Ed Kennell 47,078 #19476 Posted July 7, 2023 3 minutes ago, rjg854 said: Have you gotten enough snow in the last couple of years to need that blower I haven't gotten enough snow to need a shovel in the past 5 years. I may use it to mulch pumpkins. 1 7 1 Share this post Link to post Share on other sites
squonk 47,976 #19477 Posted July 7, 2023 13 minutes ago, Ed Kennell said: I haven't gotten enough snow to need a shovel in the past 5 years. I may use it to mulch pumpkins. Big Show Event! 2 3 1 Share this post Link to post Share on other sites
peter lena 10,029 #19478 Posted July 7, 2023 @SylvanLakeWH found those added washers and lube to related areas , make for a smooth solid engagement , go greasy , pete 1 Share this post Link to post Share on other sites
Thatoneguy 197 #19479 Posted July 8, 2023 I got all my parts pressure washed! Of course the rear end/hydro pump now has a small leak so it looks like i will be separating them… 4 2 Share this post Link to post Share on other sites
ebinmaine 80,440 #19480 Posted July 8, 2023 16 minutes ago, mower said: I got all my parts pressure washed! Of course the rear end/hydro pump now has a small leak so it looks like i will be separating them… I might have the gasket for that. I can check Sunday. 1 2 Share this post Link to post Share on other sites
cafoose 3,819 #19481 Posted July 8, 2023 6 hours ago, Ed Kennell said: All back together and ready for a blizzard. That setup will really move any kind of snow, even the heavy wet stuff and the packed snowbanks from PennDot 2 Share this post Link to post Share on other sites
squonk 47,976 #19482 Posted July 8, 2023 15 hours ago, Stormin said: Found on of the headlights on the C-125 was hanging off. Two of the securing clips had broken. Now the chances of replacing them will be zero over here. Can't see how you can really. Looking at them I wondered of they would turn round. Nothing to lose, so a pair of pliars, (English spelling), were brought into play. Luck was with me and they did turn 180 degrees. Head light secured once more. I'm putting pliars in my little book next to plough! 1 5 Share this post Link to post Share on other sites
ebinmaine 80,440 #19483 Posted July 8, 2023 1 hour ago, squonk said: I'm putting pliars in my little book next to plough! And tyres? 2 Share this post Link to post Share on other sites
squonk 47,976 #19484 Posted July 8, 2023 Just now, ebinmaine said: And tyres? Tyres comes after sires. 4 Share this post Link to post Share on other sites
peter lena 10,029 #19485 Posted July 8, 2023 @mower that bare frame , is practicly asking for a steel tube fuel line , inside of frame angle , run it the length , extend 6" vinyl cap off . as you build up it would be easy to add clear vinyl fuel line / filters , virtually eliminating fuel line break down debris . just an idea, pete 1 2 Share this post Link to post Share on other sites
8ntruck 9,241 #19486 Posted July 8, 2023 (edited) My Triumph Spitfire taught me English. You put the hood up when you wanted to stay dry in the rain. You opened the bonnet when you needed to work on the SU carburettor. The spare tyre was stored in the boot. It kept wanting me to use something called spanners on it. I made do with wrenches for those jobs. Sometimes we had quite heated discussions on that subject. Edited July 8, 2023 by 8ntruck 2 5 Share this post Link to post Share on other sites
Evguy 567 #19487 Posted July 8, 2023 31 minutes ago, 8ntruck said: My Triumph Spitfire taught me English. You put the hood up when you wanted to stay dry in the rain. You opened the bonnet when you needed to work on the SU carburettor. The spare tyre was stored in the boot. It kept wanting me to use something called spanners on it. I made do with wrenches for those jobs. Sometimes we had quite heated discussions on that subject. I worked with a guy from Australia, he kept asking for spanners and a torch. I was informed torches were lights, and gas was a torch. Learned a few new swear words too. 🙂 4 Share this post Link to post Share on other sites
D_Mac 9,339 #19488 Posted July 8, 2023 (edited) Put the deck on the Free10-8 for the first time. Fired it up and engaged the blades and it is whisper quite. I was also able to squeeze it into the garage with the other 3 Horses even with the deck on. I couldn't be happier. Edited July 8, 2023 by D_Mac 3 10 1 Share this post Link to post Share on other sites
Handy Don 17,369 #19489 Posted July 8, 2023 Renewed my Supporter membership. Looking forward to the next couple of years! 1 9 2 Share this post Link to post Share on other sites
cafoose 3,819 #19490 Posted July 8, 2023 The @Ed Kennell 953 from the Big Show shut off last week and didn't start. I have it in the neighbor's barn and didn't have tools with me to check it out at the time. The clamp screw on the coil is completely unscrewed and the coil slid down. Looks like the wire was too short with the coil all the way down. I found this: 6 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,078 #19491 Posted July 8, 2023 1 minute ago, cafoose said: I found this: Wish they were all that easy. 5 2 Share this post Link to post Share on other sites
Lee1977 7,750 #19492 Posted July 9, 2023 1 hour ago, Ed Kennell said: Wish they were all that easy. A lot of then are If you knew where to look. My 312 wouldn't start back up over at the farm. Had to haul it back home. Used my meter found no power on the battery wire. Fuse was good the fuse box was bad. 4 Share this post Link to post Share on other sites
ML3 2,485 #19493 Posted July 9, 2023 Took RJ apart. Initially wasn't going to paint it but it wasn't a correct color & had a few spots where paint was coming off. Got some parts painted w/1coat. Do another coat tomorrow. Plenty little things to fix. Whoever did refurbishment before didn't use cotter pins- used bent up nails??? Most the bolts are all mismatched so I wanna correct that. Simple little details need taken care of. Wheels & seat are painted white they need refinishing. Think I wanna go with the almond or antique white?? 9 2 Share this post Link to post Share on other sites
DevonianHorse 313 #19494 Posted July 9, 2023 Wheelhorse was used to move tents and supplies for my brother's 28th birthday BBQ 14 3 3 Share this post Link to post Share on other sites
8ntruck 9,241 #19495 Posted July 10, 2023 I poured two fingers worth of my Wheel Horse over 4 ice cubes, added a some lemon juice and Diet Coke and I am sipping it as I read the forum. 3 5 1 Share this post Link to post Share on other sites
squonk 47,976 #19496 Posted July 10, 2023 Starting to get tractors ready for the Steam Pageant. Added a shim to the 953 clutch pivot to get the sloppies out 5 4 Share this post Link to post Share on other sites
pfrederi 21,091 #19497 Posted July 10, 2023 Early this year I got a pallet 6 of engines for $15 at auction. Cleaned the carb and S/G, bought a new regulator and it runs. One other K181 I think will be saveable... MVI_0822.MOV 10 Share this post Link to post Share on other sites
Andy N. 2,806 #19498 Posted July 11, 2023 My older sister and family came to visit this weekend. They live in rural IN and tractors and other power equipment aren't new to them at all, but my BIL comes from a green family so riding Uncle Andy's red tractors was a new experience. Plus the 520-H was my dad's before he passed so they really wanted to drive Grandpa's tractor. Nephews are 10 & 17. I had to short the seat switch in order for the 10 year old to be able to reach the clutch while mowing and not have the tractor shut off on him. They also love trains so we went to the Illinois Railway Museum and I took them to my work to show them one of the planes that I maintain. So it was a planes, trains, and tractors weekdend. IMG_3061.mp4 IMG_3060.mp4 4 8 Share this post Link to post Share on other sites
JCM 11,402 #19499 Posted July 11, 2023 What could be better than that, A sweet sounding Onan and a Kohler wound up a bit and a full head of hair. Ah, the old days. 3 4 Share this post Link to post Share on other sites
ebinmaine 80,440 #19500 Posted July 11, 2023 7 minutes ago, JCM said: a full head of hair I ain't seen THAT in a while.... 5 Share this post Link to post Share on other sites
