my 314-8 and they would overheat and shut down after a few mins of use. I have since swapped the stator over to a 15A system with a regulator and they work fine now. I could have rewired the lights to run directly off of the battery, but I wanted the higher amp charging system because I needed it to handle the electrical load of a Johnny bucket as well 3 1 Share this post Link to post Share on other sites
TractorEd 675 #20483 Posted December 25, 2023 Merry Christmas! 2 1 Share this post Link to post Share on other sites
Colby G 248 #20484 Posted December 25, 2023 (edited) Merry Xmas everyone! Santa brought me a new engine for my charger 12 project! Edited December 25, 2023 by Colby G 10 2 Share this post Link to post Share on other sites
WHX?? 57,503 #20485 Posted December 26, 2023 Nothin like spending Christmas out in the shop. Glassed a head and worked on a K301 build. My fav a SG motor. Valves looked a little dicey after lapping so new ones on the way. Just a re-ring on the bore. 7 8 Share this post Link to post Share on other sites
Ed Kennell 46,642 #20486 Posted December 29, 2023 Brought a few out in the sun and left them run a while for their year end warm up. 417A 310-8 312H 520H 7 8 Share this post Link to post Share on other sites
Colby G 248 #20487 Posted December 30, 2023 Could any of these pulleys work on the rear end of my charger 12? (Yes, I'm still stuck on this project. Can't figure out what rear end it is yet... In case anyone out there can, the model number of the hydro is 90-2070) I will also include pictures of the hydro shaft. Any info would be greatly appreciated. 1 Share this post Link to post Share on other sites
76c12091520h 4,241 #20488 Posted December 30, 2023 3 hours ago, Colby G said: Could any of these pulleys work on the rear end of my charger 12? (Yes, I'm still stuck on this project. Can't figure out what rear end it is yet... In case anyone out there can, the model number of the hydro is 90-2070) I will also include pictures of the hydro shaft. Any info would be greatly appreciated. The pulleys in these pictures are for rear engine riders...... 1 Share this post Link to post Share on other sites
Colby G 248 #20489 Posted December 30, 2023 13 minutes ago, 76c12091520h said: The pulleys in these pictures are for rear engine riders...... Goes to show how much I know 😂 I was thinking they might work because they had the same keyway. Do you know which one would work? I have a guy looking for one for me but I'm looking around in the meantime in case it's not the right one. 1 Share this post Link to post Share on other sites
oliver2-44 11,651 #20490 Posted December 30, 2023 On 12/25/2023 at 6:23 PM, WHX?? said: Valves looked a little dicey after lapping @WHX?? I’m interested in the valve lapping attachment you have in you drill. I’ve never seen one like that. Looks like it sure would beat a hand lapped. 3 1 Share this post Link to post Share on other sites
WHX?? 57,503 #20491 Posted December 30, 2023 (edited) 3 hours ago, oliver2-44 said: @WHX?? I’m interested in the valve lapping attachment you have in you drill. I’ve never seen one like that. Looks like it sure would beat a hand lapped. It was cheap in the jungle. Works just ok. There is a clutch of sorts in it that likes to slip. It came with a bunch of suction cups but mostly for very large valves. Getting the cup to stick to the valve is problematic. I got it mainly to do a poor man's seat re-facer. This works too a guy just needs to shorten the hand lapper. A short wood dowel. Edited December 30, 2023 by WHX?? 5 Share this post Link to post Share on other sites
19richie66 17,930 #20492 Posted December 30, 2023 12 hours ago, Colby G said: Goes to show how much I know 😂 I was thinking they might work because they had the same keyway. Do you know which one would work? I have a guy looking for one for me but I'm looking around in the meantime in case it's not the right one. I found it. Pm’ed you pictures. Share this post Link to post Share on other sites
AMC RULES 37,259 #20493 Posted December 30, 2023 Started the process of saving these '55 rims. Can already tell... they will be sexy. 5 1 2 Share this post Link to post Share on other sites
pfrederi 20,924 #20494 Posted December 30, 2023 (edited) I have been working on a C-160-8 that i got cheap at auction last Spring. Got her running and put her away to be this winter project. Drove her back up here a couple weeks ago and started disassembly. I have worked on a bunch of WHs but the "stuckiness" of just about every part on this one is really getting old. Absolutely nothing comes apart with out a lot of effort. Latest road block is the flywheel screen. i actually managed to get all the shroud bolts out with out breaking any but I can't move any of the screen screws. A few days of Kroil, heat, whacking with a brass hammer and several tries with the impact driver ...nada... Edited December 30, 2023 by pfrederi 4 Share this post Link to post Share on other sites
Ed Kennell 46,642 #20495 Posted December 30, 2023 7 minutes ago, pfrederi said: A few days of Kroil, heat, whacking with a brass hammer and several tries with the impact driver ...nada... Time to throw it on the drill press? 1 Share this post Link to post Share on other sites
Handy Don 17,043 #20496 Posted December 30, 2023 12 minutes ago, pfrederi said: Kroil, heat, whacking with a brass hammer and several tries with the impact driver ...nada... Those impact drivers are very cool and my last resort before cutting, drilling and grinding. There have been fails, however. Try tightening to see if you get any movement? 1 1 Share this post Link to post Share on other sites
ebinmaine 79,789 #20497 Posted December 30, 2023 16 minutes ago, Handy Don said: Try tightening to see if you get any movement? That's my go-to as well. If the screws are beyond saving you could also weld a nut to the outside of the screw head. The nut allows MUCH better grip and the heat will often help breaking the rust. 5 Share this post Link to post Share on other sites
ebinmaine 79,789 #20498 Posted December 30, 2023 1 hour ago, AMC RULES said: Started the process of saving these '55 rims. E tank Craig? 1 1 Share this post Link to post Share on other sites
pfrederi 20,924 #20499 Posted December 30, 2023 Had to back off on the heating...started some stuff inside the shroud to smoldering Good idea on tightening will reverse the impact driver when the smoke clears.... 5 Share this post Link to post Share on other sites
Handy Don 17,043 #20500 Posted December 30, 2023 1 hour ago, pfrederi said: when the smoke clears Always an interesting time... 1 1 Share this post Link to post Share on other sites
